Question about Hotpoint Washing Machines
Carnt get middle bearing case out of outer barral
  • 639 Answers
Dear Monsandkaz,
ngfam1 here for you!
I am happy to be of assistance!
I believe you should use service for this particular situation!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
I have Z445 54 inch and the middle blade. Is cutting lower than sides. The outer blades are at same height, any help?
Middle lade has probably hit stump and bent. Try moving to outer and see if this does not move problem. If you still have problem at middle look at the blade spindle bearing could have gone bad and shaft dropped.
Aug 05, 2017 | John Deere Garden
Crosley washing machine making a clicking noise when I turn it on.. Machine won't do anything ?
(1) The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, i recommend replacing both the outer tub and bearing.
Jan 11, 2017 | Crosley Washing Machines
Rear bearing came apart when tried to remove. outer part of bearing stuck in axle. how do i remove this
small slide hammer with hook end some rear axle bearings are two piece one on axle and the other the outer case of bearing fits in axle tube of diff
Oct 06, 2015 | Cars & Trucks
Does the outer drum on a hotpoint WT540
All outer tubs on most Washing Machines these days are sealed.
Therefore you cannot split the tub to get inside and change the bearings. instead you have to change the whole tub assembly as a complete unit. Not an easy job.
Oct 27, 2014 | Hotpoint Washing Machines
How do I remove the Front rotor off a 2006 Dodge
the rotor is a slide on, some times the rust holds them on tight. in this case what i would do is hit the top hat of the rotor with a good size hammer all the way around it, then tap the back side of the rotor to gett it off. good luck
Nov 24, 2009 | 2006 Dodge Dakota
Metal noise and rattling during washing cycle only.spin cycle is fine and normal.just started doing it in the middle of the wash cycle. guessing 10 to 15 years old on washer with never having a repair(how...
If top loader, remove the agitator and try to move the shaft sideways in a number of directions. If sloppy, the shaft and bearing need to be replaced. To get at it, the top of the case must be open, unbolt the inner tub, then the outer tub. Be careful around any rubber seals at the bottom.
Aug 02, 2009 | Washing Machines
The inner tub is out of balance and rubbing against the outer tub
The rear bearing is part of the back half of the outer tub. In some cases the basket will need replaced also if the shaft is scored. This is a big job. In most cases whirlpool will warranty the parts for 10 years but not the labor. Will need to check in your owners manual. Hope this helps
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bearing noise
You have to remove the outer tub assy from the cabinet then split the halfs, We're told the the bearings are part of the rear tub housing. You might be able to press out the bearings
Feb 11, 2008 | Kenmore 43142 Front Load Washer
Replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Aug 29, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
