Question about IBM ThinkPad T42 Notebook
Turns off autometically
My ibm t42 thinkpad turns off autometically after running few minuts pls. help
  • kolkatacompu Aug 27, 2008
    when i keep the power pluged in for some times, and then turn it on it runs for some time like 15 min. Then i have to remove the power cable and the battery, and after putting them back on place and turning it on it runs again but not very long some times 2 min and sometimes 30 seconds ,but when ever it shuts off i have to remove the battery and power cable to turn it on again.
    Genius:
  • 2,028 Answers
How far does it get on the boot process? Does it open the operating system completely before shutting down? Do you get any error messages, and does it go to a black screen stating Windos wasn't shut down properly? Answer these and I'll have a better idea of what's going on.
Posted on Aug 26, 2008
  • Ryan Rogers
    Ryan Rogers Aug 27, 2008
    O.K. Let's start by checking a few things that commonly cause this. First check the power supply with an ohm meter for the proper output, and check the jack on the machine. If the supply is starving the machine, or the jack is loose/broken it could cause this. Then pull the battery, and try starting with the supply only. It could be a bad battery or engaged battery fail safe. Then remove the memory, and try each chip one at a time in each slot. Could have a failing memory chip. Now, follow the link bellow and download the drivers for the power management system, battery,and anything else that may be relevant to the shutdown, definitely the power management and battery downloads. At this point, you've done all that you can do without getting professional help. If the problem persists, then it's going to be a failed motherboard component, most likely with the power management system. You can take it in for diagnostics,but in my experience from the Thinkpad's that have come through my shop, it's cheaper to replace the motherboard than it is to try to have the power management system repaired.
    http://www.ibm.com/products/finder/us/fi...&
My IBM ThinkPad T42 screen does not turn off when i close the lid
there's a small switch usually located physically on the body of the laptop or sometimes on the inverter called a close lid switch. it may have gone bad, you can either try to replace the inverter to see if it helps or you can look for that physical switch
May 03, 2012 | IBM ThinkPad T42 Notebook
My IBM THINKPAD T42 screen turns to black after 30 to 40 seconds when i turn it on.
This indicates a hard drive problem, have it tested to confirm, because the hardware may need to be replaced. First try and reload windows with cd installation disc if that does not work the hard drive must be suspect.
May 01, 2012 | IBM ThinkPad T42 Notebook
IBM Think Pad screen is out. Turned black can't see any images. Can't find a Model number such as T42 or anything like that. What to do?
try to do this:
- remove the battery and charger (everything connected to the pc) then press the power button for 1 minute..
- plug back in the charger
- after few secs try to turn it on
hope this helps :D
you may check also the sticker on the back of the laptop where in you can see the SN or S/N and also the Model number
Mar 24, 2011 | IBM ThinkPad T42 Notebook
Need LAN driver for IBM thinkpad T42 cruz_369@yahoo.com
IBM ThinkPad T42 LAN Drivers
Please visit the above link from Official IBM Support and download the required Drivers
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 14, 2011 | IBM ThinkPad T42 Notebook
Have IBM think pad T42. running windows ultimate. I can get to the welcome page, but none of the keys work
unplug the AC cord,
shut down the PC ,and then removed the battery for a few minutes
Oct 01, 2010 | IBM ThinkPad T42 Notebook
I have an IBM ThinkPad T42 and until a few minutes ago my touch pad was working with no problems. I installed a wireless mouse and that works fine. But I cannot control the cursor with the touch pad or red...
Try going to Start>Control Panel>Printer and other Hardware and look for mouse pad or something like that. I think the problem is that you can only use either the mouse pad or the mouse, can't use them both at the same time.
Oct 15, 2009 | IBM ThinkPad T42 Notebook
IBM thinkpad t42 boot up problem.
The most common reason is memory.
First, try to reseat (remove and reinsert).
If still a problem, test one module at a time.
Hope this helps.
Aug 17, 2009 | IBM ThinkPad T42 Notebook
Shuts down autometically
Also, have you changed anything lately? and, Did this just start happening out of the blue, or did something happen to cause this, ie... power failure, kicked the plug out, ran the battery completely dead, overheated, etc...?
Aug 26, 2008 | IBM ThinkPad T42 Notebook
IBM ThinkPad T42 Notebook Logo
191 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
