Question about Samsung Televison & Video
I am testing a TV and when tuning in the channels cannot seem to store the channel so the TV does not 'forget' it. It is an old Samsung. Any ideas?
    Genius:
  • 2,920 Answers
Try adding them one at a time through the add erase menu
Posted on Aug 26, 2008
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
I re-tuned my TV (Samsung) on 03/09/14 as suggested by the pop-up message. i have now lost channels that are not listed as changing - namely Channel 24 (ITV4) and all the HD channels. i have tried the
You need to do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh.
Sep 07, 2014 | Samsung Televison & Video
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
New LG 32LD350 - Allowed TV to auto-program channels, and for some reason, it skipped past channel 4 during the tuning process. When I select channel 4 in the tuning options, it comes up as no signal. On...
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Mar 11, 2011 | LG 32LD350 32 in. LCD TV
How to get and store all the channels automatically?
hi,
u can auto tune ur tv for storing channels aromatically through the following steps
1. press MENU button and then select CHANNEL and press ENTER.
2. select country and press ENTER
3.select AUTO TUNE and press enter.
4. press ENTER again.
wait till it memories all available channels.
after auto tuning it will display sort channels. if u want to sort channel, do it, if not exit the option.
ok
Dec 15, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Will not store bbc1 dvb channel
I have contacted Panasonic, they are aware of the problem and will post you an update card to correct the fault.
Jul 27, 2009 | Panasonic TX-26LXD1 26 in. LCD Television
Toshiba 2151TB Television
I had a similar problem. You need to press the 2nd button down on the remote 3 arrows should appear on the screen. then use the volume + and - buttons to tune to correct channel. once the correct channel has been reached you need to enter the number of the channel u want stored ie 03. Hope this helps.
Sep 07, 2008 | Toshiba Televison & Video
Tuning My Tv
If you've store the earlier channel, off the tv and on it again. Every should come back as normal.
Regards
alan
Mar 02, 2008 | Televison & Video
TV not storing vcr channel
most newer tv's wont store the channels if the channel isn't always putting out a signal. not much you can do about it
Oct 31, 2007 | Televison & Video
Televison & Video Logo
71 people viewed this question
Henry  Thomas
Henry Thomas
