Question about Carrier Heating & Cooling
HOT CONDENSE - Carrier Heating & Cooling
  • TIMMATDEB Aug 26, 2008
    Yes that was what I thought we have combed and cleaned them but the problem still persists
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Dirty coils, needs a coil cleanning with coil cleanner! thank-you-very-much!
Posted on Aug 26, 2008
Dehumifier blowing cold air
Hot air holds more moisture than cold air so if you cool moist air the water will condense out and become dryer. Your "dehumidifier" is actually the car's air conditioner.
Jan 28, 2017 | Cars & Trucks
Ec 40 code freezer at 14 degrees
That's an excessive run code. Is the freezer door frame hot? D you clean your condense and id the condenser fan motor running?
Oct 07, 2014 | Sub-Zero 642
Why does my air conditioner keep shutting off?
This can happen for a number of reasons, but make sure the condensing coils are clean and not obstructed by any improvements or natural things such as trees or bushes. The hot gases produced by the compressor must be cooled (condensed) by the pulling in of the ambient air to cool these hot gases and dissipate them in order to reduce the head pressure and condense the hot gases to a liquid. The appliance is designed to shut down whenever the head pressure reaches a pre determined level (to protect the equipment).
May 13, 2014 | LG LW1211ER 12,000 BTU WINDOW AIR...
Kenmore side by side drain tube in freezer keeps freezing up Any solitons other than to keep thawing out the the every two weeks
try to locate the drain tube on the bottom and blow it with compressed air to clear the way for the condense water to drain out or open the freezer back panel and run hot water to see if it clears.
Dec 11, 2013 | Refrigerators
EXHAUST AIR IS COOL NOT HOT
This is definitely weird. The exhaust duct (or the connecting tube) must have came off , and you're feeling the recirculated air.All air conditioners (all) have to condense the refrigerant (cool the gas and it becomes liquid) in their condenser. The heat has to go somewhere, usually to the atmosphere and not in the conditioned space.
Aug 24, 2013 | DeLonghi Pinguino PAC-260 Air Conditioner
Miele T230C dryer keeps tripping out after only a few seconds?
Mostly likely cause is the heater element part no. 6138580. To ensure this does not happened again 1. Ensure appliance is situated in a cool room with ventilation (If room to hot it will not condense)
2. Ensure metal heat exchanger at bottom of appliance is rinsed regularly both long way and width ways.
Feb 01, 2011 | Miele Novotronic T230C Electric Dryer
PLUGGED IT IN FOR THE FIRST TIME OF THE 2009 SEASON BUT IT WILL NOT PICK UP ANY WATER. IT HAD WORKED FINE FOR THE PAST 2 YEARS.
Try to feel the lines on the compressor. The thinner line is High press and should get hot. The fatter line is Low press and should feel cold. Cold enough to allow water vapor to condense on it and turn into droplets. If neither occurs, compressor has lost "freon" charge.
Jun 27, 2009 | Danby Dehumidifiers
Dehumidifier throws off hot air making the room very warm. Is that normal?
Yes! A dehumidifier is an entire AC system in one box. First the air passes thru a very cold coil causing moisture in the air to condense and run away. Then the air is re-heated thru a hot coil (the other half of the AC) and blown back into the room. The net result MUST be a net increase in temperature because of the heat added by the mechanical process.
May 17, 2009 | Goldstar DH504EL Dehumidifier
Zanussi tumble dryer does not get very hot
Hi, I take it from the description taht you have given your T/dryer is a condenser? If this is the case you could be looking at several problems? 1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough! 2 it could be the water collection pump? Can you her it running? 3 It could be that half the heater has failed causing it not to get hot enough to dry?
Try these hopefully it should steer you in the right direction!
Feb 09, 2009 | Zanussi TD4112W Electric Dryer
Clothes wont dry but gets really hot
Hello, sounds like your cold water feed hose has got a kink in it. The machine needs cold water to condense the steam. Just pull out the machine and slowly slide back into place.
Oct 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
