Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Water left in dishwasher
By krisbizzell on Aug 26, 2008
There is dirty water left in the bottom of the dishwasher after it completed an entire cycle; drying and all. What could this be and why will not even do a rinse cycle now?
Best Solution
posted on Aug 26, 2008
Very Helpful)
jonniewalker
Rank: Guru
Rating: 88%, 619 votes
  • Check sink drain and drain hose for restrictions . The drain hose can cause the dishwasher to fail to drain properly. The recirculation hose can be responsible for problems with poor rinsing of dishes.
  • To access the drain hose remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
    The drain hose connects to the pump and runs to the sink drain (or to the air gap on top of the sink). The pump has a second hose that recirculates the water back into the dishwasher. The drain hose is roughly 1 1/2 inches in diameter. While inspecting the drain hose, check the recirculation hose as well.
    If checking for leaks, feel the hoses where they connect to the pump, for wetness and check the ground right under the connections. If they are wet, it may be a loose or improperly mounted clamp, a damaged pump housing or a leak in the hose itself.
    If checking for blockages, disconnect the drain hose from the pump, pinch the wire clamp with pliers and slide it up the hose. Place a shallow pan beneath the pump to catch any spillage. Remove the hose from the pump; wiggling the hose may help to loosen it.
    Check the hose and nipple to the pump for any debris. The only way to be certain the drain hose is completely clear is to disconnect it from the sink and run water through (such as spraying a garden hose through it at full pressure). Disconnect the recirculation hose and check it in the same way.
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
kitchen aid model number kudco31vbs is it good
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
hi my fridge freezer has stopped working, the fridge light is still on but it will not freeze or... (More)
Answer
Siemens SL34A006UC Dishwasher not cleaning top rack
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
