Question about Hotpoint Aquarius WF000 Front Load Washer
WF000G Board Hi Tresil Thank you for replying to my earlier issue with the eeprom. I did lift the old one off and place it on the new baorad... worked perfectly. Now, in my haste to remove the card from the machine and after dropping off all connnectors I removed two single wires but did'nt note their exact location, a schoolboy error (traced them to the heater element). Have got the heater working but just want to check I have put these wires back onto their correct spade terminals. If you can help, great, if not thank you for trying. John
I have the same prob i know where they go on the heater element but where do they go on the pcb
Posted on Feb 08, 2010
  • d_elliott Feb 09, 2010
    johnnymcd could you please tell me where the wires go on the pcb the two wires wat you refer to in your post ive got them on the heater but dont know where they go on the pcb thanks dawn
    President:
  • 1,462 Answers
If the wires both go to thye heater element, it won't matter which way round they go
doug
Posted on Aug 26, 2008
Black screen, but sound
maybe it is the panel eeprom,if the panel inverter is good which should be treated with experts
Jan 14, 2013 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Wire diagram 10335223
Anyway long story short, I was looking at the circuit boards of both radios and found a small 8 pin chip that was a 4Kb EEProm .
I figured this could be where the vin is stored and maybe other vehicle settings that can be changed by through the radio.
I tried to exchange these EEProms between both radios with the rationale that I would bring the vin and settings from one to the other but this did not work.
It results in a 'CAL ERROR' message for ~1-2 secs when the radio is on.
An interest side effect is that Theftlock was completely bypassed :) :) :) :)
So I returned each EEPROM to the radio they belonged to
but left pin 8 of the EEPROM not soldered/connected. (pin eight is power to the EEPROM)
Except for the CAL ERROR message for a 1-2 secs when I turn on the radio, all works perfect.
All sound settings, bass, treble, radio stations, resume place on the cd/mp3 are stored when the vehicle is shutdown too.
All integration/Class II features:
Chimes, OnStar, dimming, off when door open etc work fine too :)
Bottom line, just find the 9355093 8 pin serial EEPROM, take a soldering iron and a very small screwdriver/knife.
Heat pin #8 and lift/pry *very* carefully so it no longer contacts board.
that's it.
Jan 09, 2012 | Chevrolet Cars & Trucks
LCD screen totally white when turn on
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful.
Thank you for choosing fixya.com
Aug 11, 2011 | HP Computers & Internet
I have an RCA G32705 TV and it will not turn on anymore. It worked fine a few hours earlier, now it makes a squeeking noise. Any suggestions?
Hi - it's a good set, I have a 32695 which is a year older (1999). Top of the line Home Theatre Premier series. Common problem, it is the EEPROM chip on the circuit board. Very common problem to lots of RCA, GE, and Proscan. Shows up with age and yours is about ten-years old. If you like the set (I like mine) you might want to seek out an estimate for inhome service. I'll bet it will be well over $150.
Feb 27, 2011 | RCA G32705 32" TV
Hi, do you supply spares as i need a new mod board for a hotpoint aquarius wf000g.. thank you.
You will have to go direct to Hotpoint, or a spares supplier to obtain a new board for your washer.
Oct 27, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Need to replace the lid on fisher&paykel washing machine
Hi just read your posting.To remove your old lid open it and then lift the lid straight up away from the machine.It is only clipped in place.Then refit the new lid by clipping it back in the side holders.Hope this helps and please reply for further assistance.Looking forward to your reply.
Oct 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
Magnavox picture has started rolling.
You have a failing eeprom. The location on the board is IC002. The correct eeprom depends which microprocessor [IC001] and stereo decoder [IC1001] is used in your TV board. When removing old eeprom , insert a eight pin socket and solder into place. Now you may insert the new eeprom. This will be handy the next time you need to replace this IC the next time!
Jul 04, 2010 | Philips Magnavox 27MS343S 27" TV
Error code
These fault codes indicates an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board. Most likely the CCU board will need to be replaced.
Thank you !!
Jun 20, 2010 | Kenmore HE2 Plus Front Load Washer
New board eeprom
eprom is available as a spare from hotpoint. however, there is a good chance that the old eprom is ok in my experience.
Aug 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Won't even start.. 0.o! (Reply)
Please mark me as FixYa! even if your mobo is DOA .
Thank you Horton
Aug 06, 2008 | EliteGroup L7VMM2 Motherboard
Hotpoint Aquarius WF000 Front Load Washer Logo
284 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
