I have discovered a scratch ( few inches long ) on my flat screen television. Is this dangerous in any way? Can I jsut leave it alone and there be no concern? Please advise. Can it be fixed?
  • 4,234 Answers
This should not be a problem. As long as you can see the picture, there is no problem,
Dan
Posted on Aug 26, 2008
Scratches on mnitor
There really isn't a way to fix a scratch in the material that covers the LCD. Sorry.
Apr 18, 2014 | Samsung Televison & Video
How do I repair a scratch on the screen of LCD tv?
You have not mentioned which part of the screen is the scratch?? Anyway please note that you can not apply a chemical on the scratch. Just leave it and clean it with a slightly damp cloth as long as it does not affect the viewing of the picture on the screen.
May 22, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
There is a scratch on the screen and it's getting bigger, well it was scratched now there is a solid colored line. What do I need to do? Is it fixable? It started as a scratch about 1/2 inch now there is a...
Unfortunately it is NOT a "Scratch"... actually it is one of the "Row Driving IC's" that is failed/failing, this will only get worse and eventually it will get more & more. Worst of all there isn't anything that can be done, sorry.
Feb 16, 2010 | LG 42PC3D 42 in. Plasma Television
I was moving my pionner elite 42 inches and i hit the screen with my head, now there is a big colored big spot,also my kid scratch the screen and make some lines,how can i erase the spot and the lines,can...
If you have a pure White test sceen that you can put on it, try leaving it white for an hour or so to see if you can "burn" it out. If not, your gonna need a panel.
Oct 13, 2009 | Pioneer Elite PRO-950HD 42 in. Plasma...
Screen is stretching on each end. Vizio 32 inch. The picture is stretched on each end. The picture looks real weird and it almost makes you dizzy when you look at it.
Sounds like the display is in a mode which is sometimes called "Horizon", where they seek to fill the entire 16:9 screen with an image which is originally 4:3 by leaving the center of the image mostly alone and stretching the ends out horizontally. If your remote control has an "Aspect" button you might try pushing that a few times to cycle through the various settings.
Oct 10, 2009 | Vizio Televison & Video
Repairing screen on a flat screen tv.
the screen alone is gonna be expensive for those tvs your best bet is to buy a whole new tv because to replace it is gonna cost the same for a new tv unless their is a warranty
Jan 31, 2009 | TruTech PLV16320 Television
Polaroid FLM-2601 flat screen
It has a protective outer screen and depending on the depth of the scratch you might be able to restore it. You'll need to look on-line at a few aircraft site for a kit that is meant to polish scratches from the plexi in an aircraft windshield. There is a company in Oregon http://www.chiefaircraft.com/airsec/Aircraft/Windshields/ScratchRemoval.html
that sells the kit for 34.95....
It is time consuming but I have restored many this way!
Bill
Mar 27, 2008 | Polaroid FLM-2601 Television
Thick plastic film covering glass screen got deeply scratched while moving
Hi there!
I would simply replace the plastic sheeting. Will certainly be cheaper than replacing a tube. Glass tvs don't normally come with this plastic so leave it off if you can remove it. There is a type of spray on the market for this purpose, just don't know if available in your country. Please note: It is dangerous to use a tv which had been scratched beyond 1.5mm, The glass may become unstable and implode if bumped by accident. Good Luck,JUS004
Mar 08, 2008 | JVC AV-32FA44 32" TV
No picture 27" Akai LCD
if you can solder, you can fix this television. open the back there is one visible board with three bulging caps on it. the other board under the aluminum screen is usually fine leave it alone for now. On the board withe the bulging caps (three in a row 16v1000mf) you will need to remove the problematic caps. Use a desoldering iron or if you are very brave you can use a dremel (not advisable as you would have to remove the solder from the joint and then remove the caps with pliers). You can get 24v1000mf caps at radio shack for next to nothing jsut solder them in and rplace the board in the unit. viola if it doesn't work then you need to replace the MLT168a/b board you were jsut working on with a MLT169c from megmeet.com Replacing the caps did it for me though
Mar 18, 2007 | Akai LCT2701TD Television
Scratches on my plasma tv
your stuck with it, no way to erpair a scratched screen
Mar 05, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
