Question about Video Game Consoles & Games
CH Flightsim Yoke Sensitivity
Newwly Installed Ch Yoke Seems Over Sesitive.Same Applies to rudder pedals slightest movement sends aircraft off in all directions.Is there a means of controllig the sensitivity
  • 1,879 Answers
2 places where you can adjust the sensitivity
1. Most common is within the Game
2. From the software that came with the yoke.
Posted on Aug 26, 2008
    Genius:
  • 1,011 Answers
Sir,
CH rudder pedals by going to Settings-Controls and set the CH Rudder Pedal sliders to "Default" by pressing the Default Button on that screen.
goodluck
    Brigadier General:
  • 6,966 Answers
Have you tried adjusting the sensitivities of each axis using the Control Manager?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Aug 26, 2008
    Hi again,
    Excerpt from a review....
    "... Each of the
    controllers are accompanied by a disk containing the CH Control Manager.
    This software is used to assign functions to your controllers,
    calibrate them, making dead zones, and much more...
    Another feature
    of the Control Manager is the ability to adjust the sensitivity of each
    axis. This will determine how much of an effect each axis has on
    the sim when used. If you wanted to, you could set the yokes pitch axis
    so that only the slightest movement would perform a steep climb or dive,
    or you could set it so that you have to push the yoke in / out further
    to have the same affect, or anywhere in between
INSTRUCTION MANUAL FOR FOSSIL CH2698
See https://www.fossil.com/content/dam/fossil/PDF/watchinstructions/Fossil_Watch_Instructions_EN_US.pdf
The file is a compendium of instructions for a large number of Fossil movements, but it is unclertain which movements the model CH-2331 and CH-2698 watches use. However, movement OS10 (page 15) appears to be the only one that matches the dial layout, button layout and also has a date window as the CH-2331. The watch has a quartz analog mechanism and uses one SR927W 1.55-volt silver oxide button cell. Silver oxide cells have low current output, but very long shelf life, so if the stem is pulled out completely when the watch isn't being worn, the battery could last many years. Scan the instructions to match up the CH-2698 with a movement number. A good guess from examining photos of the face of a CH-2698 watch would be movements OS20 / FS00 or VD53.
Apr 07, 2014 | Fossil CH2331 Wrist Watch
Tip
Learn About an Aircraft, Part 2
Aircraft controls we'll be covering in this part:
  • Throttle:
A black knob, When pushed forward, puts the engine at full power, when pulled full back, sets the engine at idle. Used for setting engine power for all phases of flight.
  • Fuel Mixture:
A red knob when pushed full inward sets full rich mixture, full back kills the engine. Used for setting fuel mixture to the engine at all altitudes for smoothest running engine. and for shutting down the engine at end of flight.
  • Carburetor Heat:
Used to warm the engine air intake in icing conditions and when long descents with engine at idle, will super cool the engine and could cause engine icing.
Flaps:
A flat handled switch used to select the wing flap positions. This will be used mostly when landing the aircraft. The flaps should be advanced in increments from flaps full up to flaps full down.
  • Fuel tank select:
Used to select and use one of the fuel tanks or "Both Tanks." (primarily to balance the aircraft), Or set both tanks to off (on the ground).
  • Control wheel (Yoke):
This sets the attitude, for climbing or descending, and/or making a turn, normally used in small pitch and/or roll adjustments
  • Rudder Pedals:
These are operated by your feet. Press the top edge of the pedals, when on the ground, to apply the brakes. Pressing the lower part of the pedals Helps to keep the aircraft in line the runway in landing/takeoff and coordinated turns in the air.
  • Control trim:
There are two trim wheels below the panel, that, when adjusted properly, will release the pressure on the control wheel mostly in climbs and descents.
on Apr 11, 2015 | Sport & Outdoor - Others
As I apply throttle power during takeoff, the aircraft moves drastically to the left on the centerline
You are experiencing torque due to the propeller turning faster. You need to apply opposite rudder to compensate.
Feb 15, 2014 | CH Products CH Pro Pedals
What's your problem?Won't stop changing channels
there is every possibility that the channel (ch - and ch +) button on the TV is stuck. This can make the TV channels change by itself. This also applies to the remote control (if any).
Turn off the TV, use your thumb to flip through the channel (ch - and ch +) button on the TV. This will free the stuck button. Also, check the channel (ch - and ch +) buttons on the remove and make sure it is also not stuck in.
If the above doesn't solve the problem, then it means fault is from the control board inside the TV. It maybe defective or needs servicing.
The board controls the buttons on the TV and it can be found on the position of the channel (ch - and ch +) inside the TV.
Note that TV stores a lot of current. So if you want to disassemble the TV to check the board allow the current to discharge by remove the TV plug from the wall and wait for about 1 hour before attempting to disassemble the TV.
Let me know if you need more assistance...
Regards.
Sep 27, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
ELS 1102-2, THE HEAT CONTROL IS SUPER SENSITIVE. THE SLIGHTEST MOVEMENT HIGHER AND THE WATER IS TOO HOT, THE SLIGHTEST MOVEMENT LOWER AND THE WATER IS TOO COLD. THIS IS A FACTORY INSTALLED...
Mechanical thermostats such as the one in your heater are only accurate between 3-5 degrees once set. Unlike a digital thermostat that is accurate to .1 degrees. You can purchase an aftermarket thermostat for $120 that is digital and can be installed in your heater.
Jan 29, 2011 | Raypak 130,000 BTU Propane Gas Pool...
Does any one have the specs for a solid audio F2500D amplifier?
Power Output
RMS @ 4 Ohm: 700W x 1 Ch.
RMS @ 2 Ohm: 1300W x 1 Ch.
RMS @ 1 Ohm: 2500W x 1 Ch.
RMS @ 1 Ohm: 4000W x 1 Ch @18v
Signal to Noise Ratio: >100dB
THD (IHF-A): 0.2%
Input Sensitivity: 0.15V – 5V
Input Impedance: 47KOhm
Slew Rate: 10V/USec
Damping Factor: 300 @ 4 Ohm
Fuse Rating: EXTERNAL 200A Fuse
Dimensions (in mm):
Width: 240mm
Height: 61mm
Length: 570mm Features
MOSFET Power Supply Amplifier.
Double Sided Through Hole Epoxy PCB.
Gold-plated Brass Set Screw Terminals.
24dB/Oct. Crossover - Variable Low Pass Crossover (40Hz ~ 200Hz)
Variable 24dB/Oct. Subsonic Filter 10Hz ~ 70Hz
Variable Phase Shift
5 Way Protections
Daisy Chain Through Output RCA
Bass Remote Control
Power/Protection LED
1 Ohm Stable Circuits
Soft Start/Output Relay
18V Operation
Parallel Operation
Nov 13, 2009 | Car Audio & Video
CH products Flightsim Yoke And CH PRO Pedals seem over sensitive.Is there a way of reducind this sensitivity
I have the same problem. My Pro Pedals brake movement jumps to halfway when just placeing my feet on the unit. This reeks havoc on any car simulation game using the gas/brake combo. I have found that using the CH Products control manager, available here: http://www.chproducts.com/retail/downloads.html, helps to alleveate the USB device problems, but still doesn't fix everything thing. I have replaced the position sensors in the pedal motion, and they have the exact same problem as before. It is probably a software problem.
Aug 26, 2008 | Video Game Consoles & Games
Video Game Consoles & Games Logo
254 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
