Question about Video Game Consoles & Games
CH products Flightsim Yoke And CH PRO Pedals seem over sensitive.Is there a way of reducind this sensitivity
  • mikelindsay Nov 02, 2008
    I use CH Pro Pedlals USB in Flight Sim 2004 & FSX. The brake function is over sensitive and I've tried reducing this, and increasing the 'null' zone in my settings. In fact if I just rest my feet on the pedals the brakes are activated. Is there a driver download to reset and correct this ? The rudder and steering functions work well.
    Your help would be very much appreciated.
I have the same problem. My Pro Pedals brake movement jumps to halfway when just placeing my feet on the unit. This reeks havoc on any car simulation game using the gas/brake combo. I have found that using the CH Products control manager, available here: http://www.chproducts.com/retail/downloads.html, helps to alleveate the USB device problems, but still doesn't fix everything thing. I have replaced the position sensors in the pedal motion, and they have the exact same problem as before. It is probably a software problem.
Posted on Sep 03, 2008
As I apply throttle power during takeoff, the aircraft moves drastically to the left on the centerline
You are experiencing torque due to the propeller turning faster. You need to apply opposite rudder to compensate.
Feb 15, 2014 | CH Products CH Pro Pedals
CH Flightsim Yoke Sensitivity
Have you tried adjusting the sensitivities of each axis using the Control Manager?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 26, 2008 | Video Game Consoles & Games
Saitek Throttle Quadrant wont go idle and full power
I had a similiar problem and after spending hours researching and looking at forums I figured out the a solution. Plug in the quadrant directly into your computer and then configure it. At that time make your necessary tweaks, i.e. null zones and sensitivity adjustments. After you get it to work properly there, then you should plug it into your yoke and everything should work fine.
Best regards,
Gary
Jun 14, 2009 | Saitek Pro Flight Yoke System Flight...
V3 fx steering wheel for PS2
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 Here are all of the instructions enjoy. clip_image001.gif
To adjust the V3 Racing Wheel 2's sensitivity follow the instructions below. ( 3 preset sensitivity selections )
1. Press and hold the SET button for about 1 second to enter the "FUNCTION SETUP MODE", the MODE LED indicator will start blinking and two "beeps" will be heard.
2. Press the direction on the digital/analog directional pad and SELECT button that corresponds to the setting you desire. Directional pad UP and SELECT will give you high sensitivity. Directional pad LEFT/RIGHT and SELECT will give you medium sensitivity. Directional pad DOWN and SELECT will give you low sensitivity.
3. After selecting one of the above sensitivity options you will hear 2 "beeps" letting you know that the wheel has been programmed. For Customizable Sensitivity follow the directions below.
2. Rotate (either left or right with the wheel ) and then hold the wheel to the specific angle desired.
3. Press the SET button again, two "beeps" will sound to indicate the completion of the setting
To reset the the V3 Racing Wheel 2 to it's factory default settings press and hold START, L1 and L2 buttons in until you here two "beeps".
To change between Digital and Analog modes follow the directions below.
2. Press the SQUARE and SELECT buttons to set the wheel to DIGITAL, or the O and SELECT buttons for ANALOG. Two beeps will sound and the MODE LED will stop blinking letting you know that the mode has been selected.
By default GRAN TURISMO 3 A-SPEC uses the X and Square button for gas and brake. To reassign these functions to the pedals on your racing wheel:
1. Go to the options menu in Gran Turismo.
2. Select key configuration. (The picture of the Game Pad.)
3. Scroll down to Acceleration
4. Press Right on the D-pad (11x) until Analog Up is selected for the Right Analog Stick
5. Now go down to Brakes
6. Press Right on the D-pad (10x) until Analog Down is selected for the Right Analog Stick.
7. Press the X Button to confirm your changes and then press the Triangle button to return to the main menu
8. The gas and brake functions for the game will now be set to pedals on your wheel.
Sep 10, 2008 | Cables Unlimited InterAct Racing Wheel V3...
Joystick sensitivity problem
You can reduce sensitivity by using the Logitech Profiler tool, which is on the cd that followed the product.
In the bottom left you will find a list of the axis', select the one you want to adjust, and a window will pop up, where you can change sensitivity, deadzone and range.
Jan 07, 2008 | Logitech Extreme 3D Pro Joystick
Steering control
INCREASE THE STEERING SENSITIVITY
Nov 03, 2007 | Logitech DRIVING FORCE FEEDBACK STEERING...
Video Game Consoles & Games Logo
843 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
