Question about Canon ZR60 Mini DV Digital Camcorder
Grainy Playback I just got a Canon ZR-60. The playback is "grainy". I've tried adjusting the shutter speed and white balance. I've also tried cleaning the heads, but there has not been a noticable change. HELP.
    Sergeant:
  • 255 Answers
1. Starting at http://www.canondv.com/zr60/ I read it has a digital zoom. You will find that such to be less useful that one expects. 2. Low light levels can result in more graininess. "Recommended illumination: More than 100 lx" Notice that 100 lux is pretty bright. Try 200 lux. 3. I must ask this: Did it ever work? 4. From the specs: "Image sensor: 1/6" CCD (charge coupled device) approx. 680,000 pixels (approx. 340,000 effective pixels-tape)" 340,000 pixels is OK for common video work, but today's consumers might compare a frame to some multimegapixel camera. This is just 0.34 megapixels, so grain may indeed show as you blow it up.
Posted on Sep 04, 2005
LGcamera Treasure Pictures are grainy I tried a few things without results
The lower you set your ISO, the less 'grainy' (it's actually electronic noise) your pictures will appear, but bear in mind that you will need to adjust your exposure to compensate, and possibly your white balance too.
Jan 12, 2017 | Cameras
Shots coming out black or nearly black. I'm shooting in RAW. When I try and rescue them on photoshop they come out really grainy
Sounds like the shots are under exposed with the shutter speed to fast.
Are you shooting in low light and no flash ?
If so, reduce your shutter speed to something like 1/60 with an aperture of around F5.6 - F7.1 (these can be lowered if you raise your iso)
Obviously this will depend on the lens type and brand.
Your statement sounds like you are shooting in raw at a very fast shutter speed with a low iso (200).
The grainy effect is normally due to a lot of noise (high iso) which makes this sound strange to say the least.
Check your camera settings (menu) and turn on noise reducution, this will help in removing some of the noise.
Oct 31, 2009 | Nikon D40x Digital Camera
Fujifilm finepix f20le. circular grainy pic loss of sound
First go to the SETUP menu and make sure that the PLAYBACK VOLUME setting is set to a value greater than 0. Try increasing the shutter speed of any photos as CCD's will notoriously produce grainy images on slow shutter speeds. Grainy videos will indicate poor light, camera shake during filming or moving too quickly so the autofocus cannot function correctly, or using too low a resolution and will be especially noticeable at 640 x 480 when viewed on a large high resolution screen. If all the above make no difference then you may need to get the camera serviced.
Oct 08, 2009 | Fuji FinePix F20 Digital Camera
Canon Eos Rebel SLR (non-digital) takes blurry grainy indoor pictures, even with flash, even when I put a lot of lights on. I use Fujifilm 400. I have used my 300mm telephoto and my regular short lens,...
Sounds like the shutter is making long exsposure and you are actuallly getting blur- this can even happen with flash if the shutter stay open too  long.  without film, look in viewfinder and see what shutter speed the cmaer awants to use- it may be set incorrectly and is set on manual shutter speed- the shutter speed numners are actually the bottm part of a fraction, so 30 is 1/30th of a second- to prevent blur you want the numbers to be 60 or higher.
Aug 23, 2009 | Canon Photography
Grainy bdmv platyback
You have a couple of options.
1. Turn down the sharpness on your TV. Too much is overkill, anyway.
2. Whilst watching any movie, hit the triangle button for the movie settings & options. Turn up the noise reduction to +3, also the "mosquito" noise to +3.
These should give you a less grainy picture. Enjoy!
May 29, 2009 | Sony Playstation 3 (PS3) Console
Polaroid i1035: Bad quality pictures, appear grainy and fuzzy
The grainy effect has to do do with the ISO setting, try adjusting that. A higher ISO is generally better for darker conditions. I have noticed that this camera frequently takes grainy images.
Jan 29, 2009 | Polaroid i1035 Digital Camera
Grainy Pictures
I have an earlier version of this camera: a minolta  dimage 7. While your camera is better(later) than mine beyond ISO 100 these cameras tend to be noisy.  The only solution is to asscpt the noise since hou will need a high ISO in order to use an acceptable shutter speed  and use a noise reduction program (noise ninja, neat image, helcion noise filter). One of these may be free- i think helcionbut aside from changing to a DSLR this is the best solution
Jan 17, 2009 | Konica Minolta DiMAGE A2 Digital Camera
How to overcome Grainy photos on some in door shots with my Canon A710
The reason for this is that the auto scene function chooses which ISO (light sensitivity) is needed to have a fast enough shutter speed to capture a still image (instead of a ghosted image). There is no way to change this. You can switch modes to P and specify the ISO you want to use (100-200 will give you a clear, non-grainy image, 400+ will be grainy). To capture a still image in low light with a low ISO, you need to use a tripod. Hope this helps.
Sep 22, 2008 | Canon PowerShot A710 IS Digital Camera
Very grainy pictures indoors at night
If you can adjust the ISO sensitivity to a lower number then the graininess will be reduced.
However, by reducing the ISO, you will need a slower shutter speed and a larger aperture. A tripod, table or other support may be necessary.
The "noise reduction" setting on the camera can also be adjusted a step up.
Taking pictures at full resolution and fine compression will also help.
Overall, at least try lowering the ISO, and using the flash brighter.
Jul 01, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Grainy pictures
grainy pictures are possibly casued by a very high ISO (sensativity) setting, you should be on 100 or lower for best normal shots. Higher settings are for low light and custom shooting in strange lighting or aperature/shutter speeds. Try full auto setting.
Mar 03, 2008 | Canon PowerShot S3 IS Digital Camera
Canon ZR60 Mini DV Digital Camcorder Logo
146 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
