Question about Maytag Washing Machines
Door locks but no go - Maytag Washing Machines
  • 639 Answers
Dear grahamconnor,
ngfam1 here for you!
I am happy to be of assistance!
Procrastinating and trying to figure out why is just a waste of your time.
I believe it's time to use service for this particular situation!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF
Posted on Aug 26, 2008
I get the DL on my washer
Door Lock Error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
•Door Lock Mechanism broken or removed from the Door
•Check Door Lock/Switch Assembly
•Check the wire harness connections to the Door Lock/Switch Assembly and
Central Control Unit (CCU)
•Door Lock/Switch Assembly Failure
Mar 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ghw9100 Door lock solenoid 60 ohm and 126 ohm? Duet job aid says 60 ohms on contact point 3 to 2 and 3 to 1 that is not possible because the two windings double the resistance the way its made. ...
The terminal numbering of the door lock and unlock solenoids solenoid looks messed up and your resistance reading is correct and the solenoids are good as long as you get 60 ohms both on 3-2 and 2-1 and 120 ohms on 3-1.
You stated, as per live chat discussion, that the door never locks to start a cycle. The door locking routine starts only if the door switch contact is closed (refer to page 6-2 of Job Aid L-68). This could mean the door switch contact never closes for the door locking routine to be initiated and a wash cycle can start or the CCU is not detecting it closed.
Check the continuity of the door lock and switch assembly wire harness (door switch, door lock main switches, and solenoids wire harnesses) including the connectors. Replace the wire harness if a discontinuity or any other issue that might jeopardize its function is found. Proceed with the troubleshooting if no issue is found with the harness or if the problem is not resolved with the replacement of the harness.
Reinstall the door lock and switch assembly, reconnect the wires, put the door gasket back over the outer lip of the door opening, and close the door. Reconnect the door lock main switches and the door lock/unlock solenoids harness except the door switch harness. Jump a wire between the door switches terminal connections (adjacent terminals) on the central control unit (CCU) then reconnect power and start the machine.
The door locking routine should start and eventually lock the door and start the cycle if the issue is with the door switch not closing. Replace the door lock and switch assembly if that is the case. The problem is in the CCU not detecting the door switch closing and needs to be replaced if door locking routine still fails to start, lock the door, and start the cycle.
If the door locking routine starts and the door lock seems engaging but fault code "FdL" flashes and the door is locked, unplug the machine then check the continuity of the door lock main switches at the wire harness connector in the CCU (refer to page 5-3 of Job Aid L-68). The problem is also with the door lock and switch assembly if there's no continuity in any of the door lock main switches. Otherwise, the problem is in the CCU not detecting door lock main switches closing and needs to be replaced if there's continuity in the switches.
With the fault "FdU" flashing when the door lock main switches bypassed, the CCU is certainly detecting the switches closed. This eliminates the possibility of the CCU not detecting the door lock main switches closing. It leaves only the possibility that the door switch is not closing or the CCU is not detecting it closing.
Sep 23, 2010 | Whirlpool Washing Machines
Washer will not start, it beeps and say's dL / F
Door Lock Error---(F/DL)
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
• Door Lock/Switch Assembly Failure
This will essentially be the result of a failed door locking mechanism(wax motor failure). The necessary actions are to replace the entire door locking assembly. Click here to access the repair manual for your unit. This universal duet manual will guide you through the necessary testing procedure and component accessing, as well. Replacing the door locking mechanism will correct this issue.
Aug 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer says dl and then f
Potential Causes
Aug 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door won't lock
Hello, here is the meaning for the code and what you should do.
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes / Procedure
• Door lock mechanism is broken or removed from door.
• Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Thanks
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet GHW9100L washer door will not unlock and code comes up F dl, any idea's?
Ff dl (failure fault door lock)
Door Lock Error
Potential Causes
The door lock may have to be removed and replaced to get past this failure.
Mar 18, 2010 | Washing Machines
Washer door is locked and won't open. Error code
DOOR LOCK ERROR
After 6 failed attempts to lock the door.
Possible Causes/Procedure
Jan 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does code F LD mean?
Long Drain. Remove the drain pump filter and clean it out.
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore Elite Quiet Pak 4 HE3T Washer. The door is locked with clothes in it. The displays is saying F dL. What has happened and how can we open the door.
Apr 12, 2009 | Washing Machines
WHIRLPOOL DUET WASHER 9150 DOOR LOCK DOES NOT UNLOCK
Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
replace door lock and ccu sorry
Jul 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
