Question about Danby Heating & Cooling
Need to find fan for AC# DVAC10038EE. Hi, need to find this fan for my new AC, was busted while trying to make hole in bottom as too much water accumulated. Any idea where this item could be purchased? ASAP....! Thanks. Frank
  • chaillet Aug 26, 2008
    The fan itself (blade assy) was damaged, the motor is OK. Never found the drain or drain plugs on bottom panel, the fan was spinning IN accumulated water and was splashing everywere. The air con had an even more aggressive slope than recommended in install instr.
    So basically "made" a drain but busted the plastic fan blades in process.
    Thanks for the relpy.
    Well nub error! the blades are busted now! too late for good advise......need solution to replace fan. Any ideas? Danby has provided me with part# 201100320004 but this number is not coming up now. Got local reps looking into it for months now, still no answer, was a hot summer no air con. cauze stupidity on my part. Still hope on miracle to happen! NEED FAN! Lol thx,
Hey, I like your explaination of error. so forget plastic blades, go metal! Just take the blade down to a dealer and tell them to match you up as close as possible ,,(the #'s of blades--Pitch- slinger ring or not..and the hole diameter..--& blades diameters thats all! and tell them just get close to specs. Thank-you very-much!
Posted on Aug 26, 2008
Hey, why did you need a drain hole any way? There's a ring, on the newer type units, around the fan blade called the "slinger ring" which picks ups the water and splash it on the coils to cools the hot gases,which in turn cools the freon. The bottom of the back coils are suppose to set in water to help cools, so don't lean it too much only to keep the water flowing backward to the back coils..! If you want to ,you can cut this slinger ring off.and not hurt the blades balance! Thank you-very-much!
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Hey, sound like it as doing its job, to remove moisture ans send it to the back bottom coils ,which it suppose to cool the hot gases on the bottom run of coils then if too much water , it runs out the drain hole. You didn't say the fan blades or the fan motor?
I dont know if the water **** is bad or if there are busted hoses, but I see water squirting out of a little L shaped hose and water runs out at the bottom. If I buy a new water pump what hoses do I buy as...
Water pumps usually have a weep hole on the bottom of the snout. This is put there so when the seals go bad you will know from the water leaking out. Try to look for that weep hole and see if coolant is coming from there before spending money on a pump. If the pump does not look as if it has been leaking then maybe its just the hose.
Not knowing what Pontiac car (or Truck) you are working on and what hose specificly. When asking for the hose at the store just tell them where it goes to. Water pump bypass, water pump to intake, water pump to heater core, etc..
Aug 25, 2011 | Pontiac Grand Prix Cars & Trucks
1998 Cadillac Seville SLS with overheating problem. Head gaskets repaired!! cost me 4K, all hoses checked and look good, belts replaced etc etc. Still overheats!! The cooling system (heating/AC) is acting...
did you change your thermostats there is one on the motor and on radiator. i have a toyota and was told my motor was shot it was overheating and loosing coolant my prob was water pump and the radiator filler pipe had a pin hole in it. if you do not have water in your oil or oil in the rad then it is probabnly not the head . also if the fin on your radiator are bent you may need too change radiator..Also your radiator fan may not be working, you can hook direct or buy a new fan relay sensor that plugs in at the bottom of raiator, you can check this by getting motor hot and see if fan kicks on
Jul 23, 2011 | 1998 Cadillac DeVille
I have a haier window ac unit model hw05ca12, it doesnt appear to have a drain hole. Is this correct? Do I need to manually drill a hole in the bottom of the unit?
Hello, some window units do not have a drain hole for the condensate, instead the use the fan blade to sling the water on the condenser, since the condenser is warm/hot it will evaporate the condensate.
Jun 07, 2011 | Haier HW05CA12 Air Conditioner
Unable to locate the drainage for condensed water. I could look inside and see that water is accumulating at the bottom. Feddlers AEJ12E7AG, window unit. Thank you
Hello, most window units evaporate the condensate by having the fan blad sling the water on the condenser. Because the condenser is warm/hot it will evaporate. You shou.d be hearing a sloshing sound after the unit has benn running for a while, this indicates that the fan blade is picking up the water from the bottum of the ac.
May 31, 2011 | Fedders AEJ12E7AG Air Conditioner
I cannot get power to 19
Hi there...
First check your AC Adapter, see if it still lite green. If it not then you need a new AC Adapter. If AC Adapter still lite green, then your back light inverter are busted. It's more likely your inverter are busted... I can repaired for you... for more information @ www.3rd-Rocks.com Thanks, have a nice day!
Jan 20, 2010 | Fuji FP-988D 19" Flat Panel LCD Monitor
Kenmore AC 58067081. Have water draining out front. Think it's clogged, but where are the drain holes. Nothing in manual... I've taken off the front grill, and shop vac'd up the water sitting in the bottom...
If you can slide the unit out, there is a drain tube or drain hole from the front tray under the coil that directs the water into the rear of the unit to drain out the hole. That tube needs to be blown out or flushed. It's most likley plugged. You only need to add the drain pipe if you want to direct the drain water away from where it drips now.
Aug 23, 2009 | Heating & Cooling
It seems it's collecting water in the tray and blowing it out through the top vent, dripping from the bottom inside the house and is making a sound constantly like the fan is hitting water as it blows.
AC units do take the humidity out of the air and water collects in the bottom. The unit should be tilted slightly downward on the outside so that the water runs outrside. Make sure the drain holes are clear. The pinging noise is common, the fan is hitting drops of water, nothing to be concerned about
Aug 19, 2009 | LG Electronic Window Air Conditioner
Refilling a dell 948 color ink cart #11
Alright, I gave in and busted open my Series 11 KX703 color cartridge to figure out how to refill it. As Inksaver pointed out there are six columns which ultimately lead into three ink wells the bottom two (next to the cartridge head) are magenta, the upper right two are yellow and upper left two are cyan. Each well has one sponge in it that soaks up the ink. Each of the six columns has a hole predrilled in the center of it just below the top layer of plastic (about 5/16" from the left and right edge and 1/4" from the top and bottom and 1 3/16" (midway) from the top and bottom for the center two holes).
When I do it again (with a new cartridge since this one is busted), I'd drill three holes, one lower right and the two center holes, push the metal syringe down into the foam about midway and inject each of the foams with new blood. If someone else tries let me know how it goes. Hope this helps.
Mar 21, 2009 | Dell 948 All-In-One InkJet Printer
Leak onto floor passenger side from neck of ac drain through firewall
it sounds like your heater core is busted. you will have to go under the dash to get to it and replace with a new one
Oct 11, 2008 | 1999 Jeep Grand Cherokee
Heating & Cooling Logo
394 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
