Question about Acer Computers & Internet
The hard drive on my son's acer 5920 laptop is nearly full and he can't get any more games to install but I can see it has a data drive how do I use this hard drive
    Brigadier General:
  • 6,966 Answers
Initially, I suspect that actually it is still a single hard drive but has been partitioned into two, the C being the working drive and the D or E as the data drive. Depending on the space availability, eveytime a new game is to be installed, you can instruct the installer to install/use on this D: (or E:) drive instead of the regular C:\.. Windows and the the game program will know where it was installed/saved and run from there without any other intervention from the user.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 26, 2008
No operating system Acer 5920
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Feb 12, 2012 | Acer Aspire 5920-6335 Laptop
Need factory settings aspire 5920
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operating, registry problems, virus problems, spyware issues and more. And a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
1.Back up all necessary data to an external device such as a disk, flash drive or hard drive
2.Make sure all programs are closed and shut down your Acer laptop by opening your Start menu and selecting "Shut Down" from the options for shutting down and restarting windows.
3.Detach any external hardware such as an external hard drive or printer.
4.Press the Power button to boot your Acer laptop.
5.Press "Alt + F10" on your keyboard when the Acer screen appears at the start of the boot up process. Wait a moment while Windows loads the reset files.
6.Select "Restore System from factory default" in the Acer eRecovery Management window.
7.Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration.
8.Click "OK" in the notice window to proceed with resetting your Acer laptop.
9.Wait while your Acer laptop is reset to factory settings.
Sep 06, 2011 | Acer Aspire 5920-6727 Notebook
Smart failure predicted on hard disk, acer aspire 5570 laptop
This warning is to let you know the hard drive may fail sometime in the near future so you should backup your data frequently.
When the hard drive eventually fails, you can replace the hard drive, re-install Windows, your programs and data.
Oct 07, 2010 | Acer Computers & Internet
Drive C is full. How do I direct new data to drive D? How to move large programs to D?
Uninstall programs from C drive and install it in D drive by changing the intallation directory while installing.
Sep 03, 2010 | Acer Aspire 5920-6727 Notebook
Had to have new hard drive in my Acer laptop due
Probably a specific drive needed from Acer. You can try thier support website if you do not have the drives CDs that came with your laptop. They will want your model number, then you should be able to get the driver.
Peace,
Mar 03, 2010 | Acer Aspire 5920-6335 Laptop
How to reformat aspire 5920
If you have the factory CD's you can yous that to reformat and install all defaults. If not, you can use a bootable Windows CD. Boot to the cd (pressing F12 as soon as the computer turns on and selecting Boot to CD)
You can the use the Windows CD to format the drive and re-install Windows.
Hope that helps. Please comment and rate if it does.
Thanks,
Oz
Feb 13, 2010 | Acer Aspire 5920-6335 Laptop
Acer 5920-6864 having problems
You have bad sectors on the hard drive. The hard drive will have to be slaved to another and then your data removed. The hard drive itself is probably not worth repairing.
Mar 25, 2009 | Acer Computers & Internet
Windows failed to start !...
Hello
You seem to know a bit about computer so I will give you a good detailed solution which might be of help. READ CAREFULLY
ASSUMPTION:
I guess that the main issue here is that your hard drive might be corrupted. I am also afraid that you might have erased or repartitioned your computer on a previous occasion if the recovery is not working. Please not that the Acer 5920 you mentioned has an automated system recovery system saved on to your hard drive. Did you by any chance Reformat the whole thing when you got the laptop? Because if thats the case and you removed the EISA partitions there is NO WAY you are going to get the recovery to work.
SOLUTION 1: USING RECOVERY CD's or DVD's
If you backed your system up when you first bought it and you created the CD's DVD's boot from them and recover the system that way. I am afraid that these will erase your C drive and will restore it to the original state when it was at time of backup. BEFORE all this you need to recover any data? In that case do the following:
1. remove the hard drive if you have important data.
2. Put it in a hard drive enclosure (which plugs in USB) and hook it up to another computer XP or VISTA doesn't matter both should work fine.
3. Then backup the folders you would like to make a copy of onto the hard drive of the other computer.
4. Then connect it back to the laptop (obviously make sure that when you remove and plug in this hard drive the laptop is off). And perform the recovery.
SOLUTION 2: If still all the above doesn't work.
If you do not need to backup anything there is no need to do the first 3 steps but you will need another computer
1. Do steps 1 to 3 above to make sure that you backup everything at least
2. Go to my computer on this to which you connected the drive computer Format the hard drive of the laptop (Making sure that before this step you backed up all the important data because you will lose it!)
3. Perform full format (this will take a while) and format it as NTFS, while formatting see if you can hear any funny noises. It could be a good sign that the hard drive is out. During format you should almost hear nothing. if you hear a repeated CLICK CLICK CLICK CLICK CLICK type of noise. Get another hard drive and repeat the above 3 wsteps
4. Get hold of an XP or VISTA installation disk according to what you had on laptop
5. Go to acer website and download all the drivers for the laptop you have and burn them on CD. If you already have a driver disc of the laptop you can skip this step but make sure that you have everything you need on it
6. put hard drive back in Acer 5920
7. Boot from the installation disk XP or VISTA. HINT KEEP the SAME OS if you had XP install XP ... if you had VISTA install VISTA
8. When it asks for serial number look underneath the laptop and key in the serial number from the fancy label you have underneat. It should be a 20 numbers and letters separated by (e.g. xxxxx-xxxxx-xxxxx-xxxxx-xxxxx)
9. Follow instructions and perform a full install
10. Now install all the drivers you have on that disk. These are like small programs. Install one after the other until you install them all. Reboot when asked to reboot... Do not choose reboot later!
11. Phew by now you should have a laptop working again. Isntall office antivirus and antispyware software and GET BACK the data from the other machine.....
CHEERS
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Restore window vista for acer aspire 5920
Hi Acer supply the restoration files in a hidden partition on your hard drive. If it is the same as mine try this. Start the pc, then while the Acer logo is showing, press ALT & F10 at the same time. Then just follow the instructions. Bear in mind that this will format your C drive so you should do a backup of any important data first. Hope this helps.
Sep 27, 2008 | Acer Aspire 5920-6727 Notebook
Freezing in game play
Need more information on your laptop. Model Number, Processor, Memory Hard Drive. Have you Defrag the Hard drive, Clean Temps File, Clean free space, Derag Memory, Defrag Registry, Clean Registry. Tell me what you have done so far, to help determine whats needed in the future.
Aug 10, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
