Question about Toshiba DR410 DVD Recorder
DVD PLayer I got all the cables plugged in to the dvd player and the TV and nothing happens. The DVD pLayer is not working when I put in a dvd to play. What could be wrong?
  • Anonymous Nov 10, 2008
    device turns on then back off
    Sergeant:
  • 326 Answers
Either the cables are not connected properly or the cables are faulty.initially try to reconnect them properly or else replace the cables and then check.
Posted on Jan 30, 2009
4 Suggested Answers
weaponx69
  • 58 Answers
SOURCE: DVD player only plays DVD in black and white - what's wrong?
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
Posted on Jan 12, 2009
  • 3 Answers
SOURCE: Disney princess dvd player will not play any dvd!
We had the same issue. Try clicking <play>1234<play> and it should unlockk the dvd in the machine. Seems to work on my daughters. It's a parental control of come sort. HTH.
Posted on Feb 01, 2009
SOURCE: The dvd player doesn't play the dvd's
when i load the disc it spins for 5-7 seconds then quits and the poer light, play light and loading light flash continously. model p421
Posted on Apr 18, 2009
How do I get the dvd player to work. I have it plugged in, but the one cable do I need it, even if they don&#39;t have surround sound? The coaxial digital cable. Do I need that to get it to work?
Make sure you have the audio plugs in the same input as the video. On the back of the dvd you will have a video and audio out. On the TV you will have to put these matching cables on the input of the tv. Once you have that you need to make sure the tv source is on the same input you have plugged into for this to work. If you have an HDMI input on your tv and an HDMI output on your DVD then you can use that instead of the three cables .
Dec 24, 2014 | Sony BDP-S1200 High Definition blu-ray DVD...
Sylvania (SRD3900) DVD Player / VCR Combo i can't seem to plug in the red/white/yellow cables into the right places directly to my old toshiba tv to play either tapes or dvds. can you instruct me? thanks.
Greetings - It's very simple so I'll show you how and then I think it may be another problem (nothing broken).
You need to plug the corresponding color cables into to outputs on your player I've circled above and then into the corresponding inputs on the TV. You've probably done this correctly.
PLUS - You have to, using the remote for the player, set the source to either DVD or VCR and then you have to, finally, on your TV set the input (with the remote) to what is called probably VIDEO or VIDEO1. If there is still nothing on the screen keep (with the DVD or Tape playing) hitting the TV remote input button until you see an image or you've come around to where you started.
Unless something is broken (unlikely) you should be able to watch DVD's or Tapes depending on what input you select on the player.
If it's not working you've somehow missed a step or the Video input on the TV is called something else. If that happens come back here and give the player AND TV brand/model info and someone will be able resolve your problem.
Good Luck and thanks for using Fix Ya.
Mikeywaf
Apr 21, 2011 | Sylvania (SRDD495) DVD Player/VCR
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
I put a regular dvd into my blu ray player but it will not play. the player just says load and when I push the play button nothing happens. I'm using an hdmi cable and my 42 i.nch widesreen sharp tv is set...
Assuming it will play regular DVD's I'd suggest you connect it by scart also and set your TV input to scart.
I don't think DVD's carry High Def. data, that being the case, your player may auto route the data via scart.
Mar 31, 2010 | Samsung BD-P1600 Blu-ray Disc Player
When i connect my dvd player to TV i only hear sound but no picture
hi there
your dvd player got three cable one red two white
three yellow ok here i go dvd player input plug in the yellow cable in the yellow in put @ the back of your dvd dvd player
the white cable and red cable is your sound the yellow cabe is your picture see that you have a yellow input @ the back of you tv and plug in the yellow in it then it will work
Dec 14, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Craig dvd player, model CVD327, won't play
no, s video is not required to work. if you hooked up 3 colors to the tv 3 colors. make sure it's on video 1 or aux channel. and as long the dvd player is on and that channel is on, if that does not work, try on another tv that has same connection. if that doesn't work, then we know that dvd player doesn't work.
Oct 17, 2009 | Televison & Video
Memorex DVD problem -- rollig screen on TV
How is the dvd player connected to the tv?
Mar 21, 2009 | Memorex MVD2050-BLK DVD Player
Help I am confused. After I have connected my new Sony DVD player to my TV which remote so I use. The one from my digital cable service or the DVD player remote? I turned the DVD player on and it says...
use the remote that came with the DVD. If you want to use the cable remote, you need to program it using the codes in the manual that came with the cable box or remote.
the numbers usually mean an error. commonly, C 13:00 means that the Disk is dirty.
Aug 25, 2008 | Televison & Video
Sony DVD player color adjustment (Model #DVP-N5400D)
Solved the problem!Well, After reading two manuals on the Sony DVD player, I saw one cable not connected: the S Video connection. I connected that. Tried it out again, seemed a little better, but still not the full range of reds. At that point I thought the problem was either: 1) the cables from the DVD player to the TV or 2) the DVD player is the problem So, I thought I'd start with replacing the cables. Labeled them as to where they went, took them out and went to Radio Shack and explained my problem. The clerk I spoke to was very nice, said he had seen this problem before, and said there was a menu on the DVD for adjusting RGB settings.
So, I went back home, plugged in the cable, and went all thru the 2 Sony DVD booklets and the display menu on the TV. There was nothing mentioned re: color settings. Went thru the DVD menu many times, looking, looking. I felt I had come up with nothing.
Turned everything off. Turned back on. Put in a DVD: It looks great! :)
So, hoping it never happens again..cause I'm not sure I can repeat it! Maybe it was removing all the cables from their sockets and restarting...I know that sometimes works with computers...anyway.. At least I didn't have to buy a new DVD! Lesson: unplug, re:plug...before you trash it!
M~
Mar 06, 2008 | Televison & Video
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
Toshiba DR410 DVD Recorder Logo
142 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
