Mitsubishi Medallion WS-65611 65 in. Rear Projection looks like the Blue has collapsed (drops in the across the top, more in the middle). Is it something I can replace or do I need to call a repairman?
  • 1,800 Answers
Replace the blue picture tube its in the convergence tube specify ur model and by it frm here click here
plz rate this post
Posted on Aug 26, 2008
  • 1,879 Answers
Repairman.
Faded white picture
You need to have a good look inside especially at the fold over plugs on the middle board==not unusual for the metal bands across the top to lift up just slightly===especially if middle board was removed for convergence repair.
Other than that it could be a bad solder connection etc--extreme care to localize what area should be taken if set on etc.
Sep 01, 2012 | Mitsubishi WS-65809 65" Rear Projection...
I have a Mitsubishi 55"
This set has a convergence problem. You should only need to replace the IC. Part is STK393-110. It sits on the middle board behind the large heatsink. Use a heat transfer compound to ensure repair lasts. If you have no experience soldering (or unsoldering) please use a professional for the work. The traces are fragile and I have fixed many mistakes local DIYers have committed. Goodluck.
Jan 20, 2011 | Mitsubishi WS-55511 55" Rear Projection...
My 55"mitsu medallion has a
Please define what you mean by a poor picture, 3 d looking or what?
SD TECH
Dec 27, 2010 | Mitsubishi WS-55413 55" Rear Projection...
Blue Screen
One of two things happened. The light engine died, or if that unit uses a single lamp, it died. Most Mitsubishi's used three lamps leading to the light engine. I am trying to fix my neighbors now and was lucky enough to find an engine for under $300. Dealers will charge between $800 and $1500 to fix this. Confirmation can only be done by a tech inspection. If the power button blinks a specific color or pattern repost with that information.
Jun 30, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi Medallion 1080 WS-55413 - colors not aligned
There is no "reset" as the set has in the customer and tech menus ways to attempt to manually adjust this.
under convergence in the customer menu select advanced and follow the instructions on the screen.
If Red or Blue or Green are skewed and will not adjust it means one of the two STK-394-250 CONVERGENCE chips this set uses is bad.
Depending on where you buy them they will range in price from about 12 dollars each to nearly 35 dollars each.
Let me know what you find; this may or may not be a do it yourself repair as some real expertise is required to correctly get at and replace the chips.
SD TECH
May 11, 2010 | Mitsubishi WS-55413 55" Rear Projection...
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
Feb 17, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Red streaks across my screen of my tv
is it like a double image kind of thing?i dont know what 'red streaks' are....
Oct 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Pinching in at the sides and has blurry rainbow coloring on top and bottom.
Sounds like a pincushion problem. You can obtain the service manual and free diagnostic upport at the following link. Hope this helps.
http://servicemanuals.vstore.ca/
Jan 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
