Question about Nokia 6600
Password & keys
I set password on my phone 147 then when i restart my phone the three keys did not work bit the other keys work  and i can not open my phone what shall i do ???
  • 42 Answers
if keys not working means , try to service ur keypads... the service guy might change the keypad ic... it wil cost less only... without rectifying the keypad u cannot unlock.
good luck
Posted on Aug 28, 2008
Nokia 114 key not work 147*
Nokia114 147*key not work
Jan 19, 2014 | Cell Phones
Tip
PDF encryption, set PDF password and recover PDF password
PDF encryptionGenerally, PDF files are with a password called User Password, which is used to open the file and view the document. To encrypt a PDF password does not simply mean you can’t open and view the document, but PDF files have five to seven encryption ways to protect the file for office needs. Owner password, the other password of PDF files, is another crucial PDF password, which is to protect the file from maybe being copied (to Clipboard), printed, or modified, etc. So, in speaking of PDF password, it doesn’t necessary mean the one which you use to open the file.
PDF encryption largely relies on the sophisticated algorithm that hardly to be reversed. For example, you are easy to calculate that 1000 plus 1 is 1001, however, the reverse is seemed impossible, for 1001 can be an answer of countless calculations. PDF encryption works in the similar way. In this sense, given a password, it’s easy to deduce and decipher some data; however, the reverse PDF password recovery seems impossible.
Generally speaking PDF encryption with 128 bits key value is much more secure than that of 32 bits. PDF encryption is accomplished by a key value, either 128 or 32 bits in size. When using the key, all the bytes are changed (unless they are decoded back with the same key) into meaningless codes, and the file is impossible to be opened. Only the meaningless codes are calculated back using the correct value is it possible to get the correct password and open the file. 128 bits has a lot more possible values than the one with 32 bits, so it is much more secure. If your password is forgotten and intend to recover PDF password, PDF Password Unlocker software could be faster, for it supports 128 bits encryption, either 128 bits RC4 or 128 bits AES encryption.
PDF files are composed with objects, like image Objects, graphic Objects, and text Objects, etc. The key is calculated for each PDF Object in the PDF file using local data, which is much hard to crack, as the key keeps changing.
Set and remove PDF passwordsAdd a PDF Password1. Click the Secure button pdf-encryption-and-pdf-password-recovery_clip_image002.jpg in the Tasks toolbar, and choose Password Encrypt.
2. Click “Yes” to the prompt about changing the security, and if necessary, type the Permissions password that lets you change security settings. If you don’t know the password, contact the author of the PDF.
3. In the Password Security - Settings dialog box, set the security options as desired, confirm the password, click OK, and then click OK again.
4. Save the document to apply the security settings.
Note: You can also restrict editing capabilities when you certify a document, or when you apply a policy to a PDF.
Remove PDF passwords and security settingsYou can remove PDF passwords and security policies from an open PDF if you have the permissions to do so. If the PDF is secured with a security policy that resides on a server, the changes can be made only by the author of the policy or by a server administrator.
1. Do one of the following: Click the Secure button pdf-encryption-and-pdf-password-recovery_clip_image002_0000.jpg in the Tasks toolbar, and choose Remove Security.
Type your password, and click Yes to the prompt about removing the security.
In the Security tab of the Document Properties dialog box, choose No Security from the Security Method menu.
2. When prompted, specify the Permissions password, and then click OK. Recover PDF password in case you forgot it.Every coin has two sides. Even the PDF document is strongly encrypted with passwords, it is impossible to insure that it is secure. Once you forgot PDF password, the data in the encrypted PDF file are on the risk of unavailability. Unless fortunately the password knocks your memory again, you got the data lost or you have to give up the document eventually. With the ever-growing of strong encryption algorithms, decryption algorithms gradually come into existing, too. Though the cracking is far more difficulty than ever before, it is still of help to those expecting to recover PDF password and access the password protected PDF file. Take PDF Password Unlocker, a popular PDF password recovery software, for example, it has adopted the advanced decryption algorithms to crack 40-bit RC4, 128-bit RC4, 128-bit AES, and 256-bit AES encrypted passwords with 3 attack methods, Dictionary attack, Brute-force attack, and Brute-force with Mask attack
Reference: http://www.passwordunlocker.com/knowledge/pdf-encryption-and-pdf-password-recovery.html
on Apr 30, 2010 | Computers & Internet
I forget my password in my phone.how to open my phone now.
