Question about Gateway FPD2275W LCD Monitor
Computer has no sound
I had accidentally uninstalled my SIS audio controller, that's why I haven't heard any sound in my computer. what will I do?
  • 983 Answers
You can install the audio driver again from the manufacture cd which is given with your motherboard at the time of purchase if you are using onboard audio. ..
if you are using other sound card then you must disable the onboard audio in the bios option and then you can install the audio driver which is provided by the manufacture of the sound card at the time of the purchase ...
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my soution
Posted on Aug 26, 2008
No audio
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 19, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
No sounds
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 22, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Pc sound is not working right now hepl me
hope this helps
Jan 20, 2011 | Computers & Internet
No sound out of speakers diagnostic button does not produce test tone,and right main speaker control flashes PROLOGIC. I have heard the motorboat sound coming from the subwoofer,but no sound now,green...
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
Dec 18, 2010 | Altec Lansing ADA 885 Computer Speakers
No audio and sound device on my acer laptop aspire 5570Z model
Connect a heaphone and check if the sound is heard. Also check if the volume is not muted on the Computer.
Open the Device manager bypressing the "windows logo key+R" then type devmgmt.msc and click OK.
Next, click on the plus sign next to the "ound, video and game controllers" to check whether the audio devices is lised or if there is any exclamation mark visible.
if the exclamation mark is visible or not, right click on each of the devices listed under the "sound, video and game controllers" and click Uninstall.
After uninstalling all the devices that are listed under the "sound, video and game controllers" restart the Computer.
After restarting the Computer, visit the computer manufacturer's site to download and install the appropriate audio driver.
Nov 03, 2009 | Acer Aspire 5500 5570-2609 Laptop
I had dowload sound driver for sis 964 but when I install they inform that: error
1st Download Driver from this site SIS Sound Driver
Installation of Sound Card.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Multimedia Controller or Audio Control the yellow Question Marks sign on it.
  • Right click on Multimedia Controller and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Mar 18, 2009 | Computers & Internet
Onboard sound card driver
hi did you try this ??
http://www.downloadsource.net/7653/SiS-7012-Audio-Chip-Driver-Windows-9x-NT4-2000-XP-32-bit-XP-64-bit-2003-64-bit/
Sep 15, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
WANT TO KNOEW THE ANSWRS
Is it the correct driver? Have you checked that the motherboard chipset is VIA? If your chipset is SIS, or Intel, you should download the corresponding drivers.
Sep 11, 2008 | TerraTec Electronic Aureon 5.1 PCI Sound...
Sound card problem
Sep 08, 2008 | Computers & Internet
Gateway FPD2275W LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
