Question about Denon AVR-3802 Receiver
Denon AVR-3802 Front Display problem
I've had this receiver for about 7 years. Everything functions fine, but the front display shows gibberish, completely unreadable characters. The characters do change when I select different sources or processing, but none of it makes sense. It's almost like it's trying to display a different language on the front display only.
The onscreen display works fine, but I have to switch TV inputs to a non-digital source to view it. I've searched but can't seem to find any information.
  • superbiker Aug 26, 2008
    Thanks for the quick repsonse Dan. I'll try as soon as I can get the unit out and see if this helps. I do think the problem started after a strong thunder storm moved through.
  • 4,234 Answers
This can be either the display itself or the display driver IC havng problems. Something as simple as poor solder connections may cause this as well. Without seeing hte unit, it is difficult to say what the real problem is. If you can solder, try resoldering all of the voltage regulator ICs in the unit. These look like transistors and will be marked 7805 or 7812. If the voltages drift too low because of bad connections, the ICs can get "confused" and not work properly.
Keep us posted.
Dan
Posted on Aug 26, 2008
  • ABRsvcs Aug 26, 2008
    It is also possible that the chip that controls the display got smoked a bit because of the storm too.
    Keep me posted.
    Dan
Yamaha RX-V2600 completely dead ... any ideas
If it is plugged in to a working outlet, and the AC cord is not broken, there is a problem in the power supply of the receiver. This provides all of the DC voltages that make all functions work. If it is completely dead, the display, the lights, the audio, (everything) is not working; and it is not likely there are separate problems in all of these areas at the same time.
Feb 17, 2013 | Yamaha RX-V2600 Receiver
Geller et6800 displays wrong characters
Sounds like it needs to be brought in for repairs my friend.
Aug 11, 2012 | Computers & Internet
Seth thomas autoset wall clock not functioning. replaced both sets of batteries (AA and CR2032), still not working.
I wish I had a solution... I'm in the exact same situation. I put in new batteries, and all I get is a faint reading of gibberish from the LCD screen, and that's it. I've tried following the instructions, but I can't set the time in the LCD clock, since it's unreadable, and almost completely gone. Seththomas.com has a web page indicating that "they will be back with info", but no support or FAQ pages. Disappointing... I have three of these clocks, and they are all behaving the same way.
Apr 10, 2010 | Seth Thomas Radio-Controlled Howard Wall...
HP Laser Jet 4 with an unreadable screen
It may be a coded error message. See here.
Otherwise, try following these instructions to reset the language options.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 24, 2009 | HP LaserJet 5550 Printer
Gibberish + won't finish loading Windows
remove the new memory first. if that does not help you may have some a virus, indicated by safe mode workng fine. One other thing i found would do that is a damaged Hard drive, not to likely here because safe mode works.
Apr 28, 2009 | Dell Dimension E521 PC Desktop
Front Display Panel Letters are Scrambled and Cannot Be Read
Could need to be reset. Try unplugging it for a couple of Min's. it may reset itself. If not send me a message and I'll check the service manual for the reset procedure on Monday when I go to that hell they call work.
Mar 06, 2009 | Yamaha RX-V800 Receiver
Pioneer super tuner 3
For most Pioneer single CD players, you can set the clock using the following steps:
1. Press and hold the SOURCE button until the unit turns off.
2.Press and hold the FUNCTION button, until display pops up, then release.
(If you do not have a FUNCTION button, then push the AUDIO button)
3. Press the FUNCTION button again until the clock shows on the display.
4. Press the UP and DOWN buttons to adjust the hours.
5. Press the LEFT or RIGHT arrows to move to the minutes.
6.Press the UP and DOWN to adjust minutes.
7. When complete, press the SOURCE button to exit.
  • 1 year ago
Apr 29, 2008 | Car Audio & Video
I'm a Fresher in ASP.NET 2.0, Please help me
You need to change the column type from BoundField to TemplateField and call the substring method like this
<asp:TemplateField>
<HeaderTemplate>
Comments
</HeaderTemplate>
<ItemTemplate>
<%#Eval("Comments").ToString().Substring(0, 25)%>
</ItemTemplate>
</asp:TemplateField>
In this snippet, I am displaying only the first 25 characters of the Comments field.Only problem with this approach is that if even one of the rows contains a comments field with less than 25 characters, this might trigger an error.The fool proof way then is to write a small function in codebehind which will check the length of the field, chop off any extra characters and in case of shorter strings,
( THANKING " Balgates " For this HELP )
Apr 21, 2008 | Computers & Internet
Denon AVR-3802 Receiver Logo
307 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
