Question about Canon GL2 Mini DV Digital Camcorder
Cassette Jam How to get the videocassette out when the cassette compartment will not open?
    Sergeant:
  • 255 Answers
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds.
Posted on Sep 04, 2005
4 Suggested Answers
Fishi
  • 255 Answers
SOURCE: Cassette Jam
Fishi
  • 255 Answers
I had this problem, and here is how it was resolved.
My cassette would not pop out when I opened the door with the camera turned on. When I turned off the camera and opened the door, it slid out much further, but still failed to pop open so that I could remove the tape. Then it slid back in.
Remove the battery, and have the camera off, but make sure the power cord is connected. Open the door until the tape slides out further than at other times. (Note: It intermittently slides out further when the camera is off. Sometimes it will not slide out any further than when it is on.) When the tape is slid out as far as it will go, quickly remove the power cord. The tape will stay in the slid-out position. Now, at the bottom side of the tape door there is a curved channel for a small pin to slide in. This channel has a 90% curve at the bottom of the channel to catch the pin, which holds the door closed. Push that pin back a little (toward the lense) to get it to go around that 90% curve, and the door will pop open so you can remove your tape. The ribbon of your tape will be jammed in the camera a little, so you will have to be careful and move the ribbon around a little until you can get it out freely.
This worked for me twice. I did not try putting a tape in again.
I hope this helps.
Posted on Oct 23, 2007
Please describe your cannon laserbase 5630 showing paper check error after printing one print problem:
Hi mani4u58,
After the print,does the alarm indicator show?
Are the papers loaded and aligned in the correct way in the printers cassette?Please align them well and also note that the cassette can hold only around 250 sheets at a go.Remove the cassette completely when loading the papers and after paper load,insert the cassette as far as it can go.Does the printer feed paper correctly?If not,there may be a paper jam.To clear the jam,open the front cover by pulling it towards you.Remove the cartridge and inspect the compartment.Also make sure the orange adhesive tape around the cartridge is full removed to free its connections.You can also unplug the printer and leave it for a while and then plug it back to clear jam.
Hope it helps.Thanks!
Mar 27, 2011 | Office Equipment & Supplies
I have an Elura 90. The cassette door opens but
When ejecting the tape you must hold the eject switch down for a full second. There are two stages to the eject process just as there are with the insertion of a videocassette. Hold the button in position long enough to hear the motor mechanism start.
Oct 30, 2009 | Canon Elura 90 Mini DV Digital Camcorder
I haven't used my VM-E2 in several years. During that time it was in storage with a cassette time inside. I recently tried to use the camera and ''E'' kept flashing. I rejected the cassette and checked...
The manual says that when E is flashing to "Unload the videocassette once. Confirm that there is no problem with the tape (tape tension for example), then reload the videocassette and try to resume. I would suggest reloading a different tape. I have the same camera but am missing the RF adapter that plugs into the side. If you cannot get your camera to work, are you open to selling me the adpater?
Oct 27, 2009 | Canon Video Cameras
8mm Cassette mechanism fails to eject or sometimes fails to close
This camcorder is at least six years old now, and replacements are available quite cheaply vie on-line auction sites, probably at far less than the cost of repair.
Apr 05, 2017 | Sharp Viewcam VL-AH60U Hi-8 Analog...
Cassette compartment cover blocked
have you try to open it and see for any loose spring parts.?
thanks
Apr 23, 2008 | Cameras
Videocassette stuck in Panasonic NV-G50 VHS VCR; can't eject
Generally, you have to take off the cover, and find the motor that drives the cassette loading mechanism, then turn the motor shaft with your fingers (many many times) until the cassette is unloaded.
Usually the moter is easy to get at on top just to the right of the cassette mechanism. However sometimes it is underneath and you can only get at it by taking everything apart. Don't try this yourself and don't take the cassette carraige assembly apart trying to get at the cassette unless you don't plan on using this VCR again.
Dec 25, 2007 | Televison & Video
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
Cassette Jam
Sep 04, 2005 | Canon Optura 400 Mini DV Digital Camcorder
Cassette Jam
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
Cassette am
To unload the videocassette from the cassette compartment, the camcorder needs to be connected to a power source (either an electrical outlet or a charged battery). Please refer to the following instructions. Connect the camcorder to the power source or insert the fully charged battery pack, and then slide the EJECT switch to open the cassette compartment cover. The cassette compartment cover will open, and then the compartment will open automatically.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Canon GL2 Mini DV Digital Camcorder Logo
346 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
