Question about Apple iPod nano
Nano ipod i have forgotten the pin number i used to lock my nano ipod how can i unlock it
  • Apple Master
  • 2,794 Answers
Restore you Ipod back to factory settings to reset the pin.
Posted on Aug 26, 2008
  • Tim Babcock
    Tim Babcock Aug 26, 2008
    To restore the IPod back to factory settings. Open Itunes and dock you IPod. Using Itunes, select the IPod setting screen and select restore to factory settings.
Volume limit password reset on ipod nano
Hi
How to Unlock iPod Volume Limit
Your iPod volume can be limited, and in many instances, a PIN number will be necessary to remove the limit. If you've forgotten or misplaced your PIN, you can still unlock your iPod volume limit using your computer.
1 Connect your iPod to your PC. Make sure your hidden folders are visible.
2 Navigate to the "iPod_control" folder. This will be a hidden folder. Once you've found the "iPod_Control" folder, navigate to the "Device" folder.
3 Locate the file named "_volumelocked" in the "Device" folder. Delete this file.
4 Eject and restart your iPod.
5 Navigate to "Settings" on your iPod. Select "Volume Limit." You'll be able to reset your volume limit with a PIN or password.
Tips & Warnings
Do not listen to your iPod at high levels for long periods of time; doing so can damage your hearing.
Nov 23, 2011 | Apple iPod nano
Is theres a number i can call for technical support for help to unlock my ipod nano
No Number but try this:
Screen Lock" is provided by the iPod nano, iPod (5th Gen), and subsequently released full-size iPod, iPod nano, and iPod touch models. Earlier iPods, and iPod shuffle models, do not offer this feature. In the Apple Support Site, Apple notes that the "Screen Lock" function:
Allows you to set a 4-digit combination to prevent someone else from using your iPod while it is not attached to a computer. When an iPod is locked, you must enter the combination to unlock the screen. This feature is different from the Hold switch in that the Hold switch only prevents iPod from turning on accidentally -- not keeping snoops out. Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll be able to manage music on your iPod with iTunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod). This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data."
Oct 11, 2011 | Apple iPod nano
Im trying to unlock the combination lock on my 4GB Ipod Nano serial number YM8368BY37G
IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one
IPod synced with), and open iTunes. When you disconnect iPod from the
If you can't unlock IPod using either [the code or connecting it to the
to your iPod.
If you want to change the primary computer that your IPod is associated
with, do this:
computer.
IPod, which will erase all music and data."
Good Luck, I hope this helps
Please Rate me...Thank You
May 11, 2010 | Apple iPod nano
I forgot the pass word to my ipod nano
the best way to unlock the iPod when the screen lock code was forgotten is to connect it to your computer and view it in My Computer. Go to folders, make sure you can view hidden files then go to ipod control click device then delete the file named _locked. unplugged ur ipod and its unlocked,
Mar 10, 2010 | Apple iPod nano
I have locked my ipod nano how do i unlock it if
you have to restore it in itunes... you will have to reload everything as this will wipe your ipod clean but i think this is your only hope
Nov 25, 2009 | Apple iPod nano
Locked my apple nano ipod and don't know pin number.
Hi All,
First you can try to connect the ipod to your computer and try to update the software using the Itunes and then try to use your ipod... even after updating the software if you r not able to use, the you should restore the ipod to factory settings
Jan 31, 2009 | Apple iPod nano
Cant unlock ipod nano
hope this web excerpt helps:
Nov 22, 2008 | Apple iPod nano
Locked iPod
You can unlock your iPod nano in two ways:
A Enter the combination on iPod nano by using the Click Wheel to select the numbers
and pressing the Center button to confirm them. If you enter the wrong
combination, it flashes red. Try again.
A Connect iPod nano to the primary computer you use it with, and iPod nano
automatically unlocks.
Note: If you try these solutions and you still can’t unlock iPod nano, you can restore
iPod nano. See “Updating and Restoring iPod Software” on page 50 for more
information.
Sep 03, 2008 | Apple iPod nano
Locked ipod
information.
Aug 23, 2008 | Apple iPod nano
I need to unlock my screen lock but i lost my ipod drive and i cant afford another one
â Enter the combination on iPod nano by using the Click Wheel to select the numbers
â Connect iPod nano to the primary computer you use it with, and iPod nano
information.
Jun 26, 2008 | Audio Players & Recorders
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
