Question about Apple MacBook Mac Notebook
Error -61 I use a 250 GB LaCie disk drive, connected with a Fire Wire. The other day it was accidentally disconnected before I was able to eject the CD, now whenever I connect it, I get a message saying that my computer was unable to repair the disk. I can't change anything about the disk, and every time I try to delete something, I get error code -61. I ran Disk Utility and I get this message "Filesystem verify or repair failed". What should i do next?
  • ryel Dec 10, 2008
    I'm having the same problem. Is there anyway to salvage the Lacie? Or should I cut my loses and purchase a new external drive?
    Novelist:
    Champion:
  • 382 Answers
First off, anything LACIE is bottom of the barrel. Don't take it personal, but if i have a nickel for every Lacie D2 drive I've had to recover...oh wait, sometime i got more than what people paid for them to recover what was on them........think about it for a second. Error -61 is a bad master directory block. The drive has a directory, like any book or "volume". It's where the drive stores the information based on the location of content on the drive. Which means your drive will fail soon because it will not be able to retrieve what you are putting on it, because it is internally failing.
Posted on Sep 01, 2008
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Lacie do not start
If it still is under warranty, then exercise the warranty, and get it repaired/replaced.
If it's out-of-warranty, then disassemble the case, and disconnect the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if the disk-drive still works.
If it's dead, it's dead, unless you pay mega-dollars to a professional "Data Recovery Service" to rescue your files.
If it is dead, then buy another disk-drive that is compatible with that USB-to-disk-drive adapter, and reassemble the unit, and you'll have a brand-new external drive that you can use.
May 29, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Keep Losing Connection
try replacing the cable to it - ive notice once that is done dos not disconnect
Dec 31, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Lacie Desktop Hard Disk beeps when connected
No much help I can give, when an hard drive beeps it has motor error or head error, the disk hardwar is faulty, and you are not able to recover anything from the disk.
A safe data recovery can only be performed by specialized companies on a facility called clean room, where dust is completely removed from the room using a vacuum.
The data recovery using this kind of equipment does not cost less than $800.
Nov 23, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Drive is not ready-error message when i connect Lacie 320gb
Check BIOS for detection of hard disk and if detected operating system may need driver or corrupt
Apr 13, 2008 | Computers & Internet
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
Lacie 250 gb gives error while accessing some folders
I took mine to a place to get it fixed and they said it was beyond repair and the only option is to recover the data and transfer it onto another disk
Jan 18, 2008 | LaCie (300728U) 250 GB Hard Drive
160 Gig Lacie Design By F A Porsche Fire Wire HDD Bad Fire Wire connection
You might try going to the manufacturers website and request a new one from them.
Mar 09, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Help
Take it in, controller may have malf'ed when it got unplugged, been known to happen.
Dec 25, 2006 | LaCie (300728U) 250 GB Hard Drive
Apple MacBook Mac Notebook Logo
973 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
