Sony bravia 32" flashes back and forth between channel 3 where it should be and channel 14. Briefly resets when unplugged. Use of the volume control also sparks the flashing. is it fixable?
  • 1 more comment
  • daleeyre Aug 26, 2008
    The model no. is KDL-32L4000.
  • daleeyre Aug 27, 2008
    sony bravia 32 in. tv model number KDL-32L4000 has a runaway sound that increases to the maximum and will not decrease nor mute. Unplugging causes a temporary reset. It flashes from channel 3 where it should be to channel 14 and back. What can I do?
    The tv is grounded with its three prong plug. Do you have another idea?
    Master:
  • 788 Answers
The button board on the TV where the power, channel up/down and volume up/down button reside sounds like the problem. They could just be sticky and dirty if you feel like attempting dissasembly and cleaning. Or you may have to replace the board.
Posted on Aug 27, 2008
    Master:
  • 763 Answers
Try to see the configuration of it by the menu of the tv or see the default to reset the settings.
CHARCOIS
  • 6,487 Answers
To reset the television follow this:
Turn off the TV, While holding down the UP button on the remote ,press the Power button on the TV, then when the TV turn off and turn back on Release the UP button of the remote.
Hope that helps........
  • 1,879 Answers
Electronic control for channel / volume needs fixin either by having the logic board inside replaced or some parts of it. Call for service.
  • monk3ybidzness
    monk3ybidzness Aug 27, 2008
    What the heck - try Junoon007's advise - connect your TV to the earth to stabilize the sound.
    Genius:
  • 1,011 Answers
Sir,
The problem is with earth connection. Give the proper earth connection. It will be solved.
thanks
good luck
Posted on Aug 26, 2008
  • 4,234 Answers
Anything is fixable!! It sounds like there is a logic problem. Because the problem comes and goes, I'd first look at the 5V voltage regulator section and also for poor connections on the boards. If you could post the specific model number of your set, I can provide more detailed guidance.
Thanks,
Dan
  • ABRsvcs Aug 26, 2008
    Sorry about the BS solutions sucha s a bad eath connection. This is an internal issue. I'll look up your specific model and try to give you a more detailed set of instructions for fixing this.
    Dan
  • 435 Answers
Please mention the model #
Does anybody know how to set a 32 inch Sony Bravia back to factory reset without remote
yes manually you can set press menu button then go to av setup & select factory setting from using vol+ & vol- with channel + & channel- buttons
Jun 21, 2015 | Sony Televison & Video
I also have a Sony STR-D365. Volume control works intermittently as well as right channel. Works if I "wind" the volume control up and down a bit and then goes out again. I reset it and no change. Any
There is a wiper on the back of the volume control that varies the resistance through the switch to control the volume. When you move it back and forth you are scraping the oxides off the switch and making it work again. I suggest you either get some contact cleaner and spray the control from inside (where the wiper is) or just change out the switch.
Jan 10, 2013 | Audio Players & Recorders
Sony Bravia has lost all channels besides ABC and 7 Network, this happened while the TV was on, what is wrong?
unless you are on a antenna look in the menu to make sure set is on catv and not air or antenna.
Sep 03, 2012 | Sony Bravia KDL-32XBR9 32 in. LCD HDTV
Sony Bravia KDL 32EX400 stuck on channel one
It sounds that the main system memory IC has damaged. Before make it sure, just make a hard reset to this set, and check whether it helps you. To make it a hard reset, just unplug the AC cord from AC mains wall socket, and re-plug it back after 30 minutes or so.
If this do not help you, check and replace the main system memory IC.
Aug 22, 2012 | Sony KDL-32EX400 32 in. HD-Ready LCD TV
Sony bravia v series 32"
hi,
IT normally happens after factory reset is done. You need to reprogram the channels. Try the auto program (AUTO TUNING) Process.
  1. On your remote commander " Press HOME or MENU button"
  2. Scroll down to " SETTINGS or SET-UP"
  3. Then to "CHANNEL SET-UP"
  4. Select " AUTO PROGRAM " To Auto program your LCD TV and it's done..
Jan 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My Sony Bravia KDL 32S2030 is showing a flashing led standby (4 flashes/2 secs/4 flashes. I can unplug the mains cable, leave it for a few minutes and when I pug it back in it will re-set to the green...
I'm not a service tech, but, I do have a copy of the service manual. It says the TV has a self diagnostics and according to the chart, 4 flashes indicates a backlight failure.
Oct 26, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Need to program my synergy v time warner remote to my sony bravia 32"
STEP 1: PRESS THE MODE BUTTON ON THE TOP OF THE REMOTE, THEN PRESS TV STEP 2: PRESS AND HOLD THE "SEL" BUTTON AND THESH "MUTE" BUTTON AT THE SAME TIME UNTIL THE BUTTONS ON THE TOP ARE LIGHTING UP IN SEQUENCE FROM RIGHT TO LEFT STEP 3: HOLD THE CHANNEL UP BUTTON UNTIL YOUR TV TURNS OFF. WHEN THE TV TURNS OFF HOLD THE CHANNEL DOWN BUTTON UNTIL YOUR TV IS BACK ON AND ALL LIGHTS ON TOP FLASH AT THE SAME TIME
Jul 18, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
TV switched itself off. Standby light flashing on and off once then five rapid flashes. Tv would come on but then turn off again after a few seconds.Standby light even stayed on when tv switched off at...
Subject
Unable to Power On or Off the set
Symptoms / Customer Description
The symptom may occur while the TV is ON or in Standby.
1) If the problem occurs while the TV is in Standby:
The TV will not turn on via the remote or power button located on the set however after AC reset (i.e. unplug the TV for at least 30 seconds from the AC source) the TV returns to normal operation.
2) If the problem occurs while the TV is in use:
You may lose the ability to power off the TV or switch the video inputs however channel changing, adjusting volume, or accessing the menu may still be possible. After AC reset (i.e. unplug the TV for at least 30 seconds from the AC source) the TV returns to normal operation.
Sony has designed the BRAVIA Televisions to be CUSTOMER Software Upgradeable and therefore Sony will not pay a service claim on any issue resolved by a software upgrade. If a customer requests an update please refer them to the following website: http://www.updatemytv.com. If the unit requires the update, you may enter the customer's information in the website and a USB device will be sent to their address.
If a customer does not have access to the web please have them call the Sony Call Center Support line: 1-866-210-6333
If a customer reports either symptom above request that they unplug the set from the AC wall outlet for at least 30 seconds and then plug the set back in. This will reset the TV and it should work fine for several months. If resetting the TV does not resolve the issue the customer has a different problem and a service call by a technician may be required
Jan 02, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I lost my sonia bravia 32 inch remote. The
The easiest way to find a factory remote is to search the internet by using the model number and the word "remote". You find better prices that way. :)
Sep 17, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
Top Televison & Video Experts
