Stanley twin cooker cooker works ok Central heating works ok BUT when we put the switch to hot water only systems does not work please help
  • Anonymous Mar 16, 2014
    when baffles tuned to rads water is boiling in unit
    water boiling in unit .have replaced water pump, have replaced stat
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
I'm from Oklahoma, & we have'nt seen that type of heating system!
Posted on Aug 26, 2008
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
I have a stanley brandon 80k oil range style cooker. The Hot water and oven work fine but the heating intermittently does not work when either set to come on via the timer or via pushing the override...
Sounds like you have a valve sticking or a safety switch causing it to shut down. Does this unit exhaust first then the burner ignites that might be your issue
Jan 09, 2015 | Ovens
Central heating not working but hot water is ok.
If when you turn power off you wait a while it is probably not the central system coming on. You have a triple aquastat that maintains a temperature level needed to provide hot water. but you are not getting the thermostat to operate the central heating. The thermostat is a switch that operates by temperature. if you have tried raising the thermostat and the system did nor kick in. try jumping the thermostat terminals in the aquastat . if that works then the problem is either in the thermostat or the wiring to the thermostat. also with a electrical tester." while the thermostat is jumped" test the c1 and c2 terminals to see if power is going to the circulator. If not then you need a new aquastat. if you have power and the pump is not moving water replace it.
Oct 13, 2014 | Water Heaters
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
Have a back boiler. Central heating working fine. Hot water not.
Depends on type of control system but usually you will have a three-way motorised valve somewhere. This is contolled by the tiimer and the thermostat on your cylinder. Look for a box that has one pipe going in to it and two further pipes coming out. I suspect yours is stuck on heating. Some models had a manual lever to put it to just hot water. End of the fday you need to get someone out to fix this one.
Jun 16, 2010 | Heating & Cooling
Alpha oil fired cooker (aga type) & central heating breakdown.
you dont say but i presume you have an early model 1996-2000. these had the most horrid burners ever. its wasnt untill later when the ecoflam burners were used that problems that you describe were elimanated as a standard every day problem. better still was the much later 800 series ecoflam twin burn as fitted in the rayburn 800 series this is the aga company that closed down the alpha and now produce the same cooker with better burners.
www.topoftherangeltd.co.uk who can suply used and new burners for you
Dec 25, 2009 | Kitchen Ranges
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
Open vent central heating
yes it is possible toupgrade the system to a sealed one using a system boiler as you mentioned. the thing to bear in mind is to upgrade the radiator valves to pressure rated ones 10bar.
The probable cause of the over heating is down to the system being sludged up/cold feed blocked, or possible pump circulating problem?
I would recommend the installation of a magna clean filter to help keep the new boiler clear from system debris.I would definately power flush the system, if the system is a twin two port valve system then a automatic bypass should be fitted, all of this done by a corgi registered gas engineer
Kindly
Richie
Dec 18, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Heating & Cooling Logo
348 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
