Hello
If there is a "Menu" button on the front panel of your Curtis TV, you can select its inputs by surfing through it. If there is no MENU button you can't do it. If it has, select the item by up/down channel and volume buttons. OK.
There is no menu button
If it is there, Hit it to display its menu. Go to audio options and choose the correct one you wants. Use volume UP/DOWN button to change the options; channel UP/DOWN button to select the item. After select the desired item [AV]; if it is there, press Menu button to enter it. OK
If there is no Menu button, it is immpossible to select the options. Just buy one universal remote control which can be synchronides with Curtis. Look the remotes manual and make sure that it has codes for Curtis TV before you pay. OK.
