Question about LG LHD65EBL Dehumidifier
Dehumidifier water will not drain to hose
  • ksweetie Sep 03, 2008
    Can't get the hose connected securely so it behaves as if the bucket is full. Sloppy fittings, I guess.
    Guru:
  • 462 Answers
As for the drain most have a plastic pan and this is sometimes the type that has to be removed and dumped or a hose has to be attached and the hole it attaches to has to be cut out for self draining.
If the threads are fouled up all I can suggest is a lot of Teflon tape or pipe dope or cut out and replace the fitting with something that will correct the problem.
If this helps please rate me as high as you can and thank ytouu for using fixya.
Posted on Apr 30, 2009
  • 105 Answers
SOURCE: Connecting a drain hose
Most units have a drain connection, either on the machine itself, or in the collection pail. These connections usually fit standard garden hoses.
Posted on Jul 17, 2007
SOURCE: Kenmore 54501 Dehumidifier
Clean the hose (it's full of black gunk)
Posted on Aug 12, 2008
SOURCE: Problem with draining water through hose
I raised mine up on a platform about 6 inches, and now mine works fine. Don't know why this is necessary, but atleast it works now.
Posted on Aug 15, 2008
SOURCE: Water from LG 30 pt dehumidifier drains into
(assumming you are not an idiot, like the other solver suggested) you may very well have it connected to the right spot, many of these units, are not balanced well, (or are balnaced all to well, depending on how you look at it) The imbalance, basically makes the water drip to the front, instead of the back. Try to put something under just the front of the machine, to tilt it back, ever so slightly. Good luck
Posted on Jun 26, 2009
SOURCE: DeLonghi dehumidifier hose by drain tray leaking
I think that I am having the same problem, but I'm not sure that this tube needs to be plugging into anything. However, my humidifier seems to be draining out of this tube rather than from the tray into the bucket.
Posted on Jul 18, 2010
Dehumidifier manual
Good morning friend, thanks for your post!
Based off what you're explaining it sounds like your Frigidaire dehumidifier might not be leveled. Any time your dehumidifier is not properly leveled water will not drain out the rear but instead into the bucket. I would recommend checking to assure your appliance is leveled. If your dehumidifier is leveled detach the hose to make sure nothing is blocking the water for exiting into the hose. If those steps are unsuccessful and you continue to get water into the bucket please respond back and I can research more information for you. Best of luck. -Matt
Aug 17, 2014 | Dehumidifiers
Why is my Kenmore Energy Star 50 pint model 251-50501012 dehumidifier leaking water after I disconnected the drain hose
If you reconnect the drain hose, make sure that it lays flat from the dehumidifier and into the sump pump hole. I did that and it solved my problem of water leaking onto the floor.
Jun 15, 2014 | Kenmore 50 Pint Dehumidifier Electronic...
Why doesn't water drain into the hose?
My dehumidifier was dumping condensate onto the floor instead of through the hose to the floor drain. The solution turned out to be making sure the unit was level. No worries since then.
Feb 05, 2013 | Haier 65-Pint Energy Star Dehumidifier...
Hose connected but not draining and bucket filling
I am also an air conditioning tech, with same problem and same soleus dehumidifier problem. you must remove the plug and install the drain line hose adapter. Hose must lay flat and have no "hills" for water to drain. With this done pull your drain pan out and set aside. look under right side facing the dehumidifier and you will see a small spout. Has a lip like a little tea pot. Plug that spout. I used a foam ear plug used in work shops. Now give the front of dehumidifier a slight rise on front wheels about the thickness of a pies of cardboard 1/8 to 3/16 of an inch. Now put drain pan back in an start up. The problem is the drain pan was made with very little differance in pitch between the the hose drain and the bucket drain. Remember to check your drain hose periodically and the air filter also. Good luck
Sep 09, 2011 | Soleus CFM-40 Dehumidifier
Our new Santa-Fe Classic dehumidifier is leaking water from the bottom of the unit. It's also sending a small amount of water correctly through the tube for dispersal. We've only had it for two...
The classic model drains thru the clear hose using gravity. The drip pan in that unit is about 1/2 way up in the cabinet. Make sure the drain hose exits the unit and runs flat or downhill. If the drain hose is coiled vertically or run up hill causing water to trap within the hose it can cause water to back up in the dehumidifier drip pan and overflow causing your problem. If your drain is higher than the base of the dehumidifier, you can raise the dehumidifier or you can purchase a condensate pump kit that will allow the drain water to be pumped up to 15 feet above the dehumidifier.
The drain hose may have become disconnected from the drip pan as well. To check, turn off the humidistat to stop the dehumidifier from running. Next disconnect the cord from the power supply. Remove the six screws holding the cabinet side (with the label) from the cabinet and remove the cabinet side. The drain hose connects to a nipple on the bottom of the drip pan.
Contact Therma-Stor service for further inquiries at 1-800-533-7533 - they are located in the USA and are very helpful.
Sep 07, 2011 | Therma-Stor Santa Fe Dehumidifier
I have an Energy Star 54701. Turned on, 35 % humidity set, hose connected and ready to drain in sump hole, bucket connected. set for 6 hours. No water is draining from hose or into bucket????
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 02, 2011 | Soleus 30-Pint Dehumidifier
I tried to drain direct via garden hose, perfectaire PA50 dehumidifier. I unplugged the plug, connected the little hose that came with the thing..connected to the inner spout and to the hose adaptor,...
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Please rate 4 stars if this is helpful. Thanks and good luck!
Aug 15, 2017 | DeLonghi 50-Pint Electronic Control...
How do I switch from continuous drain to draining into the bucket? I have a Danby Pro dehumidifier. Thanks Tyler
Disconnect the hose and reattach the hose connection drain cap, that was removed when the hose was attached. The water will then be diverted into the water collection bucket
Hope this helped you, Tyler and thanks for choosing FixYa.
Aug 01, 2011 | Danby DDR5009EE Dehumidifier
I connected a hose to my dehumidifier to drain the water. The water is still going in the dehumidifiers tank. What else do I need to do?
Check the hose connection on the dehumidifier, as well as the hose for clogs. That is what usually happens when a hose is connected and it doesn't drain properly.
Also, the hose should be no more than 5 feet long and MUST slope downward to drain properly. As, the drain relies entirely on gravity. There is no pump.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 06, 2011 | Maytag M7DH45B2A Dehumidifier
LG dehumidifier won't drain through hose anymore.
Make sure hose is flat with no high or low spots. Blow or **** out hose and pour somr bleach water through hose.
Jun 30, 2009 | LG LD65EL Dehumidifier
LG LHD65EBL Dehumidifier Logo
271 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
