Canon Optura 60 Mini DV Digital Camcorder
Problem for Canon Optura 60 Mini DV Digital Camcorder
Cassette Jam
By Guest on Sep 04, 2005
How to get the videocassette out when the cassette compartment will not open?
Best Solution
posted on Oct 23, 2007
Helpful)
Berean
Rank: Apprentice
Rating: 92%, 4 votes
I had this problem, and here is how it was resolved.
My cassette would not pop out when I opened the door with the camera turned on. When I turned off the camera and opened the door, it slid out much further, but still failed to pop open so that I could remove the tape. Then it slid back in.
Remove the battery, and have the camera off, but make sure the power cord is connected. Open the door until the tape slides out further than at other times. (Note: It intermittently slides out further when the camera is off. Sometimes it will not slide out any further than when it is on.) When the tape is slid out as far as it will go, quickly remove the power cord. The tape will stay in the slid-out position. Now, at the bottom side of the tape door there is a curved channel for a small pin to slide in. This channel has a 90% curve at the bottom of the channel to catch the pin, which holds the door closed. Push that pin back a little (toward the lense) to get it to go around that 90% curve, and the door will pop open so you can remove your tape. The ribbon of your tape will be jammed in the camera a little, so you will have to be careful and move the ribbon around a little until you can get it out freely.
This worked for me twice. I did not try putting a tape in again.
I hope this helps.
You rated this solution as "Helpful".
Solution #2
posted on Sep 04, 2005
Somewhat Helpful)
Fishi
Rank: Master  Canon Expert
Rating: 79%, 224 votes
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack.
Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically.
Please try the following procedures.
1. Attach the power source to the camcorder correctly or use a fully-charged battery pack.
2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch.
The videocassette will eject automatically after a few seconds.
If the videocassette still will not eject, seek assistance from a Canon Service Facility.
You rated this solution as "Somewhat Helpful".
Solution #3
posted on Sep 29, 2007
Not Rated)
Guest
Rank: Apprentice  Cameras & Camcorders  Expert
Rating: 0%, 0 votes
Hi, I tried to insert the tape when the battery was really low. It did not fully insert and was stuck half way. I tried the power supply and it did not work.
I called Canon and they said to remove all batteries and cables and wait like 3 minutes. Then put all batteries and power cable in. Then put to vcr position. The tape was pulled in and was fine. Fixed issue.
Popular Solutions for Canon Optura 60 Mini DV
Questions and Unsolved Problems for Canon Optura 60 Mini DV
Do you recommend Canon Optura 60 Mini DV Digital Camcorder?
Answer
Answer
Accidently spilled tea on camera and dried it out. Now everything appears to work except the... (More)
Answer
how do you pause recording and then start recording again in the same shot
Answer
My Optura 60cannot communicate to my PC. I dont have the original discs but the original programs... (More)
Answer
Canon Optura 60 will not turn on. No lights, not even when plugged in. It will not even power up.... (More)
Answer
We have tried different batteries and plugging the camera into an external power source but it won't... (More)
Describe your Camcorders problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Camcorder Experts
Top Camera & Camcorder Repairmen
in Baltimore, MD
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
