Question about Linksys Wireless-G WRT54GS Router (e125894)
Router just doesn't work?
Hey. I have a ($40) Linksys Wireless-G WRT54G version 8.2. When I connect to it with my laptop the network map shows that it's connected to the router but the router isn't connected to the internet. I came over to it to check but it said it was connected to the internet. After the it stopped sending the internet connection to the PC. After I took the router out the PC internet worked fine. I'm not sure if this is related, but when i first got on my PC I went to the Linksys software that came with the router. It said that a different router was plugged in, but it was the same router that I had set it up with. Any help? How long is the warranty?
  • 63 Answers
If the computer works fine when directly connected to the modem, it means to say that your ISP is able to provide you a connection. You might have to access the page of the router via internet explorer (192.168.1.1) and double-check the settings. Check the status tab of the router and see if the router is able to get an IP address from the modem.
Thanks!
Posted on Aug 26, 2008
Network Connections can't find my wireless network
Pull the Linksy out of the console of your computer then re-install it. You may need to press and hold down your router for 30 seconds and then re-press.
Jun 29, 2017 | Linksys Wireless-G WRT54G Router
Will setting up a wireless laptop on Linksys WRT54g router mess with 3 computer ethernet wired connections ? I want to set my lap top to WPA2. Right now it's at WEP:(
it all depends on the win version you have.
Please go here (http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G) and hopefully it will have the answer you are looking for.
Obviously you know how to set up your router, since you already have three computers hooked up.
I have many wireless/wired pc's and wireless/wired mac's on the same router, with no problem at all.
Many routers can handle upwards of 30-40 connections without a problem and high quality ones can handle 254 (that's the max for a class C subnet).
Good luck
Dec 14, 2010 | Linksys Wireless-G WRT54G Router
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Wireless connection
Possible you did reset the router. Its okay to connect to that linksys network name. But if you want to customize you network name.
MAKE SURE TO USE THE WIRED COMPUTER TO SETUP WIRELESS CONNECTION.
Example : The Desktop computer that is connected to directly to router.
Just follow the steps.
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3967&p_created=1159257209&p_sid=aNKUFggj&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODExJnBfcHJvZHM9MCZwX2NhdHM9MTcyMSwxNzIzJnBfcHY9JnBfY3Y9Mi4xNzIzJnBfc2NmX2xhbmc9MSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PUNoYW5nZSBTU0lE&p_li=&p_topview=1
Hope it will work..
Oct 14, 2008 | Linksys Wireless-G WRT54G Router
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Lost connection on laptop
I would reset the router most of those linksys will have a small hole in the back of them that say reset push it and let it go back to factory default see it that does not fix your prob
May 10, 2008 | Linksys Wireless-G WRT54G Router
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
