Question about Panasonic Lumix DMC-FX7 Digital Camera
Focusing problems I have an FX-7 and it recently went through a small spate of focusing problems, both broad daylight and evening. I discovered some fain grease/hand smear on the lens. Cleaned that off (hot breath and microfibre cloth) and it went back to normal?
    Novelist:
  • 196 Answers
Yes sometimes things that seem like big trouble are nothing but small time and totally fixable problems...
Posted on Feb 09, 2006
Why can't my brand new Meade Polaris 127 telescope not even show me stuff in broad daylight or night. No matter the lens, eye piece, eye, object near or far. I only see eyelashes sometimes if I try.
I suspect that what you have is a combination of two problems:
1. you are very far out of focus,
and
2. you have too much magnification.
Here's what I would do.
Point your scopt at some distant trees. Use your lowest power eyepiece, and run the focus all the way from one end to the other. At some point, you should see the tree leaves....
Nov 15, 2015 | Meade Optics
Focusing problem
Perhaps your only option is to send it in for repairs .
Sep 07, 2015 | Cameras
My NikonD3100 is no longer focusing, my battery is charged and I am at a loss
Make sure you're using a lens that worked before on this camera.. many consumer bodies lack the built in focus motor, so you must purchase lenses that have the motor built into the lens. If it lacks a motor - no auto focus will be possible.
Remove and re-seat the lens.
Make sure that any Aperture ring on the lens barrel is set to the smallest (largest number f22) possible.
Make sure any and all Auto / Manual Focus switches are set to A or Auto.
Try taking a picture in broad daylight - or other well lit area - if the subject is very dark, the auto focus will struggle or "hunt".
Let me know if these suggestions solve your problem - good luck!
Oct 19, 2014 | Nikon D3100 Digital Camera
My a930 polaroid does not focus well at all what can I do??
This could very well just be the nature of the camera-- are you attempting to take pictures in low light? This can cause difficulty for the camera to focus. If the camera is having trouble focusing in broad daylight, then there is likely some problem with the autofocus system that would need to be examined by a camera repair shop. The repair on a point and shoot camera like this one would likely exceed the value of the camera.
Mar 10, 2011 | Polaroid a930 Digital Camera
New out of the box Cannon 550 with a 18-55mm 3.5 - 5.6 lens and I can only focus in the wide angle shot. The zoom to 55mm is out of focus even when set to AF and an automatic setting. Am I doing...
In automatic mode and automatic focus - The camera should focus onto the subject given that there's enough contrast between your subject and the background. If it not focusing at all even in broad day light conditions - You lens is faulty.
Also - Do you or your friend have another lens to test if the camera is faulty?
Feb 28, 2011 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Sigma 70-300 Macro Motorised Lens for Nikon has stopped autofocus
If you just purchased the lens I would take it back sounds like the lens is jarred and defective should still be on warranty
Jan 22, 2009 | Nikon D80 Digital Camera with 18-135mm...
My 300D wont lock on a point in its AF setting
If you are unable to focus in broad daylight and it just hunts through the whole focus range without locking, then it sounds like a problem with sub-mirror pin (also called the second mirror pin). My 300D just had this problem and I had to send to service to get fixed. I sent to http://www.keh.com/ as they were at least $50 cheaper than going straight to Canon. Just got it backed and it works like a charm again.
Jul 24, 2007 | Canon Digital Rebel / EOS-300D Digital...
DSC-T7 : Blurred images ?
I don't own a T7,but I have the P150 and S40. All these small Sony digicams have something in common;Sony uses 1/40 as the default flash shutter speed in low light conditions,while other makers use 1/60.You are more likely to get a blurry picture compared to other digicams you have previously used,unless you hold the camera steady (two hands). The other thing about these cameras is their lack of weight, coming in at a mere 134 g/4.7 oz. Light weight means you must hold the camera steady (two hands) or risk camera movement when you press the shutter. Again, the tendency with a small,light weight camera is to hold it with one hand while you take a picture,this leads to blurry pictures. The review for this camera is positive; a "Dave's Pick." - Just remember the flash range is only 5ft / 1.6m. http://www.imaging-resource.com/PRODS/T7/T7A.HTM
Sep 12, 2005 | Sony DSC-T7 Digital Camera
Photoes are not sharp
Hi, I have never had focus problems with my FX7. I suggest you set the AF mode to 1-area-focusing. This mode is quicker than the 9-area-focusing. To eliminate any possibility that the blurry photos are caused by camera shake, I also suggest placing the camera on a tripod (or setting it down on a flat surface) and using the self-timer to release the shutter. At this point you can also turn off the image stabiliser. A well lit outdoor subject is probably preferable for this test, as low contrast scenes sometimes cause the auto focus problems. If the photos under these conditions are still blurry, then you probably have a defective autofocus. Otherwise...
Sep 04, 2005 | Panasonic Lumix DMC-FX7 Digital Camera
Panasonic Lumix DMC-FX7 Digital Camera Logo
78 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
