Question about HTC P3300 Smartphone
The phone gets disconnected/stops working
My phone gets disconnected after few minutes of use. The green LED blinker goes off. I am unable to connect and make calls. Even by pressing the "ON" button it does not work/connect to the network. I removed the battry and re inserted it, then pressed "ON" button, then the phone gets connected to the network. After awhile it again goes "OFF". Please help.
I am facing the same problem with HTC Diamond.Pls help !!
Posted on Jan 10, 2011
Acer AL1716 monitor goes black after a few minutes
if u have an extra gpu try it, becuase i hade the same problem and it was not the monitrs fault
Jan 12, 2018 | Acer Computers & Internet
Tip
HTC increase Desire battery life.
<span>Preparing...<br />With the phone in the on position.<br /><br />Fully charge the battery with the phone on... (until the led turns green.)<br /><br />Once the led turns green, unplug the charger until the led goes off. <br /><br />After the led goes off, plug the charger back in. When the led turns green , power off the phone.<br /><br />now.... with the phone fully powered off...<br /><br />1. Unplug the charger. <br /><br />2. Wait until led goes off. <br /><br />3. Plug charger back in until the led turns green. When it turns green, unplug the charger again and go to step 1.<br /><br />4. repeat steps 1 and 3, 10 times. This may take anywhere from 30 seconds to 30 mins per cycle. Typically only about 1 minute. though.<br /><br /><br />DO NOT DRAIN THE BATTERY. The goal is not to empty the battery and recharge like ni-cads (those have memory, these don't). These are lithiums, so we need to do the opposite...</span>
on Jul 11, 2011 | Cell Phones
My Panasonic LED TV picture goes away after a few minutes
Could be a bad connection that disconnects when heat in the system causes it to expand. Take to a pro or call manufacturer, they might have a recall or free repair available.
Apr 03, 2015 | Panasonic TC55LE54 55" 1080p 120Hz SMART...
I have a 2002 suzuki intruder volusia vl800. When I got it it has led rear brake and taillights no turn signals. So it only had 3 wires hooked up. I got a tail/brake/turn signal combo led it has 5...
so is this the reals story?
  1. I modified my car,
  2. now it dont work?
is that it? we cant help you fix a car that is not stock
sorry, the books only cover stock, so if walk that path, then get pro
help that is willing to work on hacked up cars.
put it back to stock
bingo it works
now break it again, repeat ,wash and repeat.
YOU DO know that many cars will not run LED , correctly right
and blinkers top that list.
there are 2 cures,
1: back to stock
2: get dummy load resistors to fool car in to thinking blinkers are stock.
most blinker modules, do a dance (actup) on purpose.
the warn you that a light is dead or shorted.
putting in LED makes said MODULE, think lights are dead.
(it measure current and goes, gee, lamp out)
so if you are not a tech or engineer, (learn that ) or skip all that. stuff.
Feb 22, 2015 | Suzuki Cars & Trucks
TX-32LZD81 fault red led flashes 13 times, repeating regularly after being taken out of standby. The led goes green initially for several minutes before it starts flashing
13 flashes denotes a fault to its main board. If you wish to get more details about these blinking codes, check this link.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 18, 2013 | Panasonic Televison & Video
How to unlock motorola 3G A1000
Try this: Might work.
Connect the phone to a powered Clip. Phone display should give "USB cable connected" message.
Press UNLOCK button on the Clip.
Phone reloads. Within 5-10 seconds phone display gives "Waiting for PST" message.
Press 1 and 2 keys simultaneously in upper part of the handset. The phone enters boot mode (if you don't press these two keys during "Waiting for PST" message, the Clip will give red E/G led and you will have to start with step 1 again).
After 1 and 2 keys have been pressed E/G green led will blink and the phone reboots. Meanwhile E/G will give frequent green blinking and phone will turn on.
Do not disconnect cell phone from Smart-Clip while green led indicator blinks!
Green E/G led glows. The cell phone is unlocked.
Axxx/Exxx/Vxxx unlocking noteDon't unplug cable right after phone reboot, wait until E/G led stops blinking!
good luck.
kc
Mar 11, 2011 | Motorola Cell Phones
92 nighthawk LED blinker problems.
Honda always grounds the turn signals separately (usually a green wire)not directly to the frame.Not hooking up the running light should not effect anything except forward visibility to other motorists. If you have a two prong flasher relay, go get a cheap flasher relay ($5-$10) and replace it. The only problem I have ever heard of when switching to LED turn signals is a flicker / fast flash instead of a normal slow flash. This is remedied by adding diodes to the wires.
Jun 30, 2010 | 1985 Honda CB 700 SC Nighthawk
I Need to locate the laptop reset button on it
to reset most labtops all you have to do is hold down the power button for about 15 seconds and it should reset
Mar 25, 2009 | Dell Inspiron 1000 Notebook
Error E 4, 2 canon pixma mp 160
E42 means scanner error. May require a hard reset(disconnect from power supply for 30 min). Otherwise may require factory reset procedure to be applied. Follow the steps below:
Mp160 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s)
according to the function listed in the table below.
(Each time the Stop/Reset button is pressed,
the LED lights alternately in orange and green, starting with orange.)
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset procedures below.
5 times Orange Destination setting See Destination setting procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Jun 29, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HTC P3300 Smartphone Logo
47 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
