Question about Olympus EVOLT E-300 Digital Camera
Image adjustment functions
What kind of image adjustment functions are available on the EVOLT E-300?
    Master:
  • 852 Answers
SHARPNESS - The function is to adjust sharpness of capturing images. CONTRAST - The function is to adjust contrast (distinction between light and dark) of capturing images. SATURATION - The function is to set color depth of capturing images. GRADATION - In this function, you can select the brightness of an entire image. It is suitable when you want to add a brighter effect to a bright object (Hi Key) and a darker effect to a dark object (Low Key).
Posted on Sep 04, 2005
SOURCE:
LCD montior not on to see picture before taking picture
On the EVOLT E-300 it is not a camera that has a live view LCD screen that will allow you to see the image before it is taken. You must take the image with viewfinder only and only use the LCD screen for review purposes. This is how the camera was designed.
Mar 15, 2009 | Olympus EVOLT E-300 (Double Lens Kit)...
Olympus E510, Flash Flicker
If you are in a low lit area with the camera dial set to Auto the flash will do a strobing type of flash trying to help allow more light into the scene. This is called the AF illuminator function. To just go ahead and take the image, put the camera dial to P (program Auto) go to Menu - go to Wrench 1 tab - then right arrow over and then down arrow to AF Illum - right arrow and turn this function from On to Off and then take the image in the P mode setting. No flash flicker should occur.
Nov 03, 2008 | Olympus EVOLT E-510 Body Only Digital...
Zuiko 70-300 evolt 300 malfuntion at start up
You MUST update you firmware on the E300 and if using XP take out the memory card.Go to Olympus master online.
Nov 01, 2008 | Olympus Zuiko 70-300mm f/4-5.6 Digital ED...
EVOLT E-500 LCD Problem (Mirror Image)
This is new one one. It would seem to be an electronic failure of some sort Suggest you refer to Olympus Support on this one
Aug 20, 2007 | Olympus EVOLT E-500 Digital Camera
Playback modes
There are playback modes such as single-frame, Index (you can select the number of frames to display on the monitor from 4, 9 or 16 frames), Close-up (2x through 10x magnification), Slideshow (display the stored images one after another in succession) or playback images by rotating.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Metering modes
There are three metering modes: Digital ESP, Center Weighted Averaging and Spot. DIGITAL ESP - The camera meters and calculates the light levels or light level differences in the center and other areas of the image separately. CENTER WEIGHTED AVERAGING - The metering mode provides the average metering between the subject and the background lighting, placing more weight on the subject at the center. SPOT - The camera meters a very small area around the center of the subject, defined by the spot metering area mark in the viewfinder.
Focus modes
There are four focus modes: S-AF (Single auto focus), C-AF (Continuous auto focus), MF (Manual Focus), and S-AF/MF (Simultaneous mode). (SINGLE Auto Focus): Focusing is performed once when the shutter button is pressed halfway. C-AF (CONTINUOUS Auto Focus): The camera repeats focusing while the shutter button is pressed halfway. (MANUAL FOCUS): The function allows you to manually focus on any subject while looking through the viewfinder. SIMULTANEOUS USE of S-AF mode and MF mode: You can fine-adjust focus manually by turning the focus ring after AF is performed in the S-AF mode.
Built-in flash
EVOLT E-300 model has been developed to allow everyone to easily enjoy superior digital imaging performance with a consumer-oriented digital SLR camera.
Media cards
You can use Compact Flash cards (Type I and II) and Microdrive. By connecting with the CF Card adapter (MACF-10), xD-Picture Cards can also be used. Basically, you can use any manufacturer's Compact Flash Card in EVOLT E-300. The following Microdrive cards are verified as compatible with the E-300 camera: DSCM Series - DSCM-10340, DSCM-10512, DSCM-11000 3K4 Series - HMS360402D5CF00, HMS360404D5CF00
The main features
Four Thirds System standard-compliant dedicated digital design and a class-leading, full frame transfer 8-megapixel (effective) CCD for high image quality. Attractive new low-profile design with 85mm body height for outstanding portability. Dust Reduction System and metal body components for high reliability. Outstanding operating ease with fast SLR response for enjoyable shooting. A wide range of shooting functions for enhanced versatility.
Olympus EVOLT E-300 Digital Camera Logo
78 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
