Question about Philips 32PT6441/37 32" TV
Power not working
Power comes on sometime and then after 2 or 3 days wont work.phillips 32 plasma.
  • hm1234d Aug 26, 2008
    this is a plasma tv about 4 yrs old.thank you
My tv is broke but a want to fix it the power is just fhaching but wont come on and souns like bip bip i chek one of the parts makeing sound en the numbers is this naislksiaf-12 v alk5321 and thailandspule 12.v then tv 5 503050 . 5 a 250v tuv 5 3/100a so pleas contac to me and tanks for help me ( can i replace the part and fix it my self ) AND WERE CAN I FIND THE PART
Posted on Sep 10, 2008
The power button is flashing red...
It ur power board,Tries buy it replaced it ur self it pretty easy.
Nov 18, 2009 | Philips 50PFP5332D 50 in. Plasma...
Having problems turning on 2 year old Phillips
Philips TVs tend to have issues with bad capacitors in their power supplies. Failing capacitors tend to have slightly different ESR (equivalent series resistance) values when they have been left off, versus after they are warmed up and charged up. Either a new power supply board or replacement of the faulty capacitors will fix the problem.
Oct 20, 2009 | Philips 42PF9630A 42 in. Plasma Television
Phillips 32" HDTV power light blinks green but wont turn on
the problem in the main power supply it depends of the kind of faillure but normaly to repair it not very expensive
good luck
Aug 23, 2009 | RCA F32650 32" TV
32"InsigniaLCD TV will not turn on for days & has a popping noise
You Must get help from someone with electronic repair knowledge and experience to open your television and check the power supply board and main board for faulty components. You will need some one who Has tools and experience around televisions. The tools needed are Phillips screw drivers and plastic pry bar tools to unlock the casing once the screw are removed. They also will need soldering Iron and solder,solder wick and a solder removal pump. They will need a multimeter to measure components to check to see if they have failed. They should replace all suspect components. If after all this is tested and replaced and still not repaired. Then search ebay for replacement boards for you model of television or buy them online from the dealer or other sources. Always make sure you are dealing with reputable people and have return clauses for defective products. Always remember This product is dangerous and never work on it with the power on. Try to discharge the power supply board before working on it. I hope this will give you some help in resolving your problems.
Mar 26, 2009 | Insignia LCDTV26 26 in. Television
Phillips TV Sometimes Come's On No problem and Then Not sometimes with Green blinking light
I HAVE LOST THE TOP PORTION OF MY SCREEN, APPROX 2 1/2". IS THERE AN EASY WAY OF REPAIRING?
Oct 13, 2008 | Philips 32PT6441/37 32" TV
LG LCD TV 32" INTERMIDENTOFF
Plan on fixing or replacing the power board soon. It will keep getting worse until, the end. There is a small bright side. It is the best damage to sell your broken tv "as-is" online. Someone will come pick it for sure.
Sep 12, 2008 | LG 42PC1DA 42 in. Plasma HDTV
My phillips flat tv won't turn on?
I have come accross a lot of complaints regarding philips tv's, with premature failures the common ailment. I have filed a complaint at the following:
http://www.consumeraffairs.com/class_actions/
Click the "complaint button" and fill out the form. If enough complaints are filed, an attorney will review them.
Apr 15, 2008 | Insignia 42" LCD Flat-Panel HDTV
Phillips 42" plasma power problem
See if the following solution is relevant for you (it worked for me and was worth it):
http://www.fixya.com/support/t182302-maxent_mx_42vm11_turn
Apr 11, 2008 | Televison & Video
Phillips 30PW633R37A - Wont Turn on.
Hi Panix:
Sorry, but it sounds as if the power supply or high voltage circuit has failed. You will have to take it to a repair shop.
Feb 24, 2008 | Philips 32PT6441/37 32" TV
My 42 inch plasma wont turn back on after power cut?
We purchased a phillips plasma 50" in july 06 and it cut on and off 5 or more times a day I called phillips customer service they told us it was due to the cable company they came out and changed the tv jack gave us a new box and tested the lines said everything was ok. The problem still kept happening got back to phillips and they sent us a flash drive to update the info in the tv. still kept happening told us it was due to tv being sensitive to power flutuations. well we are now 5mths out of warrenty and the power board blows up! phillips will not do anything to help the person I spoke with admitted we were given bad advice the bill was estimated at over $500 so if I were you if its still under warrenty make them send someone out to look at it, Reading up on phillips tv complaints this seems to be a common thing By the way phillips customer service sucks dont rely on them to help you much. good luck
Jul 02, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 32PT6441/37 32" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
