Question about Epson Stylus Photo R260 InkJet Printer
How to move the cartridge cover to the left to fill in?
When i switched on the printer for the first time, and wanting to fill in the inks, the cartridge cover is in the exteme right so that i cant open my cartridge cover to install the inks, pl help me
    Genius:
  • 1,447 Answers
Hi-
If pressing ink button wont position printhead where you can change the ink, its a hardware failure that you are having. Call Epson and have it replaced. 562-276-1300
hope this helps
Posted on Aug 26, 2008
How to replace catridges for Epson Stylus Office T40W??
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing.
>Open the printer cover and the output tray.
>Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the
power light begins to flash.
>Press the ink button again. If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This
occurs each time you press the ink button until all expended or low ink cartridges have been
indicated. Once all of the expended or low ink cartridges have been indicated, the ink cartridge
holder
moves to the ink cartridge replacement position when you press the ink button. >Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover
>Press the ink button and then the printer moves the ink cartridge holder and begins charging the
ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
May 22, 2011 | Epson Computers & Internet
I need to replace the print cartridge but the carriage only stops on the far left under the frame. How do I get it to stop in the middle so the ink cartridges can be replaced?
switch the machine off then open the cover for ink cartrigde move the belt that the printer heads are on until in the middle replace cartridges and switch on machine this should work if the cartridges still does want to move the carriage rail could be very dirty and requires cleaning if you do not what you are doing advise you get a tech to assist you in this matter
Oct 18, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
The ink cartridge will not move to replace ink..
i did this once...turned off the printer. open the cover, pull the belt drive of the ink cartridge out to the left side, replace ink cartridges and switch on the power. i hope this will help you. i am not an expert printer technician, just have to do it myself at times as we do not have any canon service centers here in an island in the west coast of africa.
Aug 11, 2010 | Canon PIXMA MX310 All-In-One Printer
Cannot tell which inkjet color cartridge needs changing
Disregard the monitor information and rely on the printer.
On the left panel of the printer are your indicator lights and buttons. Push the button immediately to the left of the 'ink drop' light [looks like a little tear drop]. Open the cover and the printhead assembly will move to the left and stop. Look very closely and find that little 'ink drop' imprinted into the plastic in the very middle of the printer where the printhead assembly stopped. That 'ink drop' will line up wih the ink cartridge that needs replacing. Push that button on the left again and the printhead assembly will either return to the 'replace' position, or move to the next ink cartridge that needs replacing. Keep pushing that button just once at a time until the printhead assembly identifies all cartridges that need replacing and moves into the 'replace' position. This 'replace' position will be on the right side of the printer where the opening occurs that allows the top cover of the printhead assembly to open.
Change the appropriate cartridges and you should be good to go.
Mar 18, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Change printer ink
Turn on the printer.
lower th epirnter's output tray, pull out the extension, and open the cover.
press and release the ink button.
if your ink lights is on or flashing, the printer head moves to the left, and the cartridge that need to be replaced stops under the ink out mark.
open the cartridge cover
Pinch the back tab of the empty cartridge as your left it out of the printer.
shake the ink cartridge 4 to 5 times while it is still in the package.
unwarp the new ink cartridge and lower it into the holder. Push down gently until the cartridge is firmly seated.
repeal the procedure if more than one ink cartridge is out.
close the cartridge cover.
close the printer cover and press the ink button.
The green power light flashes and the printer makes noise. charge takes about a minutes. When it's finished, the green power light stops flashing and stay on, and the red ink light should go out.
Oct 10, 2008 | Epson Stylus C66 Photo InkJet Printer
Dell Printer carrierjam
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Aug 31, 2008 | Dell 942 All-In-One InkJet Printer
How to move the cartridge to the left to fill in the ink?
Hi-
Press the ink button ( press and release) up until it goes to the position where you can change the ink cartridge.
Hope this helps
Aug 26, 2008 | Epson Stylus Photo R260 InkJet Printer
The catridge cover goes to extreme right so that i cant fill in the inks
u first open ur printer top cover its automatically the cartridges will come to middle (or) in system go to printer option in douple click there is some options like vlack and tricolour just click it follow the rules
Ink level counter disabled, not recognizing new (refilled) cartridge.
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-24
Jan 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Cartridge stall
Solution:
Sep 04, 2007 | Dell 924 All-in-One InkJet Printer
Epson Stylus Photo R260 InkJet Printer Logo
76 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
