Question about Mitsubishi MSZ09UN Air Conditioner
Geckos How do I stop geckos from using the backside of my mitsubishi air conditioner mounted on the wall? How can I can access the backside of the wall mount to plug up the geckos refugee? How can you take down the wall mounted face plate?
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Use a finer mesh screen! Thank-you-very-much!
Posted on Aug 26, 2008
What does 3 green led flashes in sequence, operation led off mean on Fujitsu ASTA09LCC aircond
This means a "Serial reverse transfer error during the operation"
Diagnosis:
When the indoor unit does not receive the signal for 10 consecutive seconds during the operation
>Permanent stop after 30seconds.
[Diagnosis Point]
Check the indoor /outdoor cable connection (in order). If the cable wiring is not abnormal, measure the voltage of the outdoor
unit terminals and diagnose the defective location.
(Refer to the after mentioned [Serial Signal Diagnosis] for the voltage measuring method and diagnosis method.)
This is generally caused by a faulty controller board in the outdoor unit. Often they are shorted out by geckos or bugs but sometimes a power surge.
Jul 14, 2015 | Fujitsu Heating & Cooling
When I try to turn on my LG wall mount unit it will not turn on
Does it give you a code? Try turning only one at a time to see if that works. I would like to help you but need more information.
Sep 18, 2014 | LG LWHD1800R Wall/Window Air Conditioner
POWER ACOUSTIK PD-702
Elephants without tusks from Africa, and no geckos or oak trees.
Apr 06, 2014 | Vehicle Parts & Accessories
What are the heating requirements for a leopard gecko?
Leopard geckos, like most reptiles and amphibians, do not produce their own body heat internally. An external heat source will help them with digestion. This type of lizard obtains heat from their undersides, so the best heat source would be an under tank one. You should look for a heating mat that will cover between 1/3-1/2 of the tanks surface. Try to keep the tank temperature between 84-88F.
Sep 04, 2012 | Aqueon Reptile
Im looking to buy a bugaboo gecko hood but cant find one would the frog fit it
Not many Geckos in NZ and I've not worked on one but hoods are just held in place by canopy wires that insert into a clip on canopy holder. www.babycare.nl/spare-parts-bugaboo-cameleon-c-34_124_153.html shows the wires are the same for the Frog and Gecko so you should be fine,
Feb 20, 2011 | Bugaboo Gecko Stroller
My Samsung is mounted in the wall of my office. Once I turn the air conditioner off,it starts to leak water for several minutes. Any way to stop this? Frank
When the unit is on, go on the back side of the wall where the unit is
mounted. If this is a split system find the condensate hose and make sure it is not plugged and is draining.
If this is a window unit again go in the backside of the wall and see if it
is dripping there. If it is not, take the unit out of the wall, remove the top
and wash underneath the coils. Install the unit so it slants to the back.
Aug 04, 2010 | Samsung Heating & Cooling
Hi, Our Mitsubishi Air Conditioner is leaking from the bottom left hand corner. The conditioner will sometimes run for 1hr then start leaking, or a few hours then start leaking. We're aware it could be a...
Two ways to clear out the pipe. One way is to take a wet/dry shop vac and **** from the outside drain pipe. The second way is a bit messier. Take an air hose (from a compressor) and purge the air up the drain a few times. Works like a dream!
Jan 27, 2010 | Mitsubishi Heating & Cooling
Geckos cuase my airconditioning unit to seize up.
Place moth balls inside the unit: it acts as a gecko repellent. Just take care you do not place them in the airway as it may carry its smell. Also, when you visit a grocery store look in the pest control section you can find some sort of stickers which repel them.
Oct 18, 2009 | Mitsubishi MSZ09UN Air Conditioner
Ice forming on wall unit
either the system is blocked at the coil or theirs no circulation over the coils, flush the system and check the fan operation
May 20, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi MSZ09UN Air Conditioner Logo
466 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
