Question about Canon GL2 Mini DV Digital Camcorder
Ripples appear in the image when photographing an object with fine plaids or stripes. How can I fix that?
    Sergeant:
  • 255 Answers
When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red cross-stripes and black cross-stripes overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly. Reference You may find another Moire effect displayed on the LCD of the camera. As this is caused by the aligned pixels on the LCD, this effect does not necessarily appear in pictures you have taken.
Posted on Sep 04, 2005
Camera screen is black no image appears to view to take a picture??
Time for a new camera perhaps ? Sreen is faulty, most likely and fixing may be too expensive.
Sep 11, 2014 | Kodak EasyShare MD853 Digital Camera
Olympus u820 image distortions colour and form
One answer time for a new camera the cost to repair is about the same as new.
Mar 15, 2017 | Olympus Stylus Stylus 820 µ Digital 820...
Dynex 37 hiss and plaid screen
There are some components that have gone bad in the board. It could also be due to moisture inside. Please do not continue to use it and refer it to a qualified service technician.
Jul 19, 2012 | Dynex "- 37"" Class - LCD - 720p - 60Hz -...
When I turn the camera on (Canon Powershot A 80) purple and black stripes trouble the screen. The camera takes pictures anyway, but it is hard to see what photograph you make. Can anyone help?
This is known problem of ccd imager chip failure in Canon A80 camera and ccd imager chip will be replaced to fix picture problem.
Canon offers free of cost ccd imager replacement, click Canon CCD Imager Advisory for details.
Thanks.
Feb 04, 2010 | Canon PowerShot A80 Digital Camera
White surfaces photograph pink in color with
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Jan 04, 2010 | Canon PowerShot A95 Digital Camera
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
Red-striped ghost images.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
Dec 24, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Ripples appear in the image when photographing an object with fine plaids or stripes. Why is that?
The following describes the symptoms, cause and prevention of the Moire effect. Symptoms of the Moire effect When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly. Reference You may find another Moire effect displayed on the LCD of the camera. As this is caused by the aligned pixels on the LCD, this effect does not necessarily appear in pictures you have taken.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
Picture ripples
The following describes the symptoms, cause and prevention of the Moire effect. Symptoms of the Moire effect When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the fine pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red stripes and black plaids overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly.
Aug 31, 2005 | Canon PowerShot Pro1 Digital Camera
Picture ripples
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon GL2 Mini DV Digital Camcorder Logo
130 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
