Question about Sony Ericsson W850i Cellular Phone
W850i - fitting new glass screen cover?
Hi - any ideas on how to fit a replacement "glass" screen to a W850i? I have a new panel but it doesn't seem to have any obvious clips so how do I get out the old cracked glass from the phone and fit the new one? Many thanks, Paul
  • pchad Sep 06, 2008
    Bajanguru - may thanks - took a good bit of leverage (and bravery!) to overcome the sticky tape holding the screen cover in place, but your advice worked. My son thinks I'm a legend! Thanks again, Paul
    Brigadier General:
  • 7,752 Answers
All you need to do is use ur finger nail and pruy against the line of the cover and it will come up
Posted on Sep 06, 2008
Tv screen broken
If the protection glass in front of the TV only have borken, it can be replaced. If the screen as a whole has broken, there is no other way than replace the screen, which will cost around 2/3rd of the total cost of a new TV. Check this link for details. It has disassemble procedure to many brand Plasma TVs, with illustrations. You can get an idea about how the screen is fitted, and what is the protection glass and actual plasma screen. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 03, 2013 | Samsung 43 PN43D450A2D Plasma TV
Is their anyway you could fix a 47LGLM6700
Unfortunately no, you would need to replace the internal panel on the TV and honestly the labor and part would cost more then just buying a new set in most cases. If the screen has a glass cover and just the glass is cracked but the rest of the picture looks fine (no distortion in the LCD) then you could just remove the glass and run the screen unprotected or copy the dimensions of the glass/plastic and send it away to have a new sheet made to fit.
Apr 07, 2013 | LG 47LM6700
I have a Samsung HCL5515w the protective screen has a crack in it. I dont really want to spent $300 on a new one. Can i replace it with regular glass or leave it off all together?
We do not do projection TVs, but I have a good understanding of how they work and there's no risk - if anything - if you use a glass replacement.
it may not be a good idea simply because the glass used for TV shielding is specially designed to not reflect as much as regular glass, it is usually harder (tempered) etc., but as far as health or other similar concerns - you can probably go with any glass you can fit there or no glass at all.
Plasma TVs are more special in this regard and shouldn't be used without the front protectve glass.
See http://blog.coppelltvrepair.com/2012/08/how-to-fix-cracked-or-scratched-glass.html .
Oct 02, 2012 | Televison & Video
Hello my name is john I have a 47'' philips LCD tv the screen got broke it works find on pic what new panels will fit it 707 490 5318 john
John, my recommendation is for a new set. The glass is bonded to the LCD with expensive and toxic materials and with a sophisticated process. The cost for glass to fit your set would also be extremely expensive and usually not worth the hassle.
Feb 28, 2011 | Philips Televison & Video
Sony ericsson w850i problem white screen not open
Hi if your phones screen is white then this is a sign that the ribbon that takes data from the circuit board has become damaged. what happens is that when the phone has been opened and closed load of times the little copper wires that run inside the ribbon become brittle and break, the only option you have of solving this problem is to get the ribbon replaced.
its not expensive to buy and wont cost much to fit.
their is no easy fix as it is a case of getting new parts fitted to your phone.
let me know how you get on or if you need further assistance ok
Jun 13, 2010 | Sony Ericsson W850i Cellular Phone
I want to change a lcd screen cover,not lcd sreen only top glass cover.
ya u dont need to change it
get a screen cover breezeing it cost only 150rs
or else get a new body it will cost 300
Jun 12, 2010 | Sony Ericsson W850i Cellular Phone
The rain cover on my quinny buzz fits ok when the seat is facing me. but when the seat faces forward the rain cover just seems to not fit..
Hi check them out on ebay maybe you are fitting it incorrectly, or you have the wrong cover. They have pictures of them on some listings this may give you an idea to what is wrong.
Oct 23, 2008 | Quinny Buzz Jogger
Cannot re-fit middle glasss into main oven door
this is a new one too me but ill give a shot
ive never seen an over where the supports were all intack
they should be screwed in at least to of them by what i call the hidden screw or plug either the 2 bottom come out or the 2 top ones come out to where the glass slides into position and just put the supports back into place
i was reading reviews on this particular item and clearly by what there describing this is not a very good functioning machine all out of tune from the older style
May 09, 2008 | Neff U1661 Double circotherm super...
Zune 80gb 2nd Gen...Broken outer screen.
Try PDASmart.com. The glass on my zune 80gb just broke as well, and this is the only place that offers a replacement.
http://www.pdasmart.com/zune-screen-center.htm
Apr 23, 2008 | Audio Players & Recorders
The lens is scratched
hi
try this site it has a removel guide on how to do this K850i disassembly
take care when do this.
riz.
Feb 13, 2008 | Sony Ericsson W850i Cellular Phone
Sony Ericsson W850i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
