Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Water gush in power drawer
Water started gushing out of the door and the washing powder drawer. however the machine keeping going on till washing it done
  • suzanq Nov 11, 2008
    'This sits in the rubber pipe between the drum and the pump.' Does that mean I have to remove the cover ? and if yes ? which cover should I remove. Anyone can help with a blondie step by step please ? :)
When water comes out of the powder drawer on spin I think you will finf that the filter is blocked. This sits in the rubber pipe between the drum and the pump. I had the same problem and a half hour with the back off fixed it. A colour catcher was blocking the filter.
Posted on Oct 23, 2008
  • 594 Answers
You have a seal that is not working right for one. and 2 you have a water pump that is not working. because it is not limiting the water supply.
Posted on Aug 26, 2008
Water leaking from detergent drawer Hotpoint WMD 962
what is your model number is then we can get started then okay
Feb 04, 2013 | Hotpoint Washing Machines
When machine spins after wash water gushes out of detergent drawer. Checked black hose from drum and found a blockage of colour catcher sheet thought this was the problem but water is still gushing out the...
Hi.
The problem can be a defective pressure switch. The pressure switch detects water level. Pressure switch not working correctly may result in overfill. Try cleaning the rubber hose connected to the pressure switch. Check also pressure from inlet hose and look for blockage in detergent drawer.
Aug 18, 2011 | Hotpoint Ultima WF860 Front Load Washer
Zanusssi wjs1265 washing machine leaking
Hi, Well this is quite a common problem which can be caused by so many different things. Did you change washing powder or liquid? Was there loads of bubbles in the machine? If no to these then uplug the machine and tip it backwards so you can gain access to the underneath! Look at the motor! And on the rear of the motor there is a magnet which is a taco for the speed of the motor! These sometimes fall off causing the machine to wash at spin speed in short bursts! Have a look at this and get back to me with your findings.....
Jan 02, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Hotpoint WD71 washer/dryer
Hello farijl,
Welcome to Fixya,
You said, Water gushing from powder dispenser drawer. I have been told to take out drawer and put to one side. Looking into drawer space at back on right hand side there is a hole to be unlocked. It is so scaled up I cannot see hole. Can you help me or do you have an illustration fo what I am supposed to be looking at and unblocking ? Hope you can help soon. Floor is flooding every wash and cannot afford to get man out.
I found what you are looking for!
Below I will post the site for your WD71 User guide.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/531INST_016437770-02_WD71.pdf
If you scroll down to page 5 it will show you what and how to remove the transit brackets.
the dispenser drawer info is on pages 19 and 20.
My first post was incorrect about the bolt.
The American washers us a bolt!
Sorry.
You should be fine now and able to remedy this by your self
Let me know if you have any other questions.
Huuum
Please remember to leave a rating
Thank You
The detergent dispenser
will not close properly or is
collecting water?
1. Check the drawer is properly aligned.
2. Clean the dispenser drawer (see Care and Maintenance).
Oct 17, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
in this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
Jul 29, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Water leaking out through powder drawer
please take your drawer out and give a good clean also look inside when drawer is out and clean there as well good luck regards jason
Jun 13, 2008 | Indesit W 123 Front Load Washer
you have a blocked filter, unplug from mains, take off back panel you will see a black sump hose coming from the tub to the pump, tilt the machine forward and put a dish or bowl under sump unscrew clamp and pull off slowly to release any water in the drum. You will find a blockage, also what appears to be a ping pong ball dont throw away it is meant to be there.
Mar 06, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
192 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