Reset or flash ur phone..
M not sure wheather this will work
Switch off the phone. Then restart the phone pressing the volume up key, End Key and Power up key to reset
Dec 22, 2013 | Samsung Wave 525 Cell Phone
Reset asus eee top to factory setting
Open the display on your Asus and click the "Shut down" tab in the lower-right corner of the desktop.
Click "Yes" when prompted, to confirm.
Power on your laptop, and press the "F9" key when you see the logo screen.
A menu will pop up with a list of three options.
Select the "Restore Factory Settings" option (which is the last one in the menu).
Select "Yes" when prompted, then hit the "Enter" key to confirm the reboot.
Wait about 30 seconds for the system to restart, then agree to the licensing agreement when prompted.
Confirm your name, password and time and date when prompted.
Then wait as your computer configures.
hope this helps
Aug 23, 2012 | ASUS Eee Top ET2002 20-Inch All-in-One...
Purchased refurbished phones and they do not have the Factory Defaulted Admin Password. How to reset the Polycom Soundpoint IP501 to Factory Default Admin Password?!?
The factory Admin info is Polycom for the user and 456 for the password. If the password has been changed, you can do a factory reset by holding down 4 keys until it restarts. The four keys are * 4 6 8.
Apr 01, 2011 | Polycom SoundPoint IP 501 IP Phone
Mobile restarts several times before opening
Try restoring or re formatting the phone, but first backup all your needed data such as phone book entries etc, for this step or steps erases the phone completely of its contents,
Turn off Phone Remove MMC(memory card) Simulteanously pres (*) (3) AND green KEy(CALL) dont release them then press power on, still do not release the three keys until you see the NOKIA handshake logo startup. Release three keys when you do, Then you will be prompted to set country, date and time settings and you are done.
I would like to suggest to have your MMC scanned for viruses too, to prevent any failures again, if the MMC have a virus on it.
Jul 15, 2010 | Nokia 6630 Cellular Phone
I forgot my china mobile phone lock password what to do
hi my phone is a China Mobile DEVICE it"s very for me to open it. BUt when I successfully OPEN OR TURN ON IT. Its suddenly shutdown automatically. I want to restore it but i forgot the Password.
Jun 07, 2010 | Nokia N95 Smartphone
How to format phone memory of nokia n72?
hi friend,,
just hold 3 buttons *,3 and answer (green) key...while switched off and on it while holding all three thats all...
thank u please rate it
Nov 10, 2009 | Nokia N72 Cellular Phone
I forgot my memory card password how to unlock it ?
IF UR PHONE IS LOCKED THAN DOWNLOAD UNLOKER SOFTWARE FROM
http://www.imserba.com/forum/showthread.php?t=113087 ENTER UR MOBILE IMEI NO. IWILL GENERATE
A CODE ENTER OT INSTEAD OF LOCK CODE
OR
REMOVE MMC BACK UP OF ALL UR DATA FROM PHONE MEMORY INSTALL NOKIA PC SUITE IN UR PC AND
DOWNLOAD UPDATES FOR NOKIA MOBILE FROM NOKIA.COM INSTALL IT AND UPDATE UR MOBILE ONLINE.IT
WILL FORMATE UR MOBILE AND RESET UR CODE TO 12345 AND ALSO RESET ALL SETTINGS
do restore factor setting form setting menu it solve ur problems or backup ur data format
ur phone use *#7370# code it remove all virus and corrupt file
GO TO RRESTORE FACTORE SETTING OR DIAL CODE *#7780# IT WILL RESTORE ALL SETTING AND REMOVE
CORRUPTIONS
RESTART UR PHONE QUICK HOLD THIS THREE KEYS GREEN KEY OF CALL, 3, *
i guarantee my solution is always right
plz dont forgetme to rate on fixya (blue line)
May 12, 2008 | Nokia 6270 Cellular Phone
SLVR L7
please goto
menu > setting > initial setup > restore factory setting
and then enter password i.e. (000000) which is by default password if you change the password than enter that password.
Note:-Never try wrong passwords more than three time, It may be risky.
Then the phone will restart.
I think all minor problems with your phone will be eliminated.
Dec 19, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Nokia 6600 Logo
32 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
