Question about Bosch TKA 9110 Coffee Maker
Bosch porsche 9110 drip coffee maker
The filter basket dropped and plastic pieces holding spring broke off.  where can i purchase a replacement?
  • nastia9 Apr 01, 2009
    the filter basket dropped and plastic pieces holding spring broke off. where can i purchase a replacement?
Mine just broke this morning! i just ordered the same part from - the part number is AP2807555. It is currently backordered until 4/25/09 - hopefully I will get that and the other part I ordered. Hope this helps.
Posted on Apr 15, 2009
Have a Mr Coffee model #BVMC-PSTX91. The filter basket has a spring loaded release that has fallen off - how do I put back on? cannot figure out how to put the spring and extra plastic piece on?
without seeing it (a picture) that is a difficult question to respond to. it may have possibly broken or a piece of plastic needed to keep it in place broke - or the spring is defective. suggest get a new basket. (or go to the store, or find a neighbor with a similar model - and look at his basket, take a pic of the spring mechanism with your cellphone and go home to fix your own.)
Jan 27, 2017 | Coffee Makers & Espresso Machines
Bosch TKA 9110 UC Porsche Designer Series Coffeemaker my Bosch coffee maker in transit....I lost the little round ball that sits in between the coffee pot and filter section. How do i replace that...
Here is the link for the Bosch service locator. Enter your zip code (I assume that you are from USA) and you will see the nearest servicer for Bosch. From there you can get the address or phone number to contact them and order a new replacement for the missing part.
Hope that helps. Can't help you more at the moment, because you did not give sufficient information about where you live and where did you buy it.
Mar 06, 2011 | Bosch TKA 9110 Coffee Maker
I have a FTX49 Mr Coffee Maker purchased 9 months ago. It just started to leak in the front area where the round burner casing meets the tall front face of the unit (the groove area on both sides??) What...
There is a lever in the back of the carafe area that pivots and controls a spring loaged valve on the bottom of the removeable filter basket. This lever breaks easily. Pull the filter basket out and you can see the lever hanging down into the carafe "bay". (assuming it's not broken off entirely).
When you pull the pot out during brewing, the lever swings forward and allows the valve on the bottom of the filter basket to close. This shuts off the flow of coffee to avoid drips. The plastic lever is held in place underneath the valve by two round tab "ears". One of these ears can break off, causing the level to hang at an angle. This means the filter valve never completely opens, even if the pot is pushed in all the way. During brewing, the filter basket can't drain into the pot fast enough and overflows.
I fixed mine by going ahead and removing the damaged lever and then wedging the valve open. The spring loaded valve has a little drip "Spout" which hangs underneath the filter basket that directs the coffee into the pot. You can push in on the back of the drip spout and wedge something into the two slots at the back to hold the valve open. This let the coffee flow freely during brewing.
Oct 15, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Need to replace filter basket drip spout rubber ring
After searching for the replacement basket on web took whole coffee maker back to jcp and they replaced the 12cup coffee maker with a new item.
Jul 28, 2009 | Coffee Makers & Espresso Machines
Cuisinart Brew Central 12-cup Coffee Maker Filter Basket Anti-dripo has come unattached. We have a spring and the anti-drip puiece. How do they go together?
Hello tfsmithcambr,
You need 3 pieces. The bottom plug, the spring, and the collar. Slip the spring over the plug. Insert the plug into the basket end. Slip the collar onto the inside the basket end of the plug shaft until it clicks. Should be good to go. If this does not work or you are missing a piece, you may need a new basket. Hope this is helpful. Good luck and kind regards, NormanZ
Jul 07, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Cuisinart DGB-300 coffee maker brew pause valve
No one has just the individual part, but you can get the whole brew basket with the part included on Cuinart's website, or by calling them.
Feb 03, 2009 | Cuisinart DCC-100 Coffee Maker
Door spring came off filter basket door on Krups FME4 coffee mak
yhere should be a little post th spring goes on in the vack of the basket ...out in pkace hold untill in place
Dec 10, 2008 | Krups FME4 Coffee Maker
Bosch TKA9110 - Glass Lined Carafe
Or if you prefer, go to then click customer care...purchase parts...& then "order accessories & additional parts".
You will need to check the bottom of the coffee maker for the full part number, there were two machines with a similar number & different suffixes.
It will give a detailed breakdown of the coffeemaker.
I ordered parts yesterday, but I'm not yet sure if they are available in stock.
Oct 31, 2008 | Bosch TKA 9110 Coffee Maker
Swing-out filter basket with pause and serve..not functioning properly
Something wrong with your little 'grab a cup' mechanism. There should be 2 hinged plastic pieces (one of which contains the 'nipple', and one spring. The spring is shaped like a squared off 'U', and is about 2 inches long. Check to make sure all these parts are there, and move freely.
Also, check the basket. It dovetails onto a swing arm, and could be misplaced. If the basket is not positioned properly, the pot will not push up on the mechanism to let the coffee out. Make sure the pot is able to be pushed fully onto the hotplate and trip the mechanism as well.
Jun 29, 2008 | Braun AromaDeluxe KF 580 Coffee Maker
Spring came out - where does it go?
That is from your dripp stop. If you can replace it it will be in the bottom of your filter holder. If not Please tkae out the valve on the bottom of this filter holder. You will have no dripp stop but it will work just fine.
Jun 01, 2008 | Krups Aroma Control 197 Coffee Maker
Bosch TKA 9110 Coffee Maker Logo
480 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
Oloyede Monsuru
ray gallant
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
