Question about AEG Washing Machines
Replace drain pump on aeg 6350 - AEG Washing Machines
  • cleveleydog Aug 26, 2008
    i assume you need to replace via the fron of the unit. this requires the the seal on the door to be removed the rest looks straight forward. i have all ready removed the door lock
  • 639 Answers
Dear CLEVELEYDOG,
ngfam1 here for you!
I am happy to be of assistance!
IF YOU HAVE NEVER DONE THIS BEFORE YOU MAY FIND A PROBLEM!
Procrastinating and trying to figure out why, may cost you more in the long run due to continued damage!
I believe you should use service for this particular situation!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF
Posted on Aug 26, 2008
  • Neil
    Neil Aug 26, 2008
    Well good luck!
    You heard my opinion.
    But if you insist on trying your self!
I have an AEG F55002ViOP dishwasher. It's making a strange grinding sound and showing error code 30. Can anyone advise how to solve this please.
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
The noise what you heard during operation indicates that something is blocking the drain pump.
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage then check why the drain pump makes noise.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Good luck.
Dado
Oct 11, 2014 | AEG Dishwashers
Error c3
http://www.aeg.co.uk/Support/Troubleshooter/?Command=Detail&CatId=98&SymptomId=1412&DetailId=1412shows AEG's meaning for a C3 error code
Feb 06, 2013 | AEG Washing Machines
Frigidaire washer fafs4272la0 fault code f21
1. Check the drain hose for restrictions. Restriction, correct problem. No restriction, go to step (2). 2. Start the washer and check for 120VAC at the drain pump. Zero, replace the Main Control Board. 120VAC, remove the pump and check it for blockage. If blocked, remove the restriction, if not, replace the pump.
Aug 28, 2012 | AEG Washing Machines
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
Aug 06, 2010 | AEG Washing Machines
Aeg 72630 won't spin
most likeley cause are worn out carbon brushes in the main motor. have you seen any error codes e52 relates to the motor brush problem. e20 is inefficent draining caused by blockage in the pump chamber acces in the plinth area/ or in hoses or drain connection
Jul 21, 2010 | AEG Washing Machines
AEG 74630 washing Machine stopped working, will not spin or complete cycle, have manually drained and checked for blocks in pump but seem OK
I have same problem right now. The machine works fine up to the stage where it needs to pump out. the pump was dead. Have replaced the pump, but still not working and it's probably the PCB that needs replacing - expensive but will buy reconditioned for about £50.
Pump available for the machine on Ebay and easy to replace. Take of machine back panel - make sure machine off and unplugged. Pump has 3 screws holding it in - then just replace. Easy. Good luck
Jan 08, 2010 | AEG Lavamat 72640 Front Load Washer
Dear ladies and gentlemen, our problem is, that we have a full mashine stopp with e20 accuring on the led before the detenser enters the toumble. our mashine is an aeg 16809 e20 thanks for your fast reply
You've answered your own question. E20 is a draining failure. Blockage in the sump hose, pump, drain hose or faulty pump. Clear the blockage or replace the pump if faulty and you'll clear the fault.
May 16, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
AEG Favorit 420 Freestanding dishwasher
i have 4220 and i replaced the drain pump, fixed, located underneath to right at the front
Dec 26, 2007 | AEG 24 in. Favorit 40310 Free-standing...
Washing Machines Logo
80 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
