XBV443 lens cleaner not a solution to no read jpg CD
What next?
    Genius:
  • 3,422 Answers
please describe your problem in detail.
Posted on Aug 26, 2008
Put cd in, says it’s reading disc, after10 seconds it says Not Playable, then ejects disc
hi Nancy.
this could be dust on the lens that reads the disc.
Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD.
read up some more at this link.
How to Fix CD Player When It Won Play Techwalla com
Dec 20, 2017 | Audio Players & Recorders
Zenith XBV443 no picture or sound after reading DVD disc
see this causes and fix it. God bless you
Clean a DVD disc:
  1. Hold the disc by its central hub and outside edge.
  2. Blow dust from the bottom surface with a can of compressed air.
  3. Clean dirt and fingerprints from the bottom surface with a lint-free cloth dampened with CD/DVD-cleaning fluid or denatured alcohol, wiping from the center outward.
  4. Clean the objective lens:
  5. Remove the housing and lift the hold-down clamp to expose the lens.
  6. Remove dust with canned air or soft brush. If needed, use a foam swab or a camera-lens tissue dampened with lens fluid.
Sep 30, 2012 | Zenith XBV443 DVD Player/VCR
DVD has no picture or sound after reading
1) test the output cables from audio +video, clean it the contacts terminal from DVD to TV from oxide, corrosion.
2) test if the cable is faulty proove in another devices. and replaces
3) clean the objetive LENS with disk cleaner or use cottong swab with special liquid cleaner.
4) if the problem persist the problem will be in OPU + ampLifie Out audio associates circuit.
Go to the repair shop TV. for fix it.
God bless you
The DVD player won't accept any discs
tried first with cd lens cleaner, if can not get with cleaner you can do the manual lens cleaning. using with the fiber cloth soak small amount of alcohol then apply cleaning the lens. make sure before do this unplug the unit and do this gently not to damaged the lens.
Aug 30, 2012 | Toshiba Televison & Video
When I place my cd in it is showing no disc. My e-mail is breezyhill19@aol.com
Sounds to me like the lens is dirty. There are only a couple things that will cause this. First make sure the CD you are using is not a home burnt one. Some CD's get burned with a format that the CD player will not accept. Next thing you want to do is make sure the CD you are using is not scratched real bad. The laser cannot read read scratched CD's. You can get disks of all natures resurfaced for a couple dollars from your neighborhood video or gamers store. Next thing you want to do is gently clean the CD slide real well with a dry cloth and then get a CD cleaning disk and run it in your CD player two complete times. A dirty lens will not read a CD and a real dirty lens may need more than one cleaning. Sometimes the lens comes out of alignment and will not read anything anymore. Just a mm out of alignment can cause the lens to fail to read. This has to be addressed by a tech, should this be the issue.
Mar 24, 2011 | Sony Audio Players & Recorders
CD tray opens and shuts fine. With CD loaded and shut the screen still says NO DISK. These are disks which have always played without problem on this CD player. Is there anything I can try before taking...
When the CD player loads properly and still reads as no disk this indicates that the player lens (Optical device which reads the disk information) Is either dirty or bad. The only option you have is to get a disk lens cleaner and run it on the system. Once you run it, it is supposed to work if the lens is not spoilt. Otherwise you will just have to replace the lens by taking it to a repairer.
Hope this solution has been helpful?
Jan 17, 2011 | Audio Players & Recorders
CD Changer
Common Problem with AIWA 3 disc machines. I have 3 in my service shop right now. For tray not rolling in on it's own, the drive rollers have to be changed, along with the Drive Belt. Also, for CD not reading, try CD lens cleaner.
Sep 10, 2006 | Aiwa NSX-A115 Shelf System
Televison & Video Logo
Top Televison & Video Experts
