Question about Singer 6038 Mechanical Sewing Machine
Cotton snapping When using the machine the top thread breaks as i am sewing. It works for a minute or so and then snaps. Do i have my tension set to high?
Not trying to be a "know it all" I swear , but have you tried either loosening up the tension just a pinch ? and or , (speaking from experiences w/ the same machine) a bigger needle or try "driving " a little slower , I am a sewing leadfoot and sometimes the combination of some or all of these results in a most not cool breaking/ curling snarling shredding of the thread ! hope this either helps or makes you laugh !
Posted on Sep 23, 2008
The top cotton keep on snapping when I am sewing also the top cotton make a loop I tried adjusting the top tension but problem is not solve.
http://www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine
this explains tension and how to fix the problem if it is a tension problem.
Are you sewing through an abrasive fabric or anything sticky. This has been my latest reason for top thread breaking.
Apr 19, 2014 | Sewing Machines
My top thread keeps snapping on my consew 118. There are loops on the underside when I stitch with it and the thread keeps snapping at the needle. It is threaded right but it keeps happening literally...
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Thread looping on the bottom of your fabric can be caused by little or no top tension or too much bobbin tension. Another cause is thread or lint caught in the top tension.
Make sure the thread is between the tension discs and that no thread or lint is caught
Apr 09, 2013 | Sewing Machines
Singer featherweight 11 cotton keeps breaking
Jan 28, 2013 | Singer Featherweight II 117
Cotton is bunching up on the bottom of the fabric and then it snaps
Do you happen to have your feed dogs lowered? Tighten the top tension a bit and make sure you are holding both threads when you start a seam.
Also make sure you have recovered all needle pieces.
Dec 11, 2012 | Sewing Machines
Overlocker cotton onleft needle snaps
1. Try rethreading the machine
2. Is the needle inserted correctly
3. Is the needle bent
4.is the tension adjusted correctly
5.is the tension adjusted to accommodate the thickness
Of the thread being used
6.is the thread good quality thread
7.is the thread feeding off the cone or spool freely
8.is the needle size correct for the type of fabric being used
Oct 10, 2012 | Sewing Machines
I have a brother vx-1125 the cotton keeps snapping..but the tension is correct..please advise..
The needle thread breaks
Aug 17, 2012 | Janome Sewing Machines
Top thread keeps snapping on consew 230b
Top thread snapping. Do you have an idea of there it is breaking?
First I would check the needle throat plate and needle. If you have stab marks on your needle plate, examine it closely for a crack. (get out the magnifying glass or jewelers loop) I recently fixed a problem I had with an old singer that kept breaking the top thread by replacing the needle plate. The old needle plate was so damaged it had actually made a knife edge which consistently cut the thread right at that location.
Change your needle and make sure it is the proper size for your thread. Too narrow of an eye can shred the thread causing it to break.
Next, check anything along your threading process that could be catching or snagging the thread. A worn or chipped thread guide can be a real problem.
Also make sure your thread hasn't dropped down below your thread cones and wrapped around the thread spindle. This would cause extra tension that might not be readily apparent.
Good luck
Aug 15, 2012 | Consew Sewing Machines
When I start to sew, the top thread breaks, before it makes a stitch.
obviously you've slackened off the tension so thats not the problem, try changing the neddle as some times they get a sharpe edge that cutts the cotton as soon as tension is applied, if the needle passes through the plate before it snaps the timing may be off.
Aug 23, 2009 | Sewing Machines
Top thread breaking during sewing.
your needle needs to be replaced and make sure it is in correctly..if this does not work you will need to make sure your thread is not old. then adjust you bobbin tension...there are 2 tensions on machine top and bobbin
May 22, 2009 | Janome Memory Craft 9000 Computerized...
Singer 6038 Mechanical Sewing Machine Logo
116 people viewed this question
Top Singer Sewing Machines Experts
Bargain Box
Bargain Box
Mike Cairns
Mike Cairns
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
