Question about Canon GL2 Mini DV Digital Camcorder
Connection How do I connect my digital video camera to a computer?
    Sergeant:
  • 255 Answers
A digital video camera may be connected to a computer using an optional OHCI compatible, digital video capture kit available commercially. These kits must be capable of using the IEEE1394 (FireWire) interface to enable you to import digital video signal and still images into your computer. For those models equipped with a separate USB port, the camcorder may also be connected to a computer via its mini-B USB port, for downloading still images recorded on the SD/MMC card.
Posted on Sep 04, 2005
Transfer vidoes to a computer using a USB connection
Consider NOT using the USB connection.
The best way to download videos (and pictures) from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy videos and pictures from the card to the computer's hard drive, the same way you copy any other files.
Mar 08, 2012 | Sony Cyber-Shot DSC-W560 Digital Camera
I got sony cybershot dsc p 200 model digital camera. But it is not supported as web cam . Please give suggestions to set up the camera as web cam
Many digital cameras support streaming video over the USB connection, to use as a webcam. Unfortunately Sony cameras do not do this; I am confident of this, because they offer a tutorial describing how to make an analogue connection from your camera to your computer, for use as a webcam! (I feel this is a poor solution because few computers have an analogue video-in connection, and not all cameras have a video-out. They would not offer this solution if the USB streaming was possible.)
I'm sorry to tell you that unless you are really lucky and are able to follow Sony's tutorial, your best bet is to buy a webcam and forget using your camera. A whole webcam could easily be cheaper than the cable that Sony suggest you use...
Jan 19, 2011 | Sony Cyber-Shot DSC-P200 Digital Camera
No space left on memory stick.
Hello Sir\Madam,
Most digital cameras do have an internal memory which may be minimal or too small to store your pictures or videos, because of this memory stick/card are always good for storing pictures and videos due to the fact that it has enough spaces to store you data. And you can easily transfer your picture from your camera to your personal computer by using the USB cable that came with your camera. As soon as u connect it to your computer, it will detect it and automatically install the driver that will make the connection to work well, or better still install first on to your system the software that came with your camera for easy connection of your camera to your computer, then on the camera, select "Mass Storage" from the USB connection mode, automatically your memory stick or card will be detected on your computer and you can them open the folder where all your pictures is stored to retrieve then to your computer. If you have any problem with this, don't hesitate to inform me back
Regards
Jul 13, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
My Sony Dvcam DCR-HC15E Mini DV Digital Camcorder is not being seen when I plug it into the USB port on my computer. I have downloaded a program called Driver Robot which is supposed to update my computer...
Go to camcorder Menu and enable USB Streaming option.
Computer / Windows will recognize camcorder and will install drivers automatically for further communications.
Thanks.
Sep 18, 2009 | Sony Dvcam DCR-HC15E Mini DV Digital...
Digital video camera (sony dcr-trv265e)to computer
Use a firewire connection and Windows moviemaker
Jun 27, 2008 | Video Cameras
Canon mvx20i E
easy...
do not plug in your camera while you connect it with computer
Jun 24, 2008 | Canon MVX20I Mini DV Digital Camcorder
S-video port
Fist of all I like to inform in computer S-Video output of the camera usually does not fit to computer. Only if the computer has S-Video Input card it will be possible. However logic is simple. Digital Camera or Camcorders uses 1394 or USB connection to connect to the computer. You havent indicate what model of JVC you use, almost all JVC Digital Cameras come with USB connection option. All you need to put USB cable in between. If it asks driver, use the CD comes with the Camera or download from JVC's support website.
http://support.jvc.com/
Good Luck
Dec 30, 2007 | Microsoft Windows XP Professional With...
"Connection failed." -- Serial connection
The "Connection failed" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Canon GL2 Mini DV Digital Camcorder Logo
136 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
