Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
Can't connect to web configuration
Hello my router was working fine before we transfered to another house right now i cant enter the cweb confiuration utility even after reset as per dlinks advice of 10 sec press of the rest button.i it just madeits default ip adress.i cant go through after typing admin and a blank password it just says that i am unauthorized please help thanks.
    Scholar:
  • 87 Answers
There is a reset known as a 30/30/30 reset. Hold reset with power on for 30secs, unplug power while still holding reset for 30 secs, plug power in while holding reset for 30 seconds more and release, wait 30 secs or more for reboot. This should put it back to factory defaults regardless of brand. Set your IP manually on the PC to be 192.168.0.2 Open your web browser and type in the IP address of the router (192.168.0.1 by default). Enter the username (admin) and password (blank by default), and then click Ok or Log In
Posted on Oct 20, 2008
I recently got a Mac desktop and my Linksys router disk will not open up. Do I need a router that is made for Macs or is there a way to configure the Linksys?
Hi, You are correct. The CD is not compatible with Mac. What you have to do is Configuring the Router Manually using the Web Based Configuration panel.
How to:
  1. Open your Web Browser
  2. Type http://192.168.1.1 in the Address Bar and hit Enter
  3. If you have changed the address somehow you have to enter that (Router's IP - Default Gateway)
  4. Here is a small guide to Fine your routers IP address in case of that you are unable to access
  5. Enter the user name (default user name is blank- means no user name. Just leave it blank), Default password is admin.
  6. Now you can configure the Router using the Menus.
  7. Make sure that you have Saved your settings before Exit the Web Based Setup.
  8. Make sure that you have changed the Default Password.
  • If you can’t access the router’s web-based setup page, please check the following: cable connections, router’s LEDs, IP address, and connectivity.
  • Connecting Devices Together
  • Ensure that you have an Active Internet Connection and connect the modem to the router’s Internet port and the Mac to any of the four Ethernet ports.
  • Checking the Router’s LEDs
  • After connecting your modem and Mac to the router, check the lights on the front panel of the router.
  • Checking the Router’s IP Address
  • To find a Linksys router’s Local IP address, you have to check the IP settings of the Mac
  • Checking the Mac’s Connectivity with the Router
  • Ensure that the Mac is properly connected to the router.
You can download the Manuals from here to learn how to do Advanced, Customized Configurations.
Note: Please select the appropriate Hardware Version.
Thanks for contacting Fixya! Feel free to ask any questions if you face trouble with the setup. Please rate the answer as well!
Jun 22, 2010 | Linksys Wireless-G WRT54GS Router...
How do you manually connect a computer to the router? Trying different cables in port 1 but does not register to the computer. Please help!
You need to connect a standard network patch cable between port 1 and the ethernat port on your computer. To access the Web-based Utility, launch Internet Explorer, and enter the Router’s default IP address, 192.168.1.1, in the Address field. Then press Enter. This should bring up the router confiuration web page.
The password request page should appear. Leave the User Name field blank. The first time you open the Web-based Utility, use the default password admin.(You can set a new password from the Administration tab’s Management screen.) Then click the OK button.
Nov 08, 2009 | Linksys Wireless-G WRT54G Router
I have a dir 300 router that when i try to hook it up it i cant
 Let me clarify this  your internet works when your PC is hooked up directly to the modem....
When you connect the router between the pc and the modem the internet does not work....
This sounds like the configuration settings inside the router need to be setup or adjusted.
Go to the web browser and type in 192.168.0.1 and for the username type admin and then leave the password blank hit enter and it should sign you into the router. Follow the setup wizard and everything should work just fine.
Hope it Helps!
Apr 12, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Can't launch Internet
seems like there is DNS confiuration set in the wirless porperties page.
right click on the "My network Places" go to porperties. right click on the wirless connection.
go to TCP/IP under the "connection uses the following items." high lite the TCP/IP adn select the porperties box.
under hte genral tab
Obtians an IP address automatically
under alternate configuration
make sure nothing is checked. click OK and close.
try to connect again.
Oct 28, 2008 | 2wire 1800HG Router (RG1800HG00)
Belkin router and ps3
Hi Srini here ,
There could be a problem with the wireless configuration on ur belkin router.
Go ahead and type the following in the command prompt of ur computer.
ipconfig
:-This will list out the ip address and the default gateway of the computer
:-Make a note of Default Gate way.
:-Type the default gate way address in to the address bar of the internet explorer.
:-It will take u to the router configuration page.
:-it might ask u to enter router password.(Enter it)
:-In the router page u could see wireless settings options on the lefthand side of ur router confiuration page.
:-Make it appropriate accordingly
:-if u do not know what to do with wireless settings ..then send me ur product details ..will tell u further querries..
