Question about Canon Optura 500 Mini DV Digital Camcorder
White Balance What is the white balance and how can I change it?
    Sergeant:
  • 255 Answers
What is White Balance? The human eye captures white as white, red as red and blue as blue, regardless of whether you are outside under the sun or inside under incandescent lighting. Although this is something that we take for granted, the human eye actually adapts to correct the changes in color under different light sources. In reality, when light sources vary, colors caught as the reflection of those light sources also vary. For instance, films for cameras that use film are designed to capture the most appropriate coloring outside under the sun. Thus when you take pictures under incandescent or fluorescent lighting without using a flash, the colors in the resulting picture may seem strange. Digital camera and digital camcorders are equipped with a handy feature called "White Balance" that corrects the changes in color under different light sources, just like the human eye. One of the white balance settings, "Auto White Balance" (AWB) automatically adjusts to correct the changes in color under different light sources. White Balance and Coloring The White Balance feature on Canon digital cameras and camcorders is set to "Auto White Balance" at the time of purchase. If you prefer different coloring, if you want to adjust the coloring more in detail, or if you want to change the coloring on purpose, we recommend that you change the white balance setting.
Posted on Sep 04, 2005
Streamed programs vary brightness
cameras have a automatic white balance so if you move the camera it changes the white balance varing the brightness if white balance is put in manual and a white sheet of paper is put around six inches from the lens and whit balance set it will not vary as long as the lighting is constant
Dec 13, 2012 | Televison & Video
Tip
SERVICE MODE POWER SUPPLY AND INVERTEE CIRCUIT
White balance adjustment
Pre-adjustment
The set should be working for over 30 minutes before white balance adjustment so that it can be in a stable state. Use white balance apparatus CA210 and change to BBY channel to adjust white balance; Only need to adjust chromaticity coordinates when color temperature is 10000K (namely "COOL") for the unit. To meet testing requirements of BBY when color temperature is 8000K or 6500K, make sure chromaticity coordinates of bright scale is X=280 ± 5 Y=288 ± 5, chromaticity coordinates of dark scale is X=280± 8 Y=288± 8; Manual adjustment of both groups of white balance datum YPbPr white balance adjustment.
FOR MORE CHECK
Electronics Equipment Repair Center
on Feb 14, 2015 | Insignia Televison & Video
My d300 has a blueish contrast in all non flash shots Can't get normal color
Here are the possible causes and the solutions for each:
Cause 1: The most common cause of the tint in the images is White Balance. It is possible that you have set the wrong White Balance. Since you are getting a blue tint, you might have set the white balance to 'Incandescent' (Tungsten) or 'Flash'. Changing the white balance to Auto. Most White Balance problems get eliminated by this. For this, press WB on the mode dial and use the command dial to change the values.
Cause 2: The unwanted casts could also be due to the in-camera processing. To check this, Select 'Set Picture Controls' from the Shooting menu. From the four options, select one that gives the minimum processing-- that is, either Neutral (which gives minimal processing) or Standard (It gives slight enhancements, but the tones will be balanced).
Cause 3: It is also possible that the White Balance of your camera has been tweaked. So if the above steps do not solve the issue, try tweaking the white balance to your liking. For this, press WB and use the sub command dial (the dial in front of the camera near the Shutter Release button). Check the result each time you change the value until you are satisfied with the result. As a guide, the ideal values of different settings are: Daylight (direct sunlight): 5200; Incandescent: 3000; Flash: 5400; Cloudy: 6000; Shade: 8000 etc...
Aug 26, 2010 | Nikon D300 Digital Camera with 18-200mm...
White Balance
You can change the white balance in the "shooting menu".
Nov 11, 2009 | Cameras
White balance on D50 set correctly?
Are you saying that you're using a white background but it doesn't appear white in the pictures? If so, then yes, you need to change the white balance to match the light. Probably "tungsten" but you could try different settings and pick the one you like best or you could use a white piece of paper and set a manual white balance.
Oct 24, 2009 | Nikon D50 Digital Camera
How to change white balance
The white balance command is in the Capture menu. The instructions are on pages 27 and 28 of the manual.
Sep 24, 2009 | Polaroid T831 Digital Camera
XT problem with white balance/aperture
You should be able to set your white balance by taking a photograph of something white filling the screen with the correct exposure. If it is underexposed, you will not get white, it will look yellowish. Make sure while you are photographing the object, you switch your lens focus mode to manual.
Go the second setup (tools) tab and select custom wb. The custom white balance screen will appear and you will choose the image that you want to base the white balance off of by pressing the set button.
This will take you back to the menu. Go back to white balance and choose custom wb down in the bottom right corner of the screen.
Hope this helps!
Jun 04, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Panasonic M3500 VHS Video Camera
to go to the last preset white balance after turning of and on the cam , you should just click (but not hold ) on the whit balance switch but you have to select manual first , and if you want to set white balance then you should hold on the white balance switch for more than 4 seconds regards
Jan 20, 2007 | Panasonic NV-M3500EN Camcorder
White Balance
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Balance Function
This function is useful when you need more precise white balance than the Preset White Balance can provide. To set the optimum white balance for the shooting conditions, point the camera at a white object under the light source that you want to use, and press the OK button to set the white balance.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Canon Optura 500 Mini DV Digital Camcorder Logo
275 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
