Sony Mini Hi-Fi Component System (MHC-RG660)
I have a Sony Mini Hi-Fi Component System (MHC-RG660) which has developed a fault. It will suddenly switch itself off and the power button flashes. I then unplug the system and switch it back on but it immediately switches itself off again with the power button flashing. I have done the checks suggested in the troubleshooting manual and it is none of the those.
What could be the problem?
  • 3 more comments
  • Anonymous Oct 19, 2008
    MHC-RG660
  • Anonymous Dec 01, 2008
    I'm having the same problem expect now unplugging it and plugging it back in does not work anymore. It won't turn on at all.
  • Anonymous Feb 24, 2009
    my sony hi-fi component system won't shut off. I've tryed unplugging it and plugging it back in but it just turns on and I'm still unable to shut it off. help...
  • Anonymous Mar 21, 2014
    i have a sony Mini Hi-Fi System MHC-RV333DA if i turn on the dvd player reads but all the press buttons not working pls. help!
  • Anonymous Mar 28, 2014
    I have sony mini hi fi component mhc-gzr999d sometimes if i switch on my unit and put it on high volume well not so high volume upto 11 but when i do so my unit just went off and the power button is blinking what is wrong with my unit because every time i used it i cant raise the volume to my desire pls help me with this prob and one thing no any
    msg i see on the display just the blingking power button and the unit is off and i cant switch on without unplugging
I understand the problem. It should be the relay which is not responding, technically not able to connect the system power supply, you will have to replace the relay. The STK chip should be working fine.
Posted on Oct 24, 2008
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
No Audio on MHC-RV777D
its a commom fault in all the Hi fi system.its a dry fault put soldering in all components. the problem may be solved.
Nov 21, 2012 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
MHC-GN1300D Video
I need to unlock a Sony mhc 1300D mini hi fi component , make it to play all the region
Oct 24, 2012 | Sony Mhc-gn1300d 3 Dvd/vcd/cd Changer...
Sony MHC-RG660: audio steadily deteriorates on all speakers after powering on.
The problem is in the audio output ic, it is breaking down under load, the solution is have it replaced.
Mar 31, 2012 | Sony MHC-RG660 CD Shelf System
We need a manual of Sony mini hi-fi component system mhc-5600
The manual that you are looking for can be downloaded here http://www.nodevice.com/manual/sonymans/manual2435pdf/get3955.html In order to view the PDF file you will need to have Adobe Reader installed. This is provided free from their website, http://get.adobe.com/uk/reader/ djrydr.pngThis would be the first page from the manual. Hope this helps, and good luck DJRYDR
Jul 27, 2011 | Sony 720W 5-Disc Mini Hi-Fi Component...
I've sony mini hifi MHC-GZR88D. flicker
cold reset your hi fi system, by powering on your system then while holding stop button press disc 3 and power at the same time.
Feb 10, 2010 | Sony Electronics - Others
Owners manual for a Sony Mini Hi-Fi, component system,MHC-GX250
You can download the required manual from:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX250
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks.
Nov 25, 2009 | Audio Players & Recorders
I need a owners manual for a Sony Mini Hi-Fi
Click Sony Support to download user manual of MHC-GX250
Thanks.
Nov 25, 2009 | Sony Audio Players & Recorders
1,214 people viewed this question
 Grubhead
Grubhead