Most of the time the wireless device do not connect to router due to wrong "Wireless network key"
:Make sure you have same wireless netwrok settings in the devices as in the wireless router.
:-Send me ur product details and ur setting details like
ISP(Internet Service Provider):-
Brand Name of the modem:-
Model no. of the belkin router:-
If u would like to resolve ur problem soon then send me all details..
Apr 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Solution 1 didn't work
Your Verizon DSL modem might be set to BRIDGE MODE. Try connecting the router again. Connect your pc to your router. Access the configuration page of the router. Set the INTERNET CONNECTION TYPE to PPPOe. You need to enter on that page the USERNAME and PASSWORD for your VERIZON DSL. Hope this helps.
Good Day
Mar 12, 2008 | NetGear WGR614 Wireless Router
Netgear WGT624
Step One : plugin the router with your computer/laptop with the help of the cable. use port 1.
Step Two : open the web broweser and type http://www.routerlogin.net/ or http://192.168.1.1/.
Step Three : it would ask you for username and password. enter Username : admin and Password : password .
Step Four : Confiuring the router.
1) please avoid setup wizard and confure it manually and follow the steps below.
2) you would need to click on left frame buttons for the cnigration to come on the right side.
3) in setup section on the right side please click on basic settings and configure as below:
a) Does Your Internet Connection Require A Login?
Answer : No
b) for the next three options its the first choice should be like that from default, if not please set all to automatic.
Then,
Click "Apply"
4) On the right menu now click on wireless settings in the setup section.
a) give a SSID name that is a name you want to see when connecting to the the wireless router while connecting from a wireless device. E.g. ( "mp's netowrk",etc.)
b) set security option as WPA-PSK the third option.
give a password like "abcde12345" should be 10 charactes and alpha-numerical. ( This option is to make your Wi-Fi more secure and to avoid unauthorized access. Key lifetime : 60minutes
then click Click "Apply"
5) Now on the right menu goto advanced section below and click on Wireless Settigns.
a) Check both the options to enable both the Wireless Router Radio and SSID Broadcast.
Then Click "Apply".
Router Config Done..Now on the right side click in "Logout" (bottom most option)
after the router logout is done close the web browser and remove the network cable and the the power cable from the router.
Post Configring Steps :
a) Swich off the dsl modem.
b) plug the dsl cable to the internet jack in the router.
c) plug in the router power cable back to switch on the router.
d) Switch on the DSL Modem.
Wait for 15 Seconds.
Connect to you wireless netowrk using you laptop or wireless card in your computer and provide the WPA-PSK - TKIP passord which you had given in router for preventing unauhorized access.
Bingo !! you are connected...and more secure.
Mar 10, 2008 | NetGear WGR614 Wireless Router
Psp
You would need to configure your netgear router to accpect trasfers from a multimedia device like psp. and also psp can only support only WPA-PSK (TKIP) Encryption.
Please Follow the below steps to do the same.(please perform the steps in a already connected device like a laptop or a desktop using a Wi-Fi Card.
Step One: open the web browser in your computerthe laand type http://www.routerlogin.net/ or http://192.168.1.1/.
Step Five: it would ask you for username and password. enter Username : admin and Password : password .
Step Six : Confiuring the router.
2) you would need to click on left frame buttons for the confgration to come on the right side.
3) On the right menu now click on wireless settings in the setup section.
a) set security option as WPA-PSK the third option.
5) Now on the right menu goto advanced tab and click on UPnP(Universal Plug and Play Devices)
a) Check on Turn UPnP On.
Then Click "Apply".
Connect to you wireless netowrk using you psp and provide the WPA-PSK - TKIP passord which you had given in router for preventing unauhorized access.
Feb 25, 2008 | NetGear WGR614 Wireless Router
Actiontec GT704-WG wireless connection not working
you say it suddenly stopped working, if you can connect to the router via ethernet cable then try to access the router's web utility page and make sure your router is in mixed or G-only. If you can't still connect to the router through wireless then try restarting the Wireless Zero Configuration from windows. This is how it's made: Go to control panel and double-click "administrative tools", then double-click "services". You will see a list, scroll down to Wireless Zero Configuration and click "stop", you'll see a progress bar. After that click "start", you'll see another progress bar. Now try connecting to your router via wireless connection. If you still can't connect then repair the connection by right-clicking the wireless icon at the bottom right corner. Keep repairing until you connect.
Hope this works!
Feb 16, 2008 | Actiontec GT704WG Wireless Router...
Cable router
Make sure that you have followed the router manufacturer's instructions to configure the router to work with Virgin. Typically this would include entering your Virgin username and password into the connection section of the router's configuration menus.
Sep 23, 2007 | Belkin 4 ft. Modem Cable (F3N501-06-BLK)
Open Questions:
See all D-Link DI-604 4-Port Cable/DSL Router (DI-604) Questions
D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
523 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
