Plumbed in washing machine, but having electric shocks. wasn't a problem before
  • 639 Answers
Dear grahamconnor,
ngfam1 here for you!
I am happy to be of assistance!
WARNING STOP!! DO NOT RUN IT OR TOUCH TIE MACHINE
CAUTION: MANY PEOPLE HAVE DIED FROM THIS PROBLEM!
Procrastinating and trying to figure out why, may cost you more in the long run due to continued damage OR PERHAPS DEATH
I believe you should use service for this particular situation!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF
Posted on Aug 26, 2008
I get error message that says "add water" -- how do I do that?
it should be automatic if your machine is plumbed in correctly, if it is not plumbed in a hose, supplied with the machine, should be connected to the cold kitchen tap to top up the machine when required.
Dec 13, 2016 | Washing Machines
Forgot to open water supply for my new washing machine and when it started flashing I only realized the problem.As soon as it washes it trips my main switch and says Earth Leakage????Please help!!!!!
Hello Dora,
An Earth-leakage circuit breaker (ELCB) is a safety device used in electrical installations with high Earth impedance to prevent shock. It detects small stray voltages on the metal enclosures of electrical equipment, and interrupts the circuit if a dangerous voltage is detected.
You should have an appliance service person come out for a service call since there may be a dangerous shock hazard present on the machine.
Thanks,
Mario
Apr 17, 2016 | Washing Machines
There is electricity in the washing pot. What could the problem of?
You need a good ground to eliminate shock. There should be a ground wire to the case, and to the transmission. Did you leave one off when you serviced it?
Mar 06, 2016 | Washing Machines
My used washer makes a bang win it goes to wash after the soak cycle. It looks like it is missing springs in the bottom lower front between the motor basket and chassis. Is this suppose to have springs ?
washing machine normally have 2-3 springs on top of the drum and 2-3 shock absorbers supporting the drum from underneath, check one of the shock absorbers has not become detached from the drum or cabinet.
Apr 08, 2014 | General Electric WBSR3140GWW Top Load...
My LG washing machine shocks me when plugged to the mains. Can someone advise?
IMMEDIATELY unplug the machine and call a professional service tech -- this could kill. There is a short to ground. After, or during, the service call, a GFCI outlet should be installed for the washer. The GFCI will prevent electrical faults from creating a potentially lethal shock hazard.
Charlie
Feb 15, 2011 | LG Washing Machines
Im getting electric shocks from my washing machine
If you are getting shocked, it is because the electrical outlet is not grounded properly
Fix the outlet and you will be okay.
heatman101
Aug 13, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Getting electric shock from water in washing machine and laundry
Yes, because there may be a problem with your incoming electric service. Call your power company to check out their equipment, if their equipment is ok, then call a reputable electrician, because the problem may involve your equipment
Aug 09, 2009 | Whirlpool Washing Machines
Zanussi aquacycle 1000 xc washer
faulty fill valve. or tap not switched on correctly if it has the blue tap remove the top of the tap and use pliers to switch it on
Jan 26, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
