Question about Maytag Dishwashers
Water will does not drain completly the hose is not kinked nor is this unit hooked up to a disposal. maytag portable unit
  • 1,031 Answers
  • Check sink drain and drain hose for restrictions
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Posted on Aug 26, 2008
Water is not draining Maytag Jetclean
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 24, 2009 | Maytag 24 in. DWU9202 Built-in Dishwasher
I have a Maytag MDB7100AWB that won't drain water after completed cycle
Hi
Thanks
Rylee
Dec 23, 2009 | Maytag Dishwashers
Our Maytag MDB7100AWS Dishwasher fails, inconsistently, to drain.
Hi
Thanks
Rylee
Dec 23, 2009 | Maytag MDB7100AWB Dishwasher
My Maytag dishwasher will not drain at the end of the cycle. However, if I start a new cycle the first thing it will do is drain. What should I check?
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 07, 2009 | Maytag 24 in. DWU9202 Built-in Dishwasher
Dishwasher is not draining
Hi
Thanks
Rylee
Nov 04, 2009 | Maytag 24 in. MDBH955AW Built-in...
My Maytag dishwasher Model # MDB-3 will not drain. Please help. Thanks! Anna Giacobbe
Hi
Thanks
Rylee
Nov 03, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Maytag Quiet Series 100 Help - diswasher always has water in the bottom - doesn't fully drain. We took apart as far as we could down to the hole with the orange washer _ no obstruction. Put it back...
Hi
Thanks
Rylee
Nov 03, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
I have a Maytag dishwasher, model number DWU4910AAX. It is not draining. I suspect that it may be the pump, but I want to be sure. What should I do?
Hi
Thanks
Rylee
Sep 15, 2009 | Maytag Dishwashers
Diswasher does not drain after rinse.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to some different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then you may want to consider calling a professional plumber. He may need to replace the drain valve or hose.
Thanks
Rylee
Aug 20, 2009 | Maytag Dishwashers
Maytag DWC7602 drainage problem from tub bottom
OK. Try these steps.
-If hooked up to a food waste disposer, be sure the "knock out" is removed from the disposal inlet.
-Be sure the drain hose is ELEVATED at least 32" so water cannot siphon back in the tub.
-Check for a food obstruction in the drain or disposer.
-Check drain hose for a kink.
-Check your home's circuit breaker or fuse box.
-Check that the cycle is completed.
Hope this helps you!
Apr 22, 2009 | Maytag 24 in. DWC7602 Free-standing...
Dishwashers Logo
138 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
