Question about Panasonic Lumix DMC-FZ30 Digital Camera
Alternative battery
FZ30 battery alternative?
  • 363 Answers
Just a test post
Posted on Nov 11, 2007
    Master:
  • 903 Answers
I believe the dps-9000 will work, as an external battery. the 30 will need lots of power, I bet. and it might be some time before the generic internal batts are available for this new camera. the manual shows that the 30 has a power connector that _looks_ like the other fz's. if so, then it should just plug in and work. I know the voltage is the same.
Posted on Sep 04, 2005
SOURCE:
NI-MH D 14.4V 8000mAh Charger Hack. I need an alternative charger like charging on a car battery?
NI-MH batteries a re very different than car batteries and even tho voltage may be similar, you risk destroying your battery, camera or worse, an explosion. Your batter may only need a limited amount of amperage to charge (likely not much more than 1500ma or 1.5 amp) a car battery charger may put out twice or even ten times that much - hence the explosion risk! Also these kind of chargers detect when your battery is full and will quit charging or switch to a maintenance mode. I'm afraid you're pretty much stuck with using the charger meant for it.
May 08, 2016 | Cameras
Alternative battery charging
you cannot use any charger that is not used to charge ni-mh batteries car batteries charge at a rate of 5 amps minimum and if you do it will cause serious damage to the charger and batteries
if you want ideas , talk to a battery shop but unless it is designed to charge 14.4 volt ni-mh batteries-- forget it
What Is Alternative Financing?
normal financing is by by secured loans, personal loans or mortgage
Alternative financing is by leasing, interest only financing etc
Feb 24, 2016 | The Computers & Internet
Can't get in trunk of e320 remote not working, nor is the key blade. Is the an alternative
is it because the cars battery is flat,or have you changed the battery in the remote,some times the tiny terminal in the remote gets squashed when you replace the battery, try checking terminals are all good. if all is well and the car battery is flat try removeing a registration plate light,and get a 12 volt feed to the bulb terminal at the same time push boot /trunk rellease button. good luck.
Mar 21, 2013 | Cars & Trucks
I have a 1994 Chevy suburban alternative not changing battery but the test show that the alternator is good.can anyone help
have the battery checked any auto motive store will test for free if u cant get to one and u cant charge it replace the battery with another
Feb 06, 2013 | Cars & Trucks
Travelmate 290 works with AC, but fails to charge the battery
Possible broken laptop batteries. Acer Trafelmate 290 (year 2003 production), has a battery that can last 3 years (source: CNET Reviews). So it's possible your battery damaged, due to age factor.
The solution:
Alternative 1 (battery removed)
Turn on the laptop without the battery
Alternative 2 (insert the battery)
Because the battery is damaged and causes an error if installed, you must remove the gold coating on the battery. The battery, there is a thin plate-shaped connector, gold-colored. Remove the layer of gold, to disable the battery. So the battery is installed without the connector.
Alternative 3 (buy a new battery)
Price of new battery, $28.89. You can check at Amazon.com
Nov 10, 2011 | Acer Computers & Internet
For years I have a Lumix FZ30 working perfectly. Suddenly since yesterday, when I shift the start button from "off" to "on" the Camera does not react at all. Batteries OK, no previous problems! Any idea?
YOur power botton may short from inside. Can you remove your battery and clean the place properly and try, may be the reason of sulfer also. if not then visit service center.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Feb 01, 2010 | Panasonic Lumix DMC-FZ30 Digital Camera
Try taking the battery out and trying again.
May 10, 2009 | Panasonic Lumix DMC-FZ30 Digital Camera
Panasonic Lumix DMC-FZ30 Digital Camera Logo
43 people viewed this question
Top Panasonic Cameras Experts
rajiv6089
Level 1 Expert
AJMAL KHAN
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
