How to move the cartridge to the left to fill in the ink?
When i switched on the printer for the first time, and wanting to fill in the inks, the cartridge cover is in the exteme right so that i cant open my cartridge cover to install the inks, pl help me
How to replace the ink cartridges on a Dell All-In-One 948 Inkjet Printer
1. Turn the printer on.
2. Lift the printer unit.
3. The ink cartridge carrier moves and will stops at the loading point unless the printer is busy.
4. Press down on the ink cartridge lever to raise each ink cartridge lid.
5. Remove the old ink cartridges from the printer.
6. If you are installing new ink cartridges, then remove the sticker and transparent tape from the back and bottom of each ink cartridge.
Note: If you are wanting to print photos you will want to install a photo cartridge along with the color cartridge. Also if you are switching between the photo and black cartridge but they still have ink in them be sure to store then in an air tight container so they do not dry out.
7. Insert the new ink cartridges. Making sure that the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier.
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing. >Open the printer cover and the output tray. >Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the power light begins to flash.
>Press the ink button again.
If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This occurs each time you press the ink button until all expended or low ink cartridges have been indicated. Once all of the expended or low ink cartridges
have been indicated, the ink cartridge holder moves to the ink cartridge
replacement position when you press the ink button.
>Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover >Press the ink button and then the printer moves the ink cartridge holder and begins charging the ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
i did this once...turned off the printer. open the cover, pull the belt drive of the ink cartridge out to the left side, replace ink cartridges and switch on the power. i hope this will help you. i am not an expert printer technician, just have to do it myself at times as we do not have any canon service centers here in an island in the west coast of africa.
Try this procedure: 1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and
place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
From older Epsons: If the ink cartridges are empty (red light on), hold the ink switch 3 seconds to move the print head to the left. If they are not empty, hold paper switch until print head moves left. Once you remove a cartridge you can't reuse it, even if there's ink in it according to Epson.
There is no way to reset the ink levels on this cartridge type yet. Any replacement chips on the internet are violating patent law. Once the chip tells the printer it is empty it will not print no matter how much ink is left in it. There is always a lag time between the introduction of a new cartridge type and the ability to fill it properly. For refills I would recommend Cartridge World when this cartridge type can be refilled.
Replacing Ink Cartridges
1.
Turn on your printer.
2.
3.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4.
5.
Remove the old ink cartridges.
6.
Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them.
7.
If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
8.
Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier.
9.
Snap each lid closed.
10.
Close the printer unit.
11.
An alignment page automatically prints.
If pressing ink button wont position printhead where you can change the ink, its a hardware failure that you are having. Call Epson and have it replaced. 562-276-1300
u first open ur printer top cover its automatically the cartridges will come to middle (or) in system go to printer option in douple click there is some options like vlack and tricolour just click it follow the rules
