Question about Canon Optura 500 Mini DV Digital Camcorder
Lines in replay
Images appear in horizontal lines or mosaic during replay. What can I do?
This is also caused due to mis-aligned heads. They can be adjusted by your service centre to correctly read the damaged DV cassette.
Posted on Apr 14, 2007
I have a Canon ZR80. It worked okay for the first three years, though I used it maybe 10 hours a year. In the third year, high temp and humidity (90+F, 99% relative humidity) caused the CCD to fail. This is a product-wide mass defect, Canon repaired it for free. Next problem, the so-called "mosaic" or "checkerboard" or "partial recording" problem. This maybe occurred from dropping it or knocking it over. Researching it on the InterNet I saw this is common and fresh tapes and tape-head cleaning is recommended. None of that worked. Canon told me, when I contacted them, that I should send in the camera for repairs and they'd contact me about the estimated cost. I have read that usually it costs so much you might as well buy a new camera. I decided to try fixing it myself. First I removed all screws on the exterior, this required a very small jeweler's screwdriver. Removed the battery, left the tape drive bay open while doing this. DO NOT fully disassemble, remove case components only! After removal of case components, the drive controller board is located in the center of the unit, beneath where the LCD/Control unit was. The controller board has many very small ribbon connectors. After pressing all of these on tightly, I loaded a tape and battery. Test recording worked perfectly for several repeats. I reassembled the case components. It still works! If you are good with your hands and have good tools, and were about to dispose of the unit, try this repair first. It took me about an hour, and required only steady hands, a tiny screwdriver, good lighting, and lots of patience. It's less expensive than paying Canon, and it's better than throwing it away without trying to fix it. Best of luck! --thardman at thomashardman dot com
Posted on Apr 10, 2007
    Sergeant:
  • 255 Answers
Digital video camcorder are recording signals in very thin line (as thin as 1/8 of a hair.) Therefore, following symptoms may appear if video heads become dirty even a little. If such symptoms appear, clean the video heads with a commercially available dry cleaning cassette. If the symptoms reappear shortly after cleaning, the video cassette may be defective. Stop using the cassette. Video heads may become dirty under the following conditions: (1) When using the camcorder in humid or hot places. (2) When using cassette with damaged or dirty tape. (3) When using the camcorder in dusty places. (4) When using the video heads without cleaning them for a long time. Note: Before you make important recording, clean the video heads and make a test recording first. I also recommend cleaning the video heads after use before storing the camcorder.
Posted on Sep 04, 2005
3 Suggested Answers
SOURCE:
Fishi
  • 255 Answers
SOURCE: Dirty Replay
Digital video camcorder are recording signals in very thin line (as thin as 1/8 of a hair.) Therefore, following symptoms may appear if video heads become dirty even a little. If such symptoms appear, clean the video heads with a commercially available dry cleaning cassette. If the symptoms reappear shortly after cleaning, the video cassette may be defective. Stop using the cassette. Video heads may become dirty under the following conditions: (1) When using the camcorder in humid or hot places. (2) When using cassette with damaged or dirty tape. (3) When using the camcorder in dusty places. (4) When using the video heads without cleaning them for a long time. Note: Before you make important recording, clean the video heads and make a test recording first. We also recommend cleaning the video heads after use before storing the camcorder.
Fishi
  • 255 Answers
SOURCE: Lines in replay
Horizontal lines appear in newly saved images
the only thing i can think of is the sensor being misconnected or kaput. are you viewing them on the camera screen or a pc? it could also be camara screen...
Jul 05, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
HORIZONTAL LINES APPEAR IN LCD EVEN AFTER TAKING PICTURES IN IAUT
Case 1: if these lines appear only on cam lcd and not on pics if u see them on pc then ur LCD is faulty get it replaced under warranty
Case 2: if all pics have horizontal lines on them if u see them on computer then it is a BAD CCD see the link below to confirm u can still get it repaired free under warranty if u dont have warranty they will still do it free of cost i am sure it is a manufac fault hope it helps u
http://www.imaging-resource.com/badccds.html
pls rate me FIXYA for diagnosis dont waste time run for warranty claim or tell me i can get help for u and guide u where to go tell me ur region !!
Mar 31, 2009 | Cameras
Horizontal line in images
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
May 25, 2008 | Canon PowerShot A85 Digital Camera
Horizontal red lines when printing
Horizontal line is carriage axis , while moving its may give line if some dust or resdual ink may be on he carriage base
clean the caping station and cleaning wiper ( place where carriage rests )
if its not resolved please update sample images for same
May 24, 2008 | HP Officejet 6310 All-In-One InkJet...
Horizontal lines on image
This is not a solution , but only a work around. If you do at least 1/3 zoom on your lens before clicking a photo, these lines will not appear. But this not not a convenient way I agree.
Also this surely means that the CCD is not the problem otherwise it would have never worked ( electronic parts cant simply dont start to work when you zoom ringht ? ). Surely Nikon is fixing the issue, but cheating the customers by charging for a part is not defective in the first place
Nov 22, 2007 | Nikon Coolpix 8700 Digital Camera
Taken pictures appear with horizontal lines
I have the same problem, this is my second cannon sent to me from them!
Nov 16, 2007 | Canon PowerShot A430 Digital Camera
Lines appearing on camera and images
Chwck the Samsung website -technical Support team -especially if this is a recent purchase. But generally speaking this is a no repair situation.
Jun 11, 2007 | Samsung Digimax V50 Digital Camera
Horizontal Lines
your camera needs repairs as the auto apparture system is not working.
Nov 02, 2006 | Canon PowerShot S500 IXUS 500 Digital...
Lines in replay
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Dirty Replay
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Canon Optura 500 Mini DV Digital Camcorder Logo
221 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
