Laptop Driver PCG-8N1M
I have a Sony Notebook Computer Model: PCG-8N1M.
The hard drive crashed and I installed a new one.
Pls can you help me find the drivers for it? I looked on the Sony laptop website but the model is not there at all.
    Brigadier General:
  • 6,966 Answers
Due to regional differences of the models, some model numbers may only be applicable to certain limited regions, could you pls try and verify if your PCG-8N1M is identical to the PCG-GRT895MP. If yes, you may want to try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 26, 2008
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
What drivers are need for clean windows xp install on sony vaio pcg-k37?
This model Sony came installed with a 80Gb hard disk and a 40 Gb
Do a clean Windows install on this old hard drive -
Boot up with the Windows installation CD
install Windows on the hard drive
Delete the existing Windows partition
Create a new partition
Format the new partition (full format not Quick format)
Continue installing Windows.
Mar 24, 2012 | Sony PCGK37 Notebook
I need to replace my hard drive in my Viao PCG-GR370 laptop. Is it possible to put in a larger than 30 GB drive?
below is a link for a 320 gig hard drive for your model, i hope this helps
http://www.upgradecomputermemory.com/ram.cfm//memory/s/sony-vaio/sony-notebooks-vaio-pcg-series/VAIO-GR-PCG-GR-Series-Notebook/VAIO-PCG-GR370/320GB-Notebook-Hard-Drive-for-the-Sony-VAIO-PCG-GR370.html
Feb 14, 2011 | Sony VAIO GR370 Notebook
Hey my laptop, on start up says there is a there is an hard drive fault and failure is immentent and to back up data.... press F1 to continue.... this has happened for the past 1yr now it wont turn on at...
The error indicates that the Hard Drive in the computer has crashed and will require a replacement.
I made a quick search and found the part # of the HDD that was shipped with your model. It is
A1065524A. I would suggest that you replace the HDD with one with the same specification that was came with the computer.
You may either purchase it from Sony parts center or third party vendors.
Thanks!
Dec 13, 2010 | Sony VAIO PCG-V505CP Notebook
Vaio pcg-k17
WinXP needs to run a utility to partition the drive and activate it first. Try running https://docs.microsoft.com/en-us/windows-hardware/drivers/devtest/devcon
May 20, 2017 | Sony VAIO K17 (PCGK17) PC Notebook
Need to recover the computer, back to factoru settings
Call sony, the disk is 12 bucks. I had this problem after my hard drive crashed. Be careful though, because I replaced the hard drive and it would not recognize the disk after that. Sony wanted me to pay 100 dollars to fix it.
May 07, 2009 | Sony VAIO PCG-K23 Notebook
Does not find hard drive on sony laptop model pcg-992l
Hi!!!!
may the hard are not connected properly
try to open your laptop pull out the hard and then put it back!
Sep 20, 2008 | Sony PCG-TR3A Notebook
SONY LAPTOP MODEL-PCG-5KQP
what kind of driver? pls
Aug 08, 2008 | Computers & Internet
Camera, PCI Modem, USB devicedriver
hi! i need some help about my sony pcg tr3/b anyone knows where i can download the driver of the athenos AR5212 wireless adapter for this model of laptop thanks you. pls mail me at vvioxx06@yahoo.com.ph
Mar 28, 2008 | Sony PCG-TR3A Notebook
Computers & Internet Logo
1,846 people viewed this question
David Payne
David Payne
